Homebrew - What do I have?
Discussion in 'Homebrewing' started by WildLand, Feb 2, 2016.
  1. Feb 2, 2016 at 7:03 PM
    WildLand
    WildLand [OP] Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    So with the stuff I have now, is this all the equipment I need for all grain brew? Is there different equipment for extract brew because I think that is where I want to start. I have a full schedule of classes and would like to do all grain someday when I can spend more time with it but would like to start simpler as of right now.
  2. Feb 2, 2016 at 7:05 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    What will you use for a fermentation vessel?
  3. Feb 2, 2016 at 7:06 PM
    WheelInTheSky
    G
    Jackson Hole
    Or is it straight up bottle conditioned all the way?
  4. Feb 2, 2016 at 7:07 PM
    mgw24
    mgw24 Well-Known Member
    Central Idaho
    2011 DCLB 4WD SR5, 1998 Reg cab 5 lug
    Crappy spacer lift w/AAL, Camburg Balljoint UCAs, Pioneer AVH-X2700BS
    Truth... The group I brew with tried to make a "American Lager" (smh..) to replicate a miller/bud/coors. No one got close. Very difficult.
    I make a jalepeno beer that everyone seems to like. It's probably the beer I've brewed the most. Despite taking detailed notes each time, and following my previous steps as close as possible, I have yet to be able to get it consistent batch to batch... It's never bad, but never the same...
  5. Feb 2, 2016 at 7:09 PM
    WheelInTheSky
    G
    Jackson Hole
    :)Such is the plight of the home brewer! Oh well, I guess you'll just have to keep drinking all that lovely, albeit inconsistent beer...:rolleyes:
    mgw24[QUOTED] likes this.
  6. Feb 2, 2016 at 7:11 PM
    mgw24
    Central Idaho
    You have everything you need there for Extract. Except maybe a chiller, I didn't see a chiller in the pics..
    The cool thing about brewing is you don't need the top of the line stuff to make good beer..
    WildLand[QUOTED][OP] likes this.
  7. Feb 2, 2016 at 7:12 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
  8. Feb 2, 2016 at 7:14 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Gonna need a 2.5+ gallon pot to boil in for extract, 6+ for all grain if you doing 5 gallon batch.
  9. Feb 2, 2016 at 7:15 PM
    mgw24
    Central Idaho
    You don't need to clean the mash tun or kettle really.. Well, get it clean, but it doesn't need to be sterile.
    As for fermenters, a glass carboy is easy to clean, but harder to handle (and can be dangerous if it breaks). I see a lot of people going with plastic better-bottles it seems. Check out northernbrewer.com.
  10. Feb 2, 2016 at 7:42 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Okay cool! I would like to buy minimal amount of things at the moment but if I buy the stuff now, I can really get into home brewing after college and get good at it! So I guess it would be a good investment to get my own things...
  11. Feb 2, 2016 at 7:46 PM
    WheelInTheSky
    G
    Jackson Hole
    Don't worry about having all your own equipment yet. It takes up space, and is a pain to move around. Just stick with the minimalist approach until you have your own place and plan to live there a while. Then you can start getting into a permanent setup using cut-open kegs for mash tun and boiler, get a proper fermentation vessel, copper heat exchanger, kegs and co2 tank.....
    For now, buckets n bottles my friend. Buckets and bottles:thumbsup:
    mgw24 likes this.
  12. Feb 3, 2016 at 4:55 AM
    imageomega
    imageomega Well-Known Member
    Jarrod
    I personally hate those plastic pressure valves you have (what you referred to as "two plastic things"). With a good ferment, they tend to blow off the top and cause a huge mess.
    Spend ~$10 at Lowes for ~4feet of tubing, a rubber stopper that fits your glass vessel and has a hole which fits the tubing, and run the tubing into an empty bottle full of water. Keeps it all air tight and if you get a good ferment going it wont blow the top off.
  13. Feb 7, 2016 at 2:31 PM
    Smashing
    Smashing Well-Known Member
    Rochesterish NY
    2017 DCLB Sport
    Good advise here. Take the cover off your airlock and the loose middle piece and stick the hose onto the stem in the middle. No need to buy another stopper
  14. Feb 7, 2016 at 2:46 PM
    Smashing
    Rochesterish NY
    2017 DCLB Sport
    I glanced quick but it looks like you have all of the gear except some sort chiller. Ice baths are probably your best bet first time out.
    I recommend all new brewers use a pre made ingredient kit. You don't need to worry about measuring and recipe creation at this point. A kit will give you a very good beer just by following the directions. You need to experience the process. Kits are available at your local brew shops(check the dates) or on line at good prices.
    Also get yourself a sanitizer. My general choice is starsan.
    Most of all have fun
  15. Feb 17, 2016 at 8:40 AM
    #35
    WildLand
    Josh
    NM
    16T4RSR54WD
    Thanks everyone! I ended up getting this kit http://www.amazon.com/Monster-Brew-...=UTF8&qid=1455727105&sr=8-6&keywords=beer+kit
    I figured that I will probably still want to brew after this class is over and might as well buy my own. Also the kit I am borrowing did not have lids for the containers, floating thermometer, sanitizer, and some other little things. When I went to the local homebrew store it cost my about $40 for all that and what was I going to do with all that stuff when I had to return the kit? Might as well buy my own.
    Gonna clean it today and start brewing as well!
  16. Feb 17, 2016 at 1:27 PM
    #36
    imageomega
    Jarrod
    :thumbsup:
    and in a few weeks.... :cheers:
  17. Feb 17, 2016 at 2:55 PM
    #37
    WheelInTheSky
    G
    Jackson Hole
    That's great man, I hope that you find brewing enjoyable and continue to brew for many years! I think you made a wise choice in getting an entry level kit that you can use and reuse. Maybe one day you'll go for a bigger brew setup, but for now you're golden.
    :cheers:
  18. May 25, 2016 at 6:27 AM
    #38
    BLKTRUCK
    BLKTRUCK Where’s @ODNAREM?
    The Privilege
    Find Ron
    ICON 2.5, ARB bumper, ICON 2.0 RR, Dakar leaf pack, Maxtrac spindles, Moto Metal wheels,
    How did it go? Did the beer taste good?
  19. May 25, 2016 at 10:43 PM
    #39
    WheelInTheSky
    G
    Jackson Hole
