Homelink Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BobSaget916, Jan 19, 2010.
  1. Jan 19, 2010 at 8:27 PM
    BobSaget916
    BobSaget916 [OP] Active Member
    Seth
    Lafayette, LA
    06 Access Cab PreRunner 4-cyl MT
    Volant CAI Magnaflow Cat-Back HID's 6000k bi-xenon Fog Light Kit mod w/6000k HID's Tinted Tail Lights Kicker CVR 10'' Sub in Super Crew Sound Sub Box Alpine MRP-350 Monoblock Amp Pioneer Premier Head Unit JL 6x9's up front 6.5's in the back Tweets up front Mud Flap Delete 5 over 20% Tint in the back, 20% on the front, 35% on the WS EGR In-Channel Wind Guards Coming Soon -Doug Thorley Headers -Color-Matched Front and Rear Bumpers, Overfenders, Mirrors, Door handles, and Grille -Billet Grille or Mesh Grille -Bilstien 5100's front and rear -OME Coilover Springs -Rear Add-a-Leaf -33's after suspension work is done -TRD Skidplate
    Hey guys, I want to add a Homelink mirror in my taco. I have an 06 base prerunner. I know i can tie in to the existing wires used to power the reading lamps, but i'm not sure if they are always hot. I dont want the temp gauge and compass to always stay lit up on the new mirror. If i had the overhead console with the temp gauge and compass i could use the wires from that but my truck probably isnt prewirred for that either. Any comments? Concerns?
  2. Jan 19, 2010 at 11:06 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The mirror I installed is just the homelink & auto-dimming. I already have the overhead console. We wired the homelink to the map lights for constant power. We wired the auto-dimming to the compass/temp power (goes out with ignition). Ground was attached to the support piece for the overhead console.
    I personally can't comment on whether you have wires for the overhead console or not.....
    You just gotta find a power source that's always live (for homelink) and goes off with ignition (for temp/compass). That usually involves using a voltmeter and testing wiring for current and/or utilize the fuse box.
  3. Jan 20, 2010 at 8:07 PM
    BobSaget916
    Seth
    Lafayette, LA
    Yeah I dont want the whole mirror to run hot all the time, it's just going to drain my battery. Anyone have this same issue?
  4. Jan 20, 2010 at 8:15 PM
    Janster
    Jandy
    Lancaster, PA
    You want the homelink to be HOT all the time, or else you won't be able to open the garage door unless you turn the truck on. The homelink won't draw any power unless you press the button.
    Everything else...the compass and whatever, can be ignition power and only be HOT when the truck is on.
  5. Jan 20, 2010 at 8:22 PM
    deer slayer 11
    deer slayer 11 Well-Known Member
    jay
    st.louis mo
    tacomo
    I got one from the junkyard and installed it.:laser:
  6. Jan 20, 2010 at 9:06 PM
    BobSaget916
    Seth
    Lafayette, LA
    I understand that the homelink must be hot but the compass and temp need to be ignition powered but idk where to tap into for that.
  7. Jan 20, 2010 at 10:35 PM
    Janster
    Jandy
    Lancaster, PA
    Anywhere that has ignition power. You could run wires directly to the fuse box in the cab. Use a voltemeter (?) to test the empty slots (or used slots) for current while ignition is on/off. Then - you could use something like this (Add-a-Line) to connect to it.
    This is what I used for my heated drivers seat.
  8. Jan 21, 2010 at 7:36 AM
    deer slayer 11
    jay
    st.louis mo
    tacomo
    :wave: I hooked mine up to my map lights.
  9. Jan 21, 2010 at 7:57 AM
    Janster
    Jandy
    Lancaster, PA
    He doesn't have an overhead console - so I doubt he has map lights.
  10. Jan 22, 2010 at 12:40 PM
    jimker55
    jimker55 Well-Known Member
    Jim
    Scottsdale, AZ
    2007 Taco
    Hey Deerslayer, thats not specific for Toyota is it? My guess is that anyone will work, right?
  11. Jan 22, 2010 at 4:04 PM
    Janster
    Jandy
    Lancaster, PA
    You can also get them on ebay also - I bought mine on ebay.
    In terms of auto dimming & homelink - as long as its just power & you have instructions how to setup the homelink, you should be good.
    In reference to a compass & temperature.... as long as you have the proper sensors installed and those sensors will hook-up to the mirror you buy.
  12. Jan 22, 2010 at 6:45 PM
    deer slayer 11
    jay
    st.louis mo
    tacomo
    you can do it on any car you just need power to it.:D
  13. Jan 26, 2010 at 10:11 AM
    jimker55
    Jim
    Scottsdale, AZ
    2007 Taco
  14. Jan 26, 2010 at 10:56 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  15. Feb 16, 2010 at 5:51 PM
    sweetbaboo
    sweetbaboo Well-Known Member
    Northeast
    2020 Black TRD Pro MT
  16. Feb 16, 2010 at 5:56 PM
    deer slayer 11
    jay
    st.louis mo
    tacomo
    Thats it. I got mine at the junk yard $5.
  17. Feb 16, 2010 at 6:44 PM
    sweetbaboo
    Northeast
    wow, i need to check my local junkyard first
    thanks
  18. Feb 16, 2010 at 8:12 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    Or you can mount it behind the visor.
    This way it isn't oriented backwards, not that it really matters.
  19. Feb 17, 2010 at 4:05 AM
    Janster
    Jandy
    Lancaster, PA
  20. Feb 17, 2010 at 7:31 AM
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    To the OP...
    Have you checked to see if you're pre-wired for the compass/temp console? My 05 SR5 PreRunner has the wiring already there. Take off your console and see if there's an extra harness there. If so, use that for the temp/compass and then the map lights for the homelink.
