Home Improvement Today?
Discussion in 'Garage / Workshop' started by Hotdog, Jul 28, 2008.
  1. Mar 26, 2020 at 12:44 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    We had to do the cut-in with a foam brush around the stiles but the rest was done with a foam roller.
  2. Mar 26, 2020 at 12:49 PM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Home improvement/yard improvement
    12x16 lofted shed for my atv and lawn mower and tools.
    Currently out for delivery
    Coolerman and shane100700 like this.
  3. Mar 26, 2020 at 12:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    down the wall between the damp proofing and the 10mm drainage cavity provided by the dimple membrane into the 4" perforated pvc pipe in a clean gravel drainage bed wrapped in heavy filter fabric then into a solid 4" PVC pipe to daylight
    if you're a real builder that is
    Pchop, RyanTacoMC, 23Skidoo and 6 others like this.
  4. Mar 26, 2020 at 1:26 PM
    megillet
    megillet Resident Badass
    Mark
    Atlanta, GA
    2010 4x4 TRD Sport DCSB MGM 6sp
    I have one. Only issue is my M12 XC6.0 battery wiggles out of it during use. All of my other batteries stay in fine, so it may be more of a complaint for that specific battery.
    Toyko Joe[QUOTED] likes this.
  5. Mar 26, 2020 at 1:37 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    Home Depot has a package deal for the oscillating tool and a m12 drill/ driver for $129 with two batteries so I'm kind of :drool:
    wilcam47, Drainbung and shane100700 like this.
  6. Mar 26, 2020 at 7:02 PM
    Babybluetaco
    Austin
    09 5 lug
    All finished. Now to build a ramp
  7. Mar 26, 2020 at 8:56 PM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    Finally getting around to “unfinishing” a corner of the basement for a shop.54B11775-9946-4D38-8895-E157123142C9.jpgCACD486A-8844-4176-AC96-24FD52A3E5A0.jpg023DD2A9-D124-4E29-89E0-875A39D79AB6.jpg
    pdenajim, RyanTacoMC, Bagman and 5 others like this.
  8. Mar 26, 2020 at 9:01 PM
    81shark
    81shark Well-Known Member
    Nice. I need to redo my garage storage
  9. Mar 27, 2020 at 8:08 AM
    Babybluetaco
    Austin
    09 5 lug
    Mid way through building my ramp. It’s not treated wood. Doing this on a budget. Plan on staining the hell out of it top and bottom. If it’s last 5 years I’m happy
    Edit: any suggestions?
    wilcam47 likes this.
  10. Mar 27, 2020 at 8:15 AM
    Martyinco
    Martyinco Well-Known Member
    Couple coats of poly and if you can the end of the ramp that would be sitting on the grass, try to put it on blocks or something so its not sitting in the grass.
  11. Mar 27, 2020 at 8:26 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Spend the $ on a piece of 3’ treated 2x6, let that contact the ground. It’s only a few dollars.
  12. Mar 27, 2020 at 8:33 AM
    Babybluetaco
    Austin
    09 5 lug
    Yeah I thought about letting it sit on some concrete blocks
    Drainbung likes this.
  13. Mar 27, 2020 at 8:35 AM
    Martyinco
    Any way you can isolate non-treated wood from constant contact it is going to help you, or as Shane100700 said just buying a small piece of ground contact wood for that edge of the ramp would help as well.
  14. Mar 27, 2020 at 9:03 AM
    98tacoma27
    Ben
    Not Beech Creek
    It will still pull moisture from the block.
    wilcam47, shane100700 and Drainbung like this.
  15. Mar 27, 2020 at 11:21 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Exactly this.
    I made mine out of weather treated 3x6’s. Wasn’t much more cost wise.
  16. Mar 27, 2020 at 12:53 PM
    Babybluetaco
    Austin
    09 5 lug
    Oh well it’s done. If it rots In 5 years I’ll build another. Still got to build lofts and get some metal shelves for it, and wire it up
    Also my first time building anything out of wood
    916carl, wilcam47, Hawco636 and 10 others like this.
  17. Mar 27, 2020 at 3:10 PM
    jsi
    jsi Well-Known Member
    native earthling
    I used one of those for my mailbox. 27 years later it's still doing its job.
    ^this right here ^
    I've set a number of posts with nothing other than what came out of the hole. Put a little dirt in, tamp it down hard, rise, repeat.
  18. Mar 27, 2020 at 6:47 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Trimmed up the trees out front this morning, so I can walk under them without ducking while I'm mowing.
    Tested the pool water and made a few more adjustments.
    Pulled the weeds/grass growing in the driveway cracks/joints. Started edging with the weedeater until I ran out of line, and it wouldn't start after I replaced the line. The pull rope goes in/out, but it feels like it isn't pulling against anything. I didn't feel like tearing into the edger, so I ran to the gas station and refilled the gas cans because I was out of 2-stroke fuel.
    Went for a swim for the first time since I bought the house this past fall.
  19. Mar 27, 2020 at 8:51 PM
    RyanTacoMC
    RyanTacoMC 96 Tacoma LX (RIP)
    Bay Area, CA
    2005 Base Access Cab 5-Lug RWD Manual
    4x4 Springs, QA1 TS703s, Rear Sway Bar, blah blah
    Excavation pretty much done for the koi pond! I await dry weather to stock up on concrete...
    When a new project meets an old project: surface/french drain... I never wanted to see you again!
  20. Mar 27, 2020 at 9:31 PM
    RyanTacoMC
    Bay Area, CA
    I'm assuming this is some retro "mid-century modern" version of peg board? Link?
