HomerTaco's big old bucket o’ bolts build
Discussion in '2nd Gen. Builds (2005-2015)' started by HomerTaco, Jan 1, 2011.
  1. Dec 3, 2016 at 3:07 PM
    #3281
    TOYTONKA
    TOYTONKA Well-Known Member
    Dennis
    Hatboro, Pa.
    2015 tacoma trd sport dclb
    Borla cat back exhaust "touring", K&N cold air intake, weather tech digit fit floor liner front & back, A.R.E. cap w/ bed rug, Redline hood struts, Slow drop tailgate strut, tow hitch d-ring, Transformer badges, window tint
    OH BOY! Here come's another fire in Homers garage.:D
    Tractorman, ChadsPride and Blackout14 like this.
  2. Dec 3, 2016 at 3:12 PM
    #3282
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Nope. Still got nothing.
  3. Dec 3, 2016 at 3:12 PM
    #3283
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    ChadsPride, Blackout14 and TOYTONKA like this.
  4. Dec 3, 2016 at 3:13 PM
    #3284
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
  5. Dec 3, 2016 at 3:44 PM
    #3285
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
  6. Dec 3, 2016 at 3:49 PM
    #3286
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I spent most of my day wrestling Christmas lights... The only thing I was able to do to the truck was pull the rear tires and inspect the brakes by pulling the drums.
    Weird thing is that when I had them both off & turned the hub the wheel on the other side tuned the opposite way like it's supposed to without issue.
    I had to do some major gutter repair on the back of my house so I did that while I had the ladders up for the lights.
    Tomorrow morning I'll pull the diff skid and drain & see if I get any metal.
    I'll keep y'all posted. :thumbsup:
  7. Dec 3, 2016 at 4:53 PM
    #3287
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I see Chad stopped by... :rolleyes:
  8. Dec 3, 2016 at 4:57 PM
    #3288
    ChadsPride
    Sponsored by TacomaWorld.com
    :hattip:
    Place is nice, sorry about the breakage.
    Blackout14 and HomerTaco[OP] like this.
  9. Dec 3, 2016 at 4:59 PM
    #3289
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :laughing:
  10. Dec 3, 2016 at 5:00 PM
    #3290
    ChadsPride
  11. Dec 3, 2016 at 5:25 PM
    #3291
    tylerb2011
    tylerb2011 Take Me Home Country Roads
    Tyler
    Elkins WV
    2018 Toyota Tacoma TRD Sport
  12. Dec 3, 2016 at 5:34 PM
    #3292
    cynicalrider
    cynicalrider #NFG
    Jersey
    If you were in 2 hi, I don't see how it could be your t case. T case shouldn't have been engaged, no? I'm putting money towards a chipped tooth. Just theorizing. Either way, sorry to hear Craig.
    Blackout14 and ChadsPride like this.
  13. Dec 3, 2016 at 5:34 PM
    #3293
    VolkswagenTaco
    VolkswagenTaco Well-Known Member
    Sean
    Compton
    2012 sr5 4x4 Canadian model with factory locker. Pyrite Mica
    Sick overland rig
  14. Dec 3, 2016 at 5:34 PM
    #3294
    ChadsPride
    :bananadance::bananadance::bananadance:
    :wink:
  15. Dec 3, 2016 at 7:11 PM
    #3295
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    chain driven Tcase has moving parts regardless of selection, and theres a crawlbox in the mix too
    ChadsPride likes this.
  16. Dec 3, 2016 at 7:39 PM
    #3296
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you jacked up the rear, put it in neutral, and spun the rear tires yet? Alternately, with out the D.S. attached?
  17. Dec 3, 2016 at 7:51 PM
    #3297
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Did it with the DS on and the other side spun the opposite way as it should. :notsure:
  18. Dec 3, 2016 at 8:04 PM
    #3298
    cynicalrider
    cynicalrider #NFG
    Jersey
    Word, not all up on the crawlbox and fj cases
  19. Dec 3, 2016 at 8:08 PM
    #3299
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hmm. Sucks. Diagnosis mode Go.
  20. Dec 4, 2016 at 7:20 AM
    #3300
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    What did you do!?!
    :popcorn:
    Nimble9 and ChadsPride like this.
