HomerTaco's big old bucket o’ bolts build
Discussion in '2nd Gen. Builds (2005-2015)' started by HomerTaco, Jan 1, 2011.
  1. Aug 29, 2015 at 7:29 AM
    #2141
    MTgirl
    Weesa
    Bob's secret mod lair
    :notsure:
  2. Aug 29, 2015 at 7:56 AM
    #2142
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    1F9F9700-DBA2-49C3-BE2D-50D4483CB63C_zps_aa91428ed267dde5ab44a8046e4811f8390b8cd9.jpg
    Maybe this is the turtle mod he was talking about?
    hoverlover and PSU Taco85 like this.
  3. Aug 29, 2015 at 10:22 AM
    #2143
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
  4. Aug 29, 2015 at 6:17 PM
    #2144
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    When I swapped the front end one of the things I neglected to to was re fasten the hood struts. At the time I didn't have a rivet gun so I just drilled out the hardware & saved it.
    Today I took the time to reinstall the hardware and since I was under there anyway I finally installed the anti-dark hood lighting kit.
    Suckers pretty bright and was crazy simple to hook up.
    AR15xAR10 and LiveFreeOrDie2015 like this.
  5. Aug 29, 2015 at 6:55 PM
    #2145
    LiveFreeOrDie2015
    LiveFreeOrDie2015 Well-Known Member
    York PA
    15 DCSB TRD OFFROAD
    3in lift,Fox suspension,chaos UCA,AAL,leer 180 topper,SilverStar zXe headlights & fog lights,BAMF kickout sliders,Mobtown full skids,Pelfreybuilt center hoop, Pelfreybuilt Gas Tank Skid,50" curved LED light bar, Hood scoop LED, Tran cooler and fan,Oil Catch can,LED Strip lights under hood & Bed,
    Looks good .....I found the rivets 20mins after you left.:facepalm:
  6. Aug 29, 2015 at 7:01 PM
    #2146
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :laughing:
    Never fails - always find what you're looking for after you don't need it anymore. :p
  7. Aug 29, 2015 at 7:09 PM
    #2147
    LiveFreeOrDie2015
    York PA
    15 DCSB TRD OFFROAD
    Did you ever give any thought on relocating the Remote reservoirs on the 2.0 rear shocks? I was under the truck today installing wire for my popalock and it looks like a rock could smash the shit out of them.
    Didn't know if you or anyone else had any problems.
  8. Aug 29, 2015 at 8:27 PM
    #2148
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'm still running the billy 5100 B-110's on the rear in the stock locations.
    Not a problem I've got. :oops:
    I'd eventually like to follow in Ant's footsteps and do an inboard /\ setup.:cool:
    Bsheriff11 likes this.
  9. Aug 30, 2015 at 7:30 PM
    #2149
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Parked in the sun and took off all the die cut vinyl today. Time for a change.
    jrzyshore and dakotasyota like this.
  10. Sep 1, 2015 at 10:00 PM
    #2150
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Looks like an offroader's hearse with all that black....
    And it STILLLLLL needs a retrofit.
    dakotasyota likes this.
  11. Sep 1, 2015 at 11:05 PM
    #2151
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
  12. Sep 2, 2015 at 2:48 PM
    #2152
    scocar
    scocar Patron of the Farts
    Hey Craig, I just realized you have a Leer XQ and an RTT setup. Is that mounted on the Thule racks? Any issues with the RTT weight on the Leer? No strees cracks/fractures or other issues? This is exactly the setup I am considering for my '15. I just found a used XQ in pristine condition with the Thule rack for a screaming deal (except the wrong color, but I'll have it color-matched).
  13. Sep 2, 2015 at 3:35 PM
    #2153
    MTgirl
    Weesa
    I think Homie has prinsu racks
  14. Sep 2, 2015 at 3:41 PM
    #2154
    scocar
    I think you are right. I just dug a bit deeper and saw those earlier posts. I've wanted to put on RTT (that I don't need yet) on a cap (that I don't have yet), and I've been agonizing over cap rooftop load capacities for these long-term plans. Mom and dad in the teardrop, kid(s) in the RTT (once they can deal with it safely).
    Although his XQ is a short bed, which is likely stronger because of the reduced span between front and back cap pillars, and mine would be a long bed. But this is encouraging.
  15. Sep 2, 2015 at 3:43 PM
    #2155
    ArcherTaco
    ArcherTaco Well-Known Member
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    Toy-Tec Kit, Tool box fit to bed, Dipped badges, cab lights, running boards, Flowmaster exhaust
    Wait this is a problem?? damn...
  16. Sep 2, 2015 at 4:04 PM
    #2156
    AR15xAR10
    Someone has to poke the bear :boink:
  17. Sep 2, 2015 at 4:05 PM
    #2157
    ArcherTaco
    Riley
    Greeley/Windsor, CO
    '13 DCLB TRD Sport
    hold my beer and watch this... :drunk:
  18. Sep 2, 2015 at 6:04 PM
    #2158
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Zero issues with the setup. The PrInSu caprac is mounted to the factory Thule rails and is a stronger setup than the standard cross rails. I used the Thule cross bars with the RTT for quite a while though. I like the Caprac better because the tent sits lower on the cap and it offers a ton of adjustment & mounting options. :thumbsup:
  19. Sep 2, 2015 at 6:14 PM
    #2159
    scocar
    Perfect, thanks, Craig. I was wondering if you ever used the Thule rails, and I can see using those for trips to...your place of employment:D
    Likewise, I was concerned about height for the sake of aerodynamics/drag and also garage clearance. I have been looking at Prinsus and finally saw one in person the other day in front of....your place of employment o_O Impressive piece of hardware.
    But I'm bone stock on the 15, and a cap, suspension, and tires are a wee bit higher on the list.
    So where's my 2015 Homersoshi? Silver Sky Metallic, remember? I think I've been very patient.
  20. Sep 2, 2015 at 6:21 PM
    #2160
    MTgirl
    Weesa
    I thought you were going to give me the teardrop and get some oversized, family friendly RV with bunk beds?
