Homelink Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toglide, Jul 10, 2011.
  1. Jul 10, 2011 at 4:22 PM
    toglide
    toglide [OP] Member
    Ron
    Orange County, California
    09 long bed double cab 4x4
    homelink, USB ports
    Well it took me a little time but I finally installed the Homelink remote I got off Ebay.
    Mounting plate for the PC board and switches. This was just glued in place with epoxy.
    Here is the part # for the switches is used
    Mouser # 653-B3W-4005
    I reused the nice rubber buttons that came with the homelink unit and carefully cut the holes. This was the hardest part. I just took my time and did it right the first time.
    I used this link for wiring the new switches and just tapped into the map light wires for power.
    http://www.lieblweb.com/homelink.html
    TacoLou and Dj Suisav like this.
  2. Jul 10, 2011 at 5:51 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Great Job!!!!!!!
    Can you post a link here for the homelink that you purchasing on ebay?
  3. Jul 10, 2011 at 7:44 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Thats really clean. I don't see why Toyota doesn't put this in stock
    TacoLou and Parksareforever like this.
  4. Jul 10, 2011 at 8:19 PM
    myname150
    myname150 Well-Known Member
    I don't know about 09 and after...
    but in my 08, there's a compartment where the compass and temp would be and you could velcro in a garage opener there and push the button from outside the compartment.
  5. Jul 10, 2011 at 9:38 PM
    prae
    prae Well-Known Member
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    Bilstein 5100s, eibach springs, AAL, TRD anthracite FJC rims, PIAA Fogs, Pace-Edwards hard rolling tonneau
    wow! cleanest install i've seen to date. very nicely done.
  6. Jul 11, 2011 at 1:40 PM
    toglide
    toglide [OP] Member
    Ron
    homelink, USB ports
    Here is a picture of the homelink transmitter I got from EBay. There is two types rolling code and Non rolling code. The rolling code transmitter will do both so that's what I got. Just two wires. Positive and a negative.
    Also I put a few more pictures in my members gallery if your interested.
  7. Jul 11, 2011 at 3:52 PM
    prae
    Calgary, AB
    06 4x4 SR5 BSP DCLB
    does the seller offer these still? I'd be somewhat interested.
  8. Jul 11, 2011 at 4:47 PM
    Eurosport
    Eurosport Well-Known Member
    how much do you want to do mine for? :D i can mail in my piece
  9. Jul 11, 2011 at 6:10 PM
    toglide
    toglide [OP] Member
    Ron
    homelink, USB ports
    There is a few people that sell them on eBay. I just was looking for the best price.
    You could just go to the wrecking yard and pull one your self but I could tell you what car it was pulled from.
  10. Jul 11, 2011 at 6:20 PM
    toglide
    toglide [OP] Member
    Ron
    homelink, USB ports
    Just posted this so you guys could see how to do it yourself. But if you have any questions
    I'll be happy to help where I can.
  11. Jul 11, 2011 at 9:38 PM
    magmd
    magmd Active Member
    Wow...that is nice and clean. Thanks for posting. Definitely will go on my to do list!!
  12. Jul 19, 2011 at 12:17 AM
    Mitch
    Mitch
    Spokane, WA
    My 07 has that compartment also, but the homelink allows multiple doors
    TacoLou likes this.
  13. Sep 14, 2011 at 8:12 PM
    kngpyn
    kngpyn New Member
    Dean
    McKinleyville
    Greetings! I am new and this is my first post. I got my 11 Tacoma about 6 weeks ago and this is my first project. With the exception of replacing a taillight that somebody busted out and left for me to find on my own. Anyway, I digress. This is very cool and I am working on mine tonight. Console is out and on the workbench, board is cut and wires are ready to go, figured I should call it a night before I made I mistake cause I was tired. Thanks for the post, this is the best I have seen.
  14. Sep 15, 2011 at 9:42 AM
    toglide
    toglide [OP] Member
    Ron
    homelink, USB ports
    Glad you like it. I think if I was to do it again I would have put two remotes in and six buttons.
  15. Sep 15, 2011 at 3:10 PM
    kngpyn
    kngpyn New Member
    Dean
    McKinleyville
    I got a small red LED @ 3.5 volts and larger one @ 12 volts. I want to use the smaller one, what was the voltage rating on the one you used? I cant imagine it is putting 12 volts to that LED, but I could be wrong.
  16. Sep 16, 2011 at 6:32 AM
    toglide
    toglide [OP] Member
    Ron
    homelink, USB ports
    What I did was measure the voltage coming off of the original led and from what I remember it was about 3 volts.
  17. Sep 17, 2011 at 12:42 AM
    biborado
    biborado Well-Known Member
    Stephen
    San Diego, CA
    2010 TRD Off-Road 4x4
    I'm looking to do the same thing except using the homelink out of a 4runner. It looks like with a little modification, it would be a remove and replace deal...even down to using the existing plug. Anyone brave enough to try it out?
    Where I got the idea from: http://www.toyota-4runner.org/sale-t4r-items/94231-f-s-4th-gen-homelink-sunroof-console.html
    Disregard the sunroof switch, you can get the console without a sunroof switch unless you wanted to use it for something else (winch?)
    48117d1311698337-f-s-4th-gen-homelink-su_273c6349e24685c057f14f6e6f40226cbb2bef7b.jpg
    48118d1311698351-f-s-4th-gen-homelink-su_a2161b5eb7dc96325ea99bef7a9fdb541f20c751.jpg
    48119d1311698363-f-s-4th-gen-homelink-su_db8964c591dc7c9facfc76be48e12cba9f515f60.jpg
  18. Oct 24, 2012 at 8:48 PM
    rubenc87
    rubenc87 Cobra
    Texas
    2013 Tacoma DCSB 4x4
    DTRL,HID's, Redline Elite Hood Struts,IVD Coilovers and Rear Shocks W/ Ext. Res.,N-FAB Light Bar W/ KC Titanium Lights, Alcan AAL,Wet Okole's, URD T.C.A.I. M/T Classic Lock's BFG AT, Chrome TC UCA'S,TRD Exhaust, Bed Mat,Painted Roof Rack,Access LE,Weathertech's F&R,P&L Lock
    Good to know that Toyota is paying attention to what the Toyota owners are wanting.
  19. Jan 27, 2014 at 7:11 AM
    Taco John
    Taco John Well-Known Member
    Illinois
    4X4
    How did you cut the holes?
  20. Jan 27, 2014 at 7:34 AM
    toglide
    toglide [OP] Member
    Ron
    homelink, USB ports
    I used the home link remote holes as a template. Sand the back side of the home link remote cover flat. This makes a perfect template. Then tape it into place, mark holes with a scribe. Then carefully with a dremel tool cut the new holes in the toyota part. I would say this is the hardest part because this is the part that everyone is going to see and you only really get one shot at it. There is more pictures of the process in my profile.
    By the way my home link install is still working great!
