Home Made Bed Rail Mount Brackets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BudMan, Aug 23, 2013.
  1. Aug 23, 2013 at 8:39 PM
    BudMan
    BudMan [OP] knee scooters R us
    Bret
    Alameda, CA, (Bay Area)
    06 TRD Sport DC 4x4
    stuff
    So I got an AMAZING deal on a Bakflip G2. Only problem, no mounting hardware with it. I'm too impatient to order from Bakflip and spend many times more to wait for a longer install. Time to go to the hardware store. I needed a bolt head in the rail with the ability to hold itself in place for tightening.
    After a few fails with fitment and multiple trips to the store, I had success. I was trying to figure out how to seat a carriage bolt in the bed rail. Enter u-bolt top plates. Found a 3/8 plate that was a perfect fit in the rail. Bought 6 of em along with carriage bolts, nuts, and washers. Install at home only to find out 3/8 is too big for the Bak Rail Mounts, they won't fit. I knew the 5/16 top plate was too small. Defeated, I almost ordered $30+ in parts ready to wait out shipping.
    Then I realized I could seat the carriage bolt in 5/16 and hold the mount in the rail with a 3/8 top plate. Back to the hardware store. End result, success! I'm pretty sure you could also use this to mount shovels, hi-lift jacks, etc. All for less than $2 a pop.
    Now I just need a Pop-n-Lock to secure the bed. I've got some ideas how to improve security on the cover (so you can't open it with a coat hanger). Will Update when it happens.
    Borealis, AsadaTaco, rob1208 and 2 others like this.
  2. Aug 5, 2015 at 9:00 AM
    ngosselin
    ngosselin New Member
    Nicolas
    2023 Tacoma 4wd TRD-Offroad
    Budman, I know it has been a while since you posted the above information, but thanks for posting it, I was wondering what the size of the rail openings were, and this gives me the required information :)
    BudMan[OP] likes this.
  3. Apr 26, 2017 at 6:47 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  4. Apr 26, 2017 at 8:40 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    We'll just bump this every couple years.
  5. Apr 26, 2017 at 8:56 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    @T4RFTMFW Ah! I knew someone in Norcal had mentioned it. Thanks bromigo
