home made CAI is it possible?
Discussion in 'Performance and Tuning' started by kjf216, Dec 31, 2009.
  1. Jan 1, 2010 at 12:11 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    http://www.homedepot.com/Building-M...splay?langId=-1&storeId=10051&catalogId=10053
    can get something like this a cut some small holes so water would be able to get out. myabe in the tubing itself on the bottom or the backside of that triangle where it meets in the back.
    i know what i posted is expensive but there are cheap things similar to this out there
    http://plumbing.hardwarestore.com/51-600-dryer-vent-hoods.aspx
    iv been looking into doing something similar so i got a few idea as well haha just never got around to doing any of it, hopefully i will soon
  2. Jan 1, 2010 at 7:19 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    2016 Jeep Wrangler Sahara
    Head unit, speakers, LEDs
  3. Jan 4, 2010 at 12:59 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    so heres a rough sketch of what i was thinking of doing i plan to make a new box where the factory intake pulls air from the wheel well
    im going to make a box at the grill to collect the air and route it around the radiator support then back to the box on the wheel well, then to the factory filter box.
    i plan to have the new box on the wheel well take air from the wheel well and grill so does anyone have a pic of this area with the intake unbolted?
    i plan to make everything bolt on so that if i need to return the factory set up its easy. also do you guys think that by routing everything to a new wheel well box that this will solve the possibility of sucking water in from the grill? keep in mind i don't offroad and i will be making a cap so i can cap the grill house if i decide to offroad.
  4. Jan 4, 2010 at 1:47 PM
    08pretaco
    az
    I really like your idea man keep us posted on how it progresses!
    are you leaving the front of the box open there by the washer fluid reseviour or is it gonna be a closed box?
  5. Jan 5, 2010 at 12:19 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    since its bitter cold here this week, can someone see what diam the intake hose is at factory filter box and at the passenger wheel well. thanks.
    by the way diam must be from a 2nd gen 4.0 v6.
  6. Jan 5, 2010 at 12:21 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I might play with an idea to run a tube to grab air from around the exhaust manifold for warm air. I'm trying to warm my air up to get better MPG in the winter here...seen the idea over on some Hypermilers, my truck shits the bed on gas in the winter.
    I ran a AFE CAI, lost low end torque and 2 mpg, but gained some HP in the passing rpm...other than that mpg might have stayed flat while towing.
  7. Jan 6, 2010 at 12:12 PM
    kjf216
    kjf216 [OP] Fitz
    Kyle
    Ridley Park, PA
    sry over looked u post i plan to have a closed box, air will go in from tube to the front and from the wheel well
  8. Jan 19, 2010 at 4:27 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    I wouldn't burn too many calories trying to get "ram air" effects. The whole concept is a lot more marketing BS than it is measurable performance.
    My fluid dynamics is a little rusty, but ram compression comes from stagnatig moving air (relative to some solid object such as a truck), thus converting dynamic pressure into static pressure. Dynamic pressure is 1/2*air density*airspeed^2, and at 70 degrees at sea level, this comes out to 0.18 psi at 100 mph, maning you'll see less than a quarter pound of "boost" at 100 mph and that'll drop off parabolically rather than linearly (down to 0.05 psi at 55 and 0.01 psi at 25). If you know any mechanical or aerospace engineering majors, they can check my numbers on this.
  9. Jan 21, 2010 at 5:13 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Im thinking of doing something like this also and since I got a scangauge now I can keep track of intake temp's.
  10. Jan 21, 2010 at 8:16 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    MAF location is very important. if you get too much air turbulence from an incorrectly placed MAF sensor you can cause the engine to run wrong and even throw codes.
  11. Jun 7, 2010 at 5:25 PM
    jonml
    jonml Well-Known Member
    debadged ,grillcraft grill,blacked out headlights secondary filter removed,k&n filter,made a ram air tube to the airbox using 3 inch diameter flexible tubing ,sony reciever added ,rockford frosgate shallow mount sub added ,infinity component speakers added and powered by external amp,added cheap exhaust tip,added oem foglights,added helwig swaybar,shortened my antenna,dumped exhaust behind rear axel.
    ive done something very similar to that on my truck the difference with mine is i didn't cut any metal so its prob less direct i just routed mine from the airbox down by the radiator hose and bent it to up inside the bumper and made a scoop to catch the air
  12. Jul 11, 2013 at 12:59 PM
    Wolfman87
    Wolfman87 Member
    Forrest City AR
    2015 red DCSB TRD
    Backup camera anytime mod.
    I've been looking at doing this same thing. The wheel well is already a high pressure zone (the reason they put it there) the easyiest way to boost performance is use a larger hose coming out of the back of the box to the motor. The only thing you have to make sure of is the MAF sensor must be placed on a hose the same diameter as the stock.
    and yes I know this is a dead thread but oh well
  13. Jul 11, 2013 at 5:53 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Dead thread or not... the idea is still valid. :thumbsup:
    I've also been thinking of making my own home made box to enclose the filter on my aftermarket intake. ;)
