Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 20, 2020 at 4:18 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Finally got the Christmas tree and decorations down yesterday and back in the attic.
    truchador, wilcam47 and Kolunatic like this.
  2. Jan 20, 2020 at 4:58 AM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    Busy day yesterday, put tint on a couple windows in the master (working graveyard and the shades aren’t cutting it) and the front door since it glares directly on the tv in the afternoon.
    hung a couple curtains
    smashed a bunch of boxes from all the Amazon Christmas orders.
    and, hung some patio lights on my fence to fix the VERY dark corner of my yard. Paired it with a Christmas light timer to have it on for a few hours after dusk. Gotta return a mis-ordered box of the lights and order the matching ones to finish the other 100+ft of fence. Turned out pretty good and wife’s happy now.
    LTDSC, Hawco636, Drainbung and 2 others like this.
  3. Jan 20, 2020 at 8:01 AM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    N-fabs, BakFlip VP, power tailgate lock, bed lights, "raptor" grill lights. Standard mall crawler stuff.
    Which lights did you get? Are they LED?
  4. Jan 20, 2020 at 8:17 AM
    theredofshaw
    Yes
    Banord 2 Pack LED 48FT Outdoor String Light, Commercial Grade Heavy Duty Light String with 15 x E26 Socket, 36 x 2W Dimmable S14 Bulb String Lighting, Waterproof Vintage Patio Hanging Light https://www.amazon.com/dp/B07JJX32HL/ref=cm_sw_r_cp_api_i_7jDjEb6AQ6K3T
  5. Jan 20, 2020 at 8:18 AM
    JEP
    JEP Resident Lurker
    Madison
    15 DBL V6 4WD
    Perfect, thank you.
  6. Jan 20, 2020 at 8:41 AM
    theredofshaw
    there is a coupon to click for $7 off on there too.
    Drainbung likes this.
  7. Jan 21, 2020 at 10:33 PM
    TK-422
    TK-422 Toyota! Oh what a feeling.
    So Cal - SCV
    2015 4Runner TEP
    Toytech 2.5 lift BFG KO2 275-70-17
    I made a few changes while waiting for the parts to arrive. Mostly adding flex lines to the big tanks.
    The Big tanks (50 gallon water heater behind for comparison)
    UV light with a spare bulb.
    Lot$ of brass and copper. You can see the dinky filter on the side of the dryer that is being replaced.
    It's going to be a busy weekend.
    LTDSC, scottalot, GHOST SHIP and 2 others like this.
  8. Jan 22, 2020 at 7:30 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Is that a Pelican System?
  9. Jan 22, 2020 at 8:47 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    replaced bathroom faucet...
    scottalot, robssol, buyobuyo and 5 others like this.
  10. Jan 22, 2020 at 8:19 PM
    TK-422
    So Cal - SCV
    2015 4Runner TEP
    It is very similar, in fact I believe it is the exact same equipment. I got my system from filtersmart. That is only the two tanks and pre-filter. The rest is mostly from Amazon.
  11. Jan 22, 2020 at 9:53 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I installed a Pelican System in my place in San Diego and it made an immediate difference. However, soak the hell out of the media for well over the recommended 48 hours is what I found.
  12. Jan 25, 2020 at 10:58 PM
    mgfab3
    mgfab3 Well-Known Member
    looking for some advice. I am contemplating laying some vinyl flooring down in my basement. the cement floor was painted with a one stage epoxy top coated with a sealer. My issue that I have run into is that in certain area where I had temporarily laid rubber floor tiles the underneath had moisture when I picked them up. I cant imagine moisture coming threw the epoxy. Could it be moisture in the air getting trapped? I run a dehumidifier in the warmer months. I am just hesitant to lay the vinyl tiles and then have accumulations of water underneath. Has anybody run into this problem, and what was the solution? Thanks in advance.
  13. Jan 26, 2020 at 12:11 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    We have incredibly hard water but with farm fields around us we also have nitrates that started out on top of the fields. Our well is nearly 200’ deep. Point is everything will eventually work its way down to the water table.
    Copper pipes don’t like soft water.
    Soft Water in your Pipe System
    Water that is soft will not create mineral build up within the pipesbut it can create pinhole leaks as soft water is lacking in minerals making it aggressive towards unlined metal (copper) pipes. ... Eventually, the corrosion will perforate the pipe walls, creating pinhole leaks.
  14. Jan 26, 2020 at 7:16 AM
    Martyinco
    Martyinco Well-Known Member
    Anytime we lay a laminate or luxury vinyl plank floor on concrete we always use a plastic vapor barrier. Not sure what part of the country you’re in but that’s pretty standard for us in Colorado
  15. Jan 26, 2020 at 7:35 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    If you read the rest of the posts you would realize it was sarcasm. Especially with a well that is only 21’.
    robssol[QUOTED] likes this.
  16. Jan 26, 2020 at 11:32 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    if you have room you could lay some Dricore first then your finished flooring
    shane100700, FastEddy59 and 23Skidoo like this.
  17. Jan 26, 2020 at 11:38 AM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    That’s what it’s called. :annoyed: Couldn’t remember the name.
    Kolunatic likes this.
  18. Jan 26, 2020 at 11:42 AM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I used that in my basement when I lived in WV, worked like a champ!
    shane100700 and 23Skidoo like this.
  19. Jan 26, 2020 at 2:13 PM
    mgfab3
    I'm in NJ. Any idea where the moisture would be coming from? Wouldn't moisture collect under vapor barrier?
  20. Jan 27, 2020 at 12:02 AM
    OZ-T
    Peter North
    British Columbia
    does code there not require a vapour barrier under the slab ?
