HomerTaco's big old bucket o’ bolts build
Discussion in '2nd Gen. Builds (2005-2015)' started by HomerTaco, Jan 1, 2011.
  1. Aug 2, 2018 at 2:32 PM
    #4281
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    You told me what I needed to know about the dash trim piece. Hopefully that's not too hard to find. The wiring I can figure out through trial and error or research. There's only 3 positions for that switch so it can't be too complicated.
  2. Aug 2, 2018 at 2:36 PM
    #4282
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Stealership can easily source the dash piece. ;)
  3. Sep 9, 2018 at 7:19 PM
    #4283
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  4. Sep 9, 2018 at 7:25 PM
    #4284
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Bought this & the wiring harness this evening:
    G.T., Neutral, TinyTech626 and 4 others like this.
  5. Sep 9, 2018 at 7:39 PM
    #4285
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Yep. Going to mod it a bit - I want to vent it with a small air filter and enclose the top. Without inner fender liners it will get all cruddy even in the new location if I don’t seal it up better.
    Blackout14 likes this.
  6. Sep 9, 2018 at 7:45 PM
    #4286
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    My single failed under the hood. Since the dual was so expensive I wanna protect it as best as I can.
    With the relocate I’ll also have to swap the air lines from front to back due to the length.
    The mount and harness weren’t cheap - with shipping I’m out $250. But it makes it a pretty straight forward plug & play install and takes a lot of guesswork out.
    I’m all about simple.
    TinyTech626 and Blackout14 like this.
  7. Sep 10, 2018 at 4:43 AM
    #4287
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    The only reason not to put the compressor in the cab is sleeping kid(s). You'll be out airing up, they are sacked out in the back seat after a long day.
  8. Sep 10, 2018 at 4:45 AM
    #4288
    Arcticelf
    Gladiator
    Putting a lid on it would be a good idea, I should have done that.
    You'll also want to drill a couple holes in the side and add grommets to protect the air and electrical lines going through. My only gripe with that mount is the lack of provisions for routing wires.
  9. Sep 10, 2018 at 12:08 PM
    #4289
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Still have the single?
  10. Sep 17, 2018 at 7:00 PM
    #4290
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Yep. have not removed it yet. :oops:
  11. Sep 17, 2018 at 7:01 PM
    #4291
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  12. Sep 18, 2018 at 4:19 PM
    #4292
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Air upgrade pending... still need some odds & ends but I’ve got most of what I need now.
    JLink, srspicer, Littles and 2 others like this.
  13. Sep 18, 2018 at 5:10 PM
    #4293
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Fake news. I heard a about this supposed compressor install back in May.
  14. Sep 18, 2018 at 5:16 PM
    #4294
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I don’t mod quick. :pout:
    Originally I was just going to jam it into the engine bay but I thought that I better put a little bit more effort into it.
    Going to do it right this time.
  15. Sep 18, 2018 at 6:07 PM
    #4295
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Big wires all the way to the back. At least 4g
  16. Sep 18, 2018 at 6:33 PM
    #4296
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    That's what the spool is in the left corner. Bought that with the mount. :D
  17. Sep 18, 2018 at 6:35 PM
    #4297
    MTgirl
    Weesa
    Bob's secret mod lair
  18. Sep 18, 2018 at 7:20 PM
    #4298
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    Looks like the regular harness to me. :notsure:
    I’m talking main power from the battery. I initially ran 6g and blew lots of 50,60 and 80 amp fuses at the battery. Then ran 4g with 100amp breaker at the battery, 80 amp at the bed and then I attached the ARB wiring harness with 40amp fuses still intact.
  19. Sep 18, 2018 at 7:48 PM
    #4299
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    It’s an aftermarket harness designed for the longer length install of having the unit in the bed. Very thick wire. I’ll post a close up tomorrow. ;)
    Arrex likes this.
  20. Sep 19, 2018 at 12:38 AM
    #4300
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    He said unit
