Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Jan 2, 2014 at 11:16 AM
    #1921
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    This has more than enough to handle that 8"w by what 6" lumber?
    Although I think Pete was suggesting one of these if I am not mistaken.
  2. Jan 2, 2014 at 11:47 AM
    #1922
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    now you're tempting me :D
    ...yep, he was referring to the hand-held kind, while i was thinking of the desktop type as you have shown... i'm not experienced /w these machines, but i'm assuming i'd still have to first get one face flat (including removing twist), and then it would have taken a lot of passes to get the opposing face co-planar... there was quite a bit of twist and thickness variations across these slabs... and then, i still would've had to joint the edges flat/square and parallel by hand, no?
  3. Jan 2, 2014 at 11:59 AM
    #1923
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Yes , if you are trying to joint a board , you would have to true one face first before using the thickness planer
    The electric hand plane just gives you the ability to quickly remove the bulk of the material
  4. Jan 2, 2014 at 12:14 PM
    #1924
    wileyC
    Centerville, OH
    got it... the power tool would've helped w/ the rough dimensioning (...i.e. in place of my scrub plane conversion)... my biggest concern was getting the edges jointed and straight because i'm going to glue the slabs together edge-wise... then, i'll have to re-flatten at least one (the top) of the faces...
  5. Jan 2, 2014 at 12:17 PM
    #1925
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    This^^
  6. Jan 3, 2014 at 2:49 PM
    #1926
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    I always run my concrete board/ hardi board over that lip (the one on top of the tub). I normally fur out the walls with 1/4" material and have also carved out board. I feel it give one more level of protection that the water will not get behind the wall. I have seen it done that way but I think they build it out with some sort of hydraulic cement.
  7. Jan 3, 2014 at 10:41 PM
    #1927
    OZ-T
    Peter North
    British Columbia
    It's not supposed to go over the tub flange
    " 3. Attachment
    Place a 1/4" spacer strip or shim around lip of tub or shower pan to hold bottom edge of cement board off lip. "
    http://www.northlandconstruction.com/products/2629/techsheet/DrckCement_Board-Installation_Guide.pdf
  8. Jan 4, 2014 at 12:23 PM
    #1928
    OZ-T
    Peter North
    British Columbia
    Love at first sight
  9. Jan 4, 2014 at 1:48 PM
    #1929
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Nice Pete
    :gossip: what's the square in the front rt corner (next to the tape measure) for? My dad had one, just don't know what it's "main purpose" is :eek:
  10. Jan 4, 2014 at 2:09 PM
    #1930
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    For marking straight square marks on things, such as wood, but can be used on any material. Very similar to the other one on the left, just doesn't have the 45 degree capability or the little level bubble and isn't adjustable
  11. Jan 4, 2014 at 2:31 PM
    #1931
    OZ-T
    Peter North
    British Columbia
    I use it mainly to set tools up for square cuts
  12. Jan 4, 2014 at 3:21 PM
    #1932
    ImpulseRed008
    Susan
    SC
    thanks Pete
  13. Jan 4, 2014 at 3:22 PM
    #1933
    OZ-T
    Peter North
    British Columbia
    anytime
  14. Jan 4, 2014 at 5:14 PM
    #1934
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Learn something new every day
  15. Jan 4, 2014 at 5:15 PM
    #1935
    OZ-T
    Peter North
    British Columbia
    Like table saws , chop saws , biscuit joiner , anything with a tilting fence or blade
  16. Jan 4, 2014 at 5:38 PM
    #1936
    Pchop
    Pchop Beavis Killer
    Rob I
    Stuart, FL
    '09 Tacoma TRD
    Yeah, I know what your were referring to. I always just thought they were really nice squares for fine cabinetry wood workers.
    I always use a speed square for saws and such.
  17. Jan 4, 2014 at 5:45 PM
    #1937
    OZ-T
    Peter North
    British Columbia
    I use that square for joinery sometimes too
  18. Jan 4, 2014 at 7:34 PM
    #1938
    Frkypunk
    Timmy
    Woods of P.A.
  19. Jan 4, 2014 at 7:36 PM
    #1939
    OZ-T
    Peter North
    British Columbia
    You said you run yours over the flange , that's incorrect
  20. Jan 4, 2014 at 7:38 PM
    #1940
    Frkypunk
    Timmy
    Woods of P.A.
    If you fill it anyway...what's the difference?
