HomerTaco's big old bucket o’ bolts build
Discussion in '2nd Gen. Builds (2005-2015)' started by HomerTaco, Jan 1, 2011.
  1. Mar 15, 2016 at 1:32 PM
    #2841
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Fought me a bit but I'll call it done. :yay:
  2. Mar 15, 2016 at 1:34 PM
    #2842
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    Did you have to relocate the stock shifter at all? That looks sweet and now I want one!
  3. Mar 15, 2016 at 1:34 PM
    #2843
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
  4. Mar 15, 2016 at 1:37 PM
    #2844
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    the hurst/core shifter allows the ability to move the trans stick side to side by fastening it on either side of the housing. It was not intended to be used this way but it suited my needs for this application.
  5. Mar 15, 2016 at 1:38 PM
    #2845
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
  6. Mar 15, 2016 at 1:39 PM
    #2846
    SMKYTXN
    Nathan
    Houston
    DCFB
    I'll let you know when I get the fifth stick mod complete Craig. You can never have enough sticks. :D
  7. Mar 15, 2016 at 1:42 PM
    #2847
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I read the throttle stick posts... Not sure that would really be needed with the crawler - I actually spent most of the time in 2nd gear with the crawler engaged & hardly touched the clutch all day...
    2ndGenJonny and Blackout14 like this.
  8. Mar 15, 2016 at 1:45 PM
    #2848
    SMKYTXN
    Nathan
    Houston
    DCFB
    Right, for the most part you won't need it. But I'm assuming you didn't get yourself in a position where you had to stop on a steep hill with an obstacle in front of you?
  9. Mar 15, 2016 at 1:48 PM
    #2849
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    No, but let's say you are in that situation and stalled. Throw the truck in 1st gear and compound low, push the clutch start cancel & turn the key. No clutch needed and you can throttle all you want. :cool:
    Torspd likes this.
  10. Mar 15, 2016 at 1:51 PM
    #2850
    SMKYTXN
    Nathan
    Houston
    DCFB
    Quit raining on my parade Craig!
    That's a valid idea for the situation, but if you're still running you'd have to shut off the engine for that maneuver. I still want my fifth stick! :D
    Blackout14 likes this.
  11. Mar 15, 2016 at 2:01 PM
    #2851
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Looks great! (although I always knew it would)
    HomerTaco[OP] and Blackout14 like this.
  12. Mar 15, 2016 at 2:14 PM
    #2852
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Thanks Mark - you're one of the few folks who knew what I had in mind from day one. Took a few years but it's finally there! :D
  13. Mar 15, 2016 at 2:33 PM
    #2853
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    about time this thing is back in shape. You beat me to getting the shifter boots inside made LOL, i still use that area for a trash can on road trips it is hidden space #lazyinnovation
  14. Mar 15, 2016 at 3:18 PM
    #2854
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It certainly does look professional. Hands down.
  15. Mar 15, 2016 at 6:05 PM
    #2855
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Gotta keep em' guessin. :cool:
  16. Mar 15, 2016 at 6:21 PM
    #2856
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :laughing:
  17. Mar 15, 2016 at 6:22 PM
    #2857
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Going to throw this on tomorrow with the tent & see how I like it:
    ChadsPride and Blackout14 like this.
  18. Mar 15, 2016 at 6:24 PM
    #2858
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    let mr know if u need help with the tent.
    Blackout14 and HomerTaco[OP] like this.
  19. Mar 15, 2016 at 6:25 PM
    #2859
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Thx Jerry - I've got it down to a system now. Actually pretty easy to get it on solo. I appreciate the offer though! :thumbsup:
  20. Mar 16, 2016 at 5:52 AM
    #2860
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Not to hijack the thread or anything, but since all the right people are in here, does anyone have a stock FJ shifter laying around that they'd sell. My case didn't come with one.
    BTW is there an official crawlbox thread?
