Homemade Grille idea. HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by oneBIGroom, Sep 14, 2011.
  1. Sep 14, 2011 at 6:02 PM
    oneBIGroom
    oneBIGroom [OP] SSS
    SSS
    SSS
    SSS
    SSS
    OK... im trying to make a homemade grille and ive gotten it cut. But i hade an idea :D i want to --->SOMEHOW<--- make a 1inch thick border around the edges of the grille. and then ill stick bolts through the front and nuts on the back to make it look like the RBP grille's border. but i cant decide how to make a border or what to make it out of. Does ANYONE have any idea of what to use or how to do it? Thanks for any help... and yes im going to paint it black. :rolleyes:
  2. Sep 14, 2011 at 6:16 PM
    johnnym
    johnnym Well-Known Member
    john
    NH
    87 4Runner Chevy 1500
    Sas 4.7tranfer case gears 5.29s Locked front/rear
    thin sheet metal
  3. Sep 14, 2011 at 6:18 PM
    oneBIGroom
    oneBIGroom [OP] SSS
    SSS
    SSS
    SSS
    SSS
    Only problem is bending it for the curved edges, do you think it'll bend to fit?
  4. Sep 14, 2011 at 6:20 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Fort Collins, Colorado
    bone stock / unmolested 04 2.7L
    Sawzall. No bending required. Just trace (I guess) the grill opening onto the sheet metal and have at it.
  5. Sep 14, 2011 at 6:33 PM
    oneBIGroom
    oneBIGroom [OP] SSS
    SSS
    SSS
    SSS
    SSS
    Good idea about tracing on the sheetmetal, but Sawzall's a little violent for trying to cut it precisely haha.
  6. Sep 14, 2011 at 6:40 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    The flat plastic that stereo installers use for mounting speakers to panels. Not sure what the name of it
  7. Sep 14, 2011 at 7:56 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
  8. Sep 14, 2011 at 8:04 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    you could fab it from a sheet of ABS Plastic & then heat weld it to the mesh.
    that would be the easiest & most cost effective IMO.
    I precision sheet metal shop could make you just about anything you want but your talking serious $$$
    I'm not wild about the look of that grill so I haven't attempted a replica.
    I'll take a whack at a 01-04 satoshi here myself soon.
    Best of luck!
  9. Sep 14, 2011 at 8:42 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Dremel.
  10. Oct 4, 2012 at 7:50 AM
    Tacoma9396jrc
    Tacoma9396jrc Well-Known Member
    Jacob
    South Carolina
    96 4x4 tacoma 4 cyl
    Cherry Bomb exhaust, 3" suspension lift
    I built one similar to an rbp grille, actually still in the process. Used a sawzaw and a bench grinder youll just have to do some welding. Id like to see pics of yours if you ever got one made
