HomerTaco Grill Install
Discussion in 'HomerTaco' started by canyonchaser, Apr 19, 2012.
  1. Apr 19, 2012 at 1:50 PM
    canyonchaser
    canyonchaser [OP] Member Known Well
    Dave
    Utah
    LR TRD PRO MT
    I hadn't seen one of these so, as my new grill arrived, I thought I'd document the process for all to enjoy.
    Look! The new grill! It's very brown and square;
    Out of the box, this is a thin lip M4
    Here's my truck before I started
    As soon as you open the hood you'll notice these two clips on either ends of the grill.
    Simply use a small flat-head screwdriver and slide it under the smaller of the two heads - It should pop right open. If it's stubborn you may need to slightly twist.
    Open - Now simply, and carefully pull the entire plastic faster directly up and out.
    Next, undo the two 10mm bolts. Careful, they are just threaded into plastic. When it's time to put thing back together be VERY careful not to over-tighten these.
    At this point, the grill will be feel like it wants to come out, but there are two more fasteners - down on the actual headlight body.
    Deliberate but careful force will release them. They hook into the headlight. My right one came out immediately, the left one took some negotiation.
    The old grill will lift up and out of the truck - leaving you with this view. You'll notice the bare aluminum sides to the radiator/cooler as well as those unsightly horns.IMG_1954_821fa1367eab2c79f665b22c895c49e8eb49fa1d.jpg
    Most people will want to relocate the horns. This too is quite simple. Start by removing the plastic radiator cover. It uses the exact same clips used by the grill.
    Removed:
    Unplug and remove the two horns using a 12mm socket and set them aside. The cable is routed underneath the radiator sub-frame. The cable's held in place with these black clips.
    Simply squeeze them and they will release;
    You'll also need to free this little sensor.
    Works exactly the same way as the other clips;
    The horn wiring should now free for you to relocate it
    I went around through one of the small ports near the bottom of the left headlight. This gives you lots of extra cable to work with.
    You can almost see the port I used.
    I ran the cable along the lower brace of the radiator sub-frame. there is a suitable existing hole for the sensor clip to snap back into right next to the right radiator lower mount (the black thingie in the corner of the photo).
    To reattach the horns, you'll need some nice giant fender washers and some lock-nuts. I just happened to have these on hand.
    I chose the two center most oval holes and placed the horn towards the center. You can see my fender washer on the back side of the radiator sub-frame.
    This places the horns immediately behind the lower grill. (only one horn fit here).
    Another image of the new horn placement. I used a couple of long zip-ties to fasten the horn wires to the lower radiator sub-frame.
    Now time to paint. I cleaned up the aluminum bits and sprayed them with some satin black heat paint. Not overly concerned as it's mostly to obscure stuff. It doesn't need to look perfect.
    You insert the new grill from the top down and gently press the clips into the headlight (the HomerTashi grill comes with new clips - no need to remove them from your old grill).
    All done.
    Because nobody seems to mention. I chose the thin lip, M4.
    From the right now...
    The end result
    Good luck!
    dp
  2. Apr 19, 2012 at 2:16 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    +1
    great job! Thank you! :thumbsup:
  3. Apr 19, 2012 at 2:59 PM
    canoeski
    canoeski Well-Known Member
    Bill
    Southcentral Wisc
    2012 Tacoma AccessCab
    Debadged. ARE Topper. Tailgate mods, including locking handle. BAMF LCA skids.
    Nice job there Dave!!
    I loved the pics and thorough explanation.
    Just one question:
    What is that "little sensor thing"?
    Is it a thermometer, and will changing the location affect the readings?
    Or if it were some sort of position sensor or part of the air bag system, would relocating it or changing it's orientation affect it's function?
    ~bill
  4. Apr 19, 2012 at 3:02 PM
    AbunaiXR
    AbunaiXR Active Member
    Hawaii
    05 SWB Xrunner
    that looks tight!!
  5. Apr 19, 2012 at 3:04 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    It is the temp sensor for the overhead outside temp gauge I've been told.
    I personally left mine there bu I did relo the horns.
    Sir4taye likes this.
  6. Apr 19, 2012 at 3:05 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Nice write uP + 1 for you
  7. Apr 19, 2012 at 11:28 PM
    Tbaytaco
    Tbaytaco Well-Known Member
    Nolan
    Thunder bay
    O6 TRD sport
    quick question. When painting the rad do you need to clean it well or just wash and spray away?
  8. Apr 20, 2012 at 1:10 AM
    canoeski
    Bill
    Southcentral Wisc
    Thanks Homer.
    How are the grills for the 2012's coming?:rolleyes:
  9. Apr 20, 2012 at 4:15 AM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    Sweet write up
  10. Apr 20, 2012 at 4:31 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    clean any dirt off it, but don't have to go crazy...
    or
    just spray away... :D
  11. Apr 20, 2012 at 7:24 AM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    Yeah, I just did a quick wipe with a degreaser to get most of the shmutz off. It's not uber critical. If it starts to look shabby, you can just pull the grill and respray.
    dp
  12. Apr 20, 2012 at 7:29 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Now you should show how you remove that sexy grille, repackage it, and send it to me :D
  13. Apr 20, 2012 at 8:45 PM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I just can't wait till I get mine. I'm 24 on the list then I'll def be referring to this to see where to relocate the horn
  14. Apr 20, 2012 at 8:56 PM
    sernaj64
    sernaj64 Aight
    Juan
    honolulu
    2011 prerunner V6 SR5
    N fab Step bars BHLM by Asianants Pro Comp 2.25" level lift kit rear leaf TSB
    ditto^^^^
  15. May 22, 2012 at 10:33 AM
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Hey guys,
    Was wondering how you place an order with Homer. I have a silver Taco myself and would like to order this same grill. Just looks Tits & Tacos!!!! Also, what's the cost????
    Thnx,
    Eppy
  16. May 22, 2012 at 10:34 AM
    Aw9d
    Aw9d That one guy
    Looks good! Great write up!
  17. Jun 17, 2012 at 7:27 PM
    darktaco
    darktaco Active Member
    N.E. , Pa...U.S.A.
    08/Sport
    scangauge/c.b.-cobra 29/ BO chrome badges/Demello bolt on sliders/rcbs 4x4 led mod/rear tsb / relocated trailer plug to plate light hole/ Toytec U.L.K./L.R. UCA's/AFE-pro-dry air filter/LEDS -plate,dome,map lites /rear diff breather/ImMrYo's mirror lift/redline hood lift,
    Looks good !
    Great step by step.
    I like the thin lip over the satoshi . Do you plan to leave it neckid or put/paint any type of toyota emblem on ?
  18. Jun 18, 2012 at 6:41 AM
    canyonchaser
    Dave
    Utah
    LR TRD PRO MT
    Thank you!
    I think I really want to put an old FJ40 toyota badge on it.
    But it's summer, so I haven't gotten around to it yet. :)
    dp
  19. Jun 18, 2012 at 7:41 AM
    Mr. LaBeef
    Mr. LaBeef Well-Known Member
    Grayson, GA
    PreRunner TRD Sport
    Looks good. I'm getting mine soon and Ive seen a lot of people relocate their horns there. In getting the lower grill as well and didn't want to put them there. I have tried searching but couldn't find a different spot that isn't behind the grills.
  20. Jun 18, 2012 at 10:40 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Mine are now back on the drivers side behind the fuse box... There are two threaded holes ready to go back there... :D
