Homemade Crank Pulley Tool
Discussion in '1st Gen. Tacomas (1995-2004)' started by BadBrains, Feb 17, 2011.
  1. Feb 17, 2011 at 2:31 PM
    BadBrains
    BadBrains [OP] Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Here's the tool I made for around $20-$25 instead of purchasing the Schley SP 64400 for $60-$80.
    C-channel from the Depot, and 3/8" rod also from the Depot.
    I had to chase out the holes on my pulley due to rust, other than that it worked like a charm when I recently did my T-belt/Water-pump.
  2. Feb 17, 2011 at 3:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sweet. i made one as well......looks like the one from schley.......but the damn holes i drilled for pins didnt line up worth a shit. now..if i dont use it...i just lay a prybar against the frame with a socket on the crank nut and bump the engine over...breaks her loose real fast.:D
  3. Feb 17, 2011 at 3:48 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I made one as well, but out of scrap so it was free. I just welded two pieces of 1/4" flat stock together to make 1/2" thick steel, drilled holes in it for the drill bits, torched a big hole in the middle for the socket, and welded about 3' of 1/2" x 1" flat stock to that for a handle. Worked perfect.
  4. Feb 17, 2011 at 3:49 PM
    BadBrains
    AL
    That's how I broke it loose as well. I made the tool at the end when I was ready to put everything back together.
    Stuck the tool on and rotated it until it stopped against the frame, then torqued the pulley bolt.
  5. Feb 17, 2011 at 3:56 PM
    wired_af
    wired_af Well-Known Member
    Alex
    Colorado Springs, CO
    '07 DC TRD Sport S/C, Rivian R1T
    I made one too for my 2nd gen. This is the aftermath from torquing to 204ftlbs.
    Obviously, I should have used a stronger bolt :D
  6. Feb 17, 2011 at 4:10 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Wulf and Brie like this.
  7. Feb 23, 2011 at 11:07 AM
    Willman
    Willman Sierra Expeditions
    Nice work!
  8. Mar 31, 2011 at 12:16 AM
    bwill808
    bwill808 Active Member
    bryan
    hawaii
    00 extra cab 5lug trd supercharged
    trd supercharger the grey version , k&n intake , trd headers , 2 1/2 inch catback
    noticed ur in az or kailua????/?i just moved here from hawaii , i have no way to make a that tool , if ur near phenix if i could buy or borrow ,
  9. Apr 1, 2011 at 10:04 PM
    BadBrains
    AL
    From Kailua, but live in Northern AZ now....however I'm currently out in CA for a couple more months.
    Hopefully someone from the Phoenix area will see this and hook you up/ help you out.
  10. Nov 8, 2011 at 7:36 PM
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
    Just me being lazy and I don't Wana crawl under my truck at the moment, but what is the length of the 3/8 rod from the base to the tip?
  11. Nov 8, 2011 at 8:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    it doesn't matter, just make them around 4" to be safe.
  12. Nov 8, 2011 at 9:18 PM
    Gorillazrus
    01 Prerunner SR5
    Ok thanks, haven't had a chance to look it over but wanted to start getting my metal together.
  13. Nov 8, 2011 at 9:19 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    They just need to engage in the holes in the crank pulley, the one I made just uses drill bits stuck through holes in the tool.
  14. Nov 8, 2011 at 9:30 PM
    Gorillazrus
    01 Prerunner SR5
  15. Nov 9, 2011 at 1:56 PM
    BadBrains
    AL
    I'd measure them for you but the tool I made is in storage.
  16. Feb 14, 2012 at 7:27 PM
    Beluga
    Beluga Member
    Another technique that works is just screw in 2 bolts into the pulley at the same time so the pulley is level while the bolts push the pulley out as it hits the block. Pretty much the same way you take out rear drum cover with 2 bolts.
  17. Jun 27, 2012 at 10:38 AM
    TallTacoma
    TallTacoma Bear fvcker!
    Charles
    The Silver State
    Come and take it from my cold, dead hands.
    3" suspension lift (ToyTec coilovers and wheeler leafs), Yakima roof rack, ARE tonneau, K&N FIPK.
    That's how I did it. It's amazing how much torque those starters are putting out.
  18. Jun 27, 2012 at 9:32 PM
    The Raisin
    The Raisin Well-Known Member
    Mark
    Spanaway, WA
    streetqueen
    Badlands front bumper with a Smittybilt 8K winch, synthetic winch line. Demello sliders and bedbar. Custom rear bumper. Custom skid plates. Flex-a-lite tranny cooler with fan mounted in bed. Bilstein 5100's with SAW coils, AllPro UCAs, NW offroad rear springs (garbage), 4.88s and front and rear lockrights. Lots of custom sheetmetal work.
    I've done my water pump and timing belt twice now, both times i removed the crank pulley bolt with a pneumatic impact gun. It came right off both times.
  19. Jun 27, 2012 at 9:33 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    pulled the radiator out too?
  20. Jun 27, 2012 at 9:43 PM
    The Raisin
    Mark
    Spanaway, WA
    streetqueen
    Yes the radiator and the grill. So much easier to get it done that way. I just did the entire thing last Saturday, waterpump, t-belt and t-stat, pulleys and new t-belt tensioner as well. It took me and a buddy about 5 hours from start to finish.
