Home made access cab Stealthbox?
Discussion in 'Audio & Video' started by winterboy04, Apr 2, 2010.
  1. Apr 2, 2010 at 7:43 AM
    winterboy04
    winterboy04 [OP] Professional Cube-Jockey
    MA
    07 SR5 TRD (Bright Red)
    Alpine CDA-9886 Hybrid Audio Unity Series components JL 250.1, JL300.4 Infinity Perfect 10.1 SVC 4ohm in custom enclosure / amp rack Alpine PXA-H100 Processor FatMat everywhere URD short shifter OEM Bed Mat Tail Gate Safety Mod (Plumbing clamps) Pro-Dry S Filter
    Has anyone else attempted a to build a box for their center console on an access cab? I found this picture while ripping through the search results for a stealthbox and i was very interested in seeing if anyone had done it? My plan is to try and get an 8inch sub in there and have it sound good. Sounds simple enough, but i'd love to hear from anyone with experience in trying it? yeah, i know there are much easier options out there, but i want to be able to fold the jump seats up and down at ease and have the full length of the rear access cab (for my dog, of course).
    the thread i found the picture on is below (and yes i PM'd him as well)
    http://www.tacomaworld.com/forum/audio-video/15631-2005-stealthbox.html
  2. Apr 2, 2010 at 7:55 AM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    for me, i will only go with ported sub boxes, so unless this can have a slot port (i think that would be best) at the top or bottom i wouldn't even consider it.
    edit, also it doesn't look like he has lost any space in the cup holders :S shouldn't they be trimmed as well?
  3. Apr 2, 2010 at 7:57 AM
    only_K
    only_K Future Owner
    Kevin
    Central California
    Currently searching for dream truck...
    TBD
    Yea for an 8" sub you wont get much out of it unless ported. It has to be a good 8".
  4. Apr 2, 2010 at 8:02 AM
    Cars0n`
    Carson
    Alberta
    03 2.7L 4x4 5spd
    i was also thinking could you raise the console a bit to allow the box to be a bit taller. i hate how you loose so much console room. mines filled with useful stuff
  5. Apr 2, 2010 at 8:25 AM
    winterboy04
    MA
    Well, i would most likely be going with the JL 8", but if you port it, you also have to increase the box volume...defeating the purpose of the small/hidden enclosure. I was even considering the new 6.5" inch JL sub as it only requires a TINY ported volume (i believe its .15 cubic feet)
    http://mobile.jlaudio.com/products_subs_enclusure.php?series_id=29
    I don't expect it to win any competitions, but i do want some lower end and i need to be able to use most of the space in the access cab. I'm not so worried about losing the center console room, but i DON'T want to replace the console all together with a custom built center console, simply pop a box IN it.
  6. Apr 2, 2010 at 8:25 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'd imagine if you have the towing package with the outlet in the bed that box is EXTRA impossible. That's where the power inverter is mounted.
  7. Apr 2, 2010 at 8:26 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Mike, what you should REALLY do is figure out how much airspace you have to work with and THEN choose your sub.
  8. Apr 2, 2010 at 8:29 AM
    winterboy04
    MA
    Well, i was looking through JL's install instructions, and they show how to get around it...but they are also pushing the sub out what looks like 6 inches...
    http://mobile.jlaudio.com/pdfs/13944.pdf
  9. Apr 2, 2010 at 8:43 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Ooooh, I didn't know it was an actual stealth box that JL made. That's pretty cool but it seems like you're compromising quite a bit with it. You lose all your center console space and you have to cut it up.
  10. Apr 2, 2010 at 8:45 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    they make some that go into the back doors.
  11. Apr 2, 2010 at 8:50 AM
    winterboy04
    MA
    They do, and i have been talkign to Mr. Marv a lot about that. He said he has even installed 8 inchers in the front doors, but those components run close to a grand themselves. The main hindrance for the door mounted subs is that they are still deep enough that i may have to cut the door plastic and you also need to seal the inside of each door to the point of turning them into a "sub box". i was really just hoping there would be a cost effective "JL-knockoff"...but i suppose if JL already did the legwork and that is the best they could come up with...i doubt i am going to get much better.
  12. Apr 2, 2010 at 3:43 PM
    mando
    mando New Member
    Just picked up a 2010 double cab, and just came across the jl stealthbox (with dual 10's). Anyone have anything good/bad to say about em? I know it's a bit on the expensive side, but was more curious as to it's performance capabilities....thanks in adavance
  13. Apr 4, 2010 at 11:55 PM
    taco06
    taco06 Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
  14. Apr 5, 2010 at 5:02 AM
    winterboy04
    MA
    I'm only looking for an option that lets me keep the jump seats folded DOWN so that i have the cargo area.
  15. Apr 5, 2010 at 5:22 AM
    taco06
    Alex
    pomona ,California
    06 sprt
  16. Apr 5, 2010 at 7:52 AM
    phd12volt
    phd12volt Well-Known Member
    So-Cal
    07 Tacoma Manual 2wd Access Cab 5-Lugger
    Homelink Mirror Autopage Alarm/Remote Start/C3 Tracking Alpine w505 w/P1 Nav
    you could do this, however your rear (full range) speaker would be gone. :D
  17. Apr 5, 2010 at 10:39 AM
    winterboy04
    MA
    And that would be absolutely perfect...but i somehow misplaced my winning lottery ticket....
  18. Apr 5, 2010 at 10:43 AM
    phd12volt
    So-Cal
    who knows, maybe ill get the itch to do it to mine, and make a couple extra ones??? where would be a good place to get these panels......Any idea?
