HomeLink
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gasgasman, Oct 5, 2012.
  1. Oct 9, 2012 at 8:17 AM
    Bengaliprince
    Bengaliprince Active Member
    B
    ATL
    PreRunner Sr5 TRD Sport Long Bed
    thats nice man....i need to do something like that to mine...great idea
  2. Dec 5, 2012 at 3:25 PM
    Sandy sangha
    Sandy sangha Member
    Sandy
    Vancouver
    08 Tacoma trd 4x4
    EXCELLENT JOB LOOKS REALLY GOOD CAN YOU PLEASE SEND ME SOME PICS OF WHAT MODS U DID TO SHIFTER COVER THANKS I AM GOING TO BE PUTTING MY HOMELINK THERE TOO
  3. Dec 5, 2012 at 3:31 PM
    Whiplash777
    Whiplash777 Well-Known Member
    Upstate NY
    '09 Blue Double Cab Off Road
    Side steps, DRLs, DynoLock
    Brilliant! I gotta do that to mine sometime.
    Added to my to-do list of mods. :-D
  4. Dec 8, 2012 at 2:45 PM
    gasgasman
    gasgasman [OP] Well-Known Member
    Sorry, no step by step pics.
    Not too difficult to install if you have the right tools.
    You basically have to cut out the opening for the HomeLink buttons.
    I took the rubber HomeLink button pad and layed it on the console, then drew around it to verify where to cut.
    Take a small drill bit and drill multiple holes along the out the cutout drawn on the console.
    You have to grind the ridges off the bottom of the center console so the HomeLink module will fit flat against the console. You will need to grind some material off the console to make it thinner so the button cover will snap on tight to the module.
    Run 12V power to the module and program.
  5. Dec 8, 2012 at 3:06 PM
    CIAGDDS
    CIAGDDS Well-Known Member
    Corona, Ca.
    05 4x4 TRD OR
    You can also do this with any garage door remote and a switch. I soldered my remote to a Carling Switch from OTRATTW. My garage door opener switch is the Trunk Monkey.
    In the past I have also hooked it up to my high beams so when you flash them it opens or closes.
