Home Made Gas Pump
Discussion in 'Off-Topic Discussion' started by Maticuno, Feb 22, 2012.
  1. Feb 22, 2012 at 5:57 PM
    Maticuno
    Maticuno [OP] Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I have one of these:
    The problem is the crappy pump handle and hose broke a long time ago. Even if it hadn't, it would have taken about 5 years to fuel up my truck one squeeze at a time. I replaced the line with rubber fuel hose and added a brass valve and fitting, but now this fuel caddy only works via gravity. That's fine if I'm fueling up my lawnmower, but if I wanted to top off my truck before a trail run that means I have to find something taller than my fuel door to sit this unit on. Loaded with a full 14 gallons of gas makes this a heavy beast to pick up that high.
    Most of the fuel transfer pumps that I see (both hand or electric powered) say they are only for diesel. The ones that say they are rated for gasoline are usually in the $300 range.
    One possible solution I've dreamed up is to rig a low pressure, high flow air pump to pressurize the top of the tank which in theory would force the gasoline out of the bottom fitting and through the hose into the vehicle. My concern with this is that I'm pretty sure this gas caddy was not meant to be a pressure vessel and I'm afraid of what would happen if 14 gallons of pressurized petroleum ruptured all over my garage.
    Any thoughts or other possible solutions?
  2. Feb 22, 2012 at 6:00 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I thought this said Home Made Gas Pimp.
    I was like "Waaaa?! Awesome."
    I'm am so disappointed...
  3. Feb 22, 2012 at 6:02 PM
    Maticuno
    2011 Suburban 2500
    Most people are when they see me coming.
  4. Feb 22, 2012 at 6:05 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    thats cool.
    the air idea sounds good.
  5. Feb 22, 2012 at 6:21 PM
    Maticuno
    2011 Suburban 2500
    While something I thought of, it needs to be portable. It already comes with hard plastic wheels which don't roll very well. I was thinking of buying a cheap dolly with pneumatic tires from Harbor Freight to strap the tank/pump/12V battery to. This would also give me the ability to ground any mechanical or electrical components I use to prevent static discharge.
  6. Feb 22, 2012 at 6:26 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    You could just siphon it.$2 for a hose long enough and possibly some gas in your mouth.
  7. Feb 22, 2012 at 6:56 PM
    Maticuno
    2011 Suburban 2500
    For a siphon to work the end point must be a lower elevation than the draw point which means I would still need to lift the gas caddy above the level of the fuel door.
  8. Feb 23, 2012 at 8:16 AM
    speedjunkie13
    speedjunkie13 Well-Known Member
    a work in progress
    What about a cheap inline fuel pump from a local auto parts store? I would imagine it wouldn't be too hard to mount it down by the petcock, you would just need to get creative with how to hook it up to the lines. Gravity would feed the pump and then it would push it out the hose. Also would probably need something to protect it slightly from getting damaged since it would be sticking off the caddy. unless you used some sort of quick connects.
  9. Feb 23, 2012 at 8:18 AM
    speedjunkie13
    a work in progress
    something like this for example.
  10. Feb 23, 2012 at 8:31 AM
    Maticuno
    2011 Suburban 2500
    An in-line fuel pump like a Walbro was another option I was considering. The drawback is the flow rate. Most of them max out in the 250L/Hr rate, which equals about 1GPM. That means it would take almost 15 minutes to empty the caddy.
