Homelink Mod to turn off with key
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mav44, Feb 8, 2012.
  1. Feb 8, 2012 at 5:08 PM
    Mav44
    Mav44 [OP] Well-Known Member
    Does anyone know of an easy mod to turn the homelink system off when the key is out? I would hate to have someone break into my truck but things could go really bad if they hit the homelink and had access to everything in the garage. I cannot believe the button still works with the key out.
  2. Mar 30, 2012 at 3:45 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Regular garage door openers work with the key out of the truck. No difference.
  3. Mar 30, 2012 at 4:17 PM
    brny67
    brny67 Well-Known Member
    Bill
    Moyock NC
    08 TRD Sport A/C
    mine turns off when I turn my veh off, I will look at my instructions 2morrow and give u a heads up on how 2 do it
  4. Mar 30, 2012 at 4:47 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya, any factory system I've seen is hot 24/7.
    When I installed the homelink in my Silverado, I wired it to the overhead console lighting.
    It automatically powered down 15 minutes after shutting the engine off.
  5. Mar 31, 2012 at 8:28 AM
    LBS4
    LBS4 Member
    LB
    Ocean City, MD
    Tacoma TRD Sport
    Bump - anyone have an answer on how to disable the Homelink when the ignition is off in my 2012?
    I'm going to the dealer for service late next week & I will ask but figured someone here would have a solution.
  6. Mar 31, 2012 at 11:30 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Dealer won't do such a modification... you'd have to find an independent shop to do it for you.
    But your answer is above.
    Find the "radio" fuse, install an "add-a-circuit" to tap power from there, run that wire to the overhead console, disconnect power from the Homelink and replace it with your new power lead.
    Nobody can be of any more help than that without being there.
  7. Mar 31, 2012 at 11:34 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I don't have Homelink, and not sure how it works, but if power was killed to it when truck was off, would it forget the signal that was programmed into it? Or is it set with the little switches such as a remote foe a garage door opener?
  8. Mar 31, 2012 at 11:40 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I installed Toyota units in my '03 Tundra, '04 Rav4, and '06 Silverado and the programming is apparently stored in NVRAM... I never had a problem with them losing memory when powered down or with the battery removed.
  9. Mar 31, 2012 at 11:44 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Got ya, thanks. Mmaybe some type of hidden kill switch would work out then
  10. Mar 31, 2012 at 11:58 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Alternatively, install a relay inline with the existing power to the homelink unit. Then use the add a circuit to power the relay's coil. Same effect, but stays closer to factory that way.
  11. Mar 31, 2012 at 12:41 PM
    brny67
    Bill
    Moyock NC
    08 TRD Sport A/C
    if i remember correctly there is a constant hot and a hot with ignition on I hooked mine directly to the ignition on, do not remember which wire is which, will have to take the map lites down and check, will try to do this within a few days.
  12. Mar 31, 2012 at 2:55 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I strongly suspect that the Homelink is powered from the dome/map light hot... there's not likely to be a separate power feed for it from the kick panel.
    Might be a bit crowded up there to add a relay, and it would certainly get busy adding 2-4 more wires to control the relay when all that is needed is a single switched hot.
    When there are two or more options, take the simplest. Relays can fail. We already have enough of them, why add more? ;)
  13. Mar 31, 2012 at 11:26 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yeah, the relay is too much work if that's the way it's setup.
  14. Mar 13, 2013 at 4:30 PM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    Are there any updates to this? I was wondering if it would be possible to rewire the whole mirror to a switched power source.
