Homelink garage door opener
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cruxx, Jan 2, 2020.
  1. Jan 2, 2020 at 7:20 PM
    cruxx
    cruxx [OP] Well-Known Member
    Huy
    2017 TRD Sport
    The homelink mirror opens the garage even when the truck is off. How easy is it to change it to an ignition source, so it only works when truck is on. Any issues with doing it this way?
  2. Jan 2, 2020 at 7:33 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    The factory wiring is to only work with ignition in on position. are you sure yours is wired by the factory and not some dealership / aftermarket wiring?
  3. Jan 2, 2020 at 7:37 PM
    FourWD
    FourWD Well-Known Member
    19 Tacoma DCSB OR TRD
    Thats weird. Mine works when the truck is ON but not OFF
  4. Jan 2, 2020 at 7:49 PM
    calebc
    calebc Well-Known Member
    Factory provides an ignition and a constant hot wire. In most vehicles, homelink is the same way and works with ignition on or off. The only one I’m aware of that’s not this way are Jeeps due to being able to remove their tops.
    It’s not hard to make it so it only works when on. You need to make a new harness that takes the ignition on wire and splits that to both pins on the mirror. Or hit up Bob in this thread https://www.tacomaworld.com/threads/updated-12-28-19-gentex-mirrors-w-homelink%C2%AE-blue-compass-backlit-buttons-for-2016-20-tacoma.550584/ and just buy a harness from him. No downsides to doing this. Mine didn’t come with a constant hot wire so I had to wire mine this way to get homelink to work in my truck.
  5. Jan 2, 2020 at 7:53 PM
    kjttaco
    kjttaco Well-Known Member
    Ken
    NJ
    2020 Black Limited
    I like the fact that I can open my garage door before I start the truck
    wahoobie likes this.
  6. Jan 2, 2020 at 9:07 PM
    BadDogMax
    BadDogMax Well-Known Member
    IdahoLand
    2019 TRD Pro
    I’m pretty sure mine stops working a period of time after the truck is shut off, like the headlights do.
  7. Feb 4, 2020 at 7:32 PM
    CementTruck2020
    CementTruck2020 Member
    Calgary, AB, Canada
    2020 4X4 TRD Sport Premium
    Does anyone have the wiring diagram for the rear view mirror harness for a 2020 TRD Sport. Thinking to replace the constant 12v with a splitter from the ignition wire.
  8. Feb 4, 2020 at 8:02 PM
    calebc
    On the back of the mirror plug, the wire on the top row far left is ignition, the one 3 spaces to it’s right is ground, and the one on the bottom row 3 spaces from the left is the battery/constant hot wire. It's easy enough to test this with a simple voltmeter. If you want the harness, it's only $20 and can be bought from Bob's (you can get the mirror too, if you just want the harness, he has it) (https://www.tacomaworld.com/threads/updated-12-28-19-gentex-mirrors-w-homelink%C2%AE-blue-compass-backlit-buttons-for-2016-20-tacoma.550584)
