HomerTaco's big old bucket o’ bolts build
Discussion in '2nd Gen. Builds (2005-2015)' started by HomerTaco, Jan 1, 2011.
  1. May 25, 2016 at 8:43 PM
    #3061
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    On the plus side, the shower is installed and functions perfectly! :rolleyes:
    Going to sleep on this wheel thing... I'm not in the right frame of mind at this moment. -_-
    Crom, AR15xAR10, Littles and 2 others like this.
  2. May 26, 2016 at 1:14 AM
    #3062
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    Shit! Glad your okay man.... Anthony's right déjà vu. Gonna go check my damn lug nuts
  3. May 26, 2016 at 4:11 AM
    #3063
    P2W
    P2W Whut?
    Whodatsville
    '13 Tacoma DCLB
    Somstuff
    Wholly crap!
    and that's alls I got ta say on that
  4. May 26, 2016 at 7:30 AM
    #3064
    cynicalrider
    cynicalrider #NFG
    Jersey
    Holy shit glad you are okay Craig. We were just talking about that weren't we? I thought you fixed the stud issue?
  5. May 26, 2016 at 9:06 AM
    #3065
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    So did I. :(
  6. May 26, 2016 at 9:12 AM
    #3066
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Is your rear shock still blown too??
  7. May 26, 2016 at 11:54 AM
    #3067
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To repeat what Nathan asked, how did the wheel come off?
    How much engagement on the studs is there currently?
    With my aftermarket wheels, I was only getting a small portion of the threads, since my wheels are thicker than OEM. Always was scared that it wasn't enough bite.
    That is why I swapped to the ARP studs.
    http://www.xr-underground.com/forum/showthread.php?t=41398
    I am using the Celica GTS studs. They are not cheap. They are also not as long as the Lexus Studs. As well as having a longer knurled section, which presses into the hub.
    I have no personal experience with the EVO studs.
    Ugly Betty likes this.
  8. May 26, 2016 at 1:43 PM
    #3068
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I wish I had a solid answer for why it came off - could be several different reasons.
    Not sure what I'm doing here yet. Have a lot to think about...
  9. May 26, 2016 at 2:35 PM
    #3069
    MTgirl
    Weesa
    Bob's secret mod lair
    If this is a solo mission I'd say call off the trip. Its one thing to have major breakdown close to home, another to have it happen half way across the country. And I know you like to drive nonstop which could mean if something did happen you'd be tired and maybe not react as quickly or clearly as you did in this instance.
    Torspd likes this.
  10. May 26, 2016 at 3:12 PM
    #3070
    sander1036
    Sadly, I agree with Lisa. :pout:
    I wouldn't go back out to Moab unless I had others with me the entire way. Especially after URE.
    MTgirl[QUOTED] likes this.
  11. May 26, 2016 at 6:22 PM
    #3071
    sander1036
    Anthony was two or three studs away from losing a wheel on a major highway
  12. May 26, 2016 at 6:36 PM
    #3072
    cynicalrider
    cynicalrider #NFG
    Jersey
    I'd ride out with you if I could dude.
  13. May 26, 2016 at 6:41 PM
    #3073
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I appreciate all the kind thoughts and words everyone.
    Pretty sure now that the issue was the studs not being completely seated properly in the hub.
    Everything is back together once again. Still undecided on status.
  14. May 26, 2016 at 8:35 PM
    #3074
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Weigh then act upon fact.
  15. May 26, 2016 at 9:10 PM
    #3075
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    AR15xAR10 and G.T. like this.
  16. May 26, 2016 at 9:20 PM
    #3076
    SMKYTXN
    Nathan
    Houston
    DCFB
  17. May 26, 2016 at 11:46 PM
    #3077
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    Scary dude! Literally my worst nightmare with my spacers....
    I think you should still come to Moab though! Sounds like you figured it out, as long as they're seated good go for it!
  18. May 27, 2016 at 4:41 AM
    #3078
    G.T.
    G.T.
    CONUS
    @HomerTaco, if your trip out west and/or back takes you along Interstate 64 through St. Louis and you need a place to be able to turn a wrench I can open my shop for you. I don't have every tool out there but I have quite a few plus an air compressor to run pneumatic tools. I can also scare up some local TacomaWorld guys to help out if needed.
    HomerTaco[OP] and SMKYTXN like this.
  19. May 27, 2016 at 5:04 AM
    #3079
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Thank you sir, that is very kind of you to offer.
    I'm taking the truck over to get it up on a lift to give it a detailed look over this afternoon. I'll know more then.
  20. May 27, 2016 at 5:46 AM
    #3080
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    while on said lift,have father in law throw a weld on the back side of stud to axle flange.Piece of mind and hit the road.If you have break down give me a holler,ill load up trailer and come get u.
