HomerTaco's big old bucket o’ bolts build
Discussion in '2nd Gen. Builds (2005-2015)' started by HomerTaco, Jan 1, 2011.
  1. Apr 23, 2014 at 6:46 AM
    #961
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    What drive shaft? :anonymous:
    the one that fell out of the back of my truck?
  2. Apr 23, 2014 at 8:59 AM
    #962
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    :rolleyes:
  3. May 4, 2014 at 7:25 AM
    #963
    McFly2013
    McFly2013 New Member
    Houston, TX
    13 SR5 T-Force
    Man, those 35s look amazing!!! Looking to go the same route as you, would you mind listing the specs on the wheels and tires and who makes them? Thanks!!!
  4. May 4, 2014 at 9:03 AM
    #964
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Kmc Xd strike. 17x9 4.06 backspacing, -24mm offset
    Had to look that up. :eek:
  5. May 4, 2014 at 8:23 PM
    #965
    McFly2013
    Houston, TX
    13 SR5 T-Force
    Good stuff!!!! Really appreciate it!!!
  6. May 5, 2014 at 9:21 AM
    #966
    Griff 99 TRD
    Griff 99 TRD Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp HAT Speakers Pioneer Head Unit ARB bumper XD 128 16x8 wheels Odyssey battery BAMF Sliders Camburg UCAs
    You have any issues with your engine "bogging" down with such a large tire/wheel combination? I thought about putting 33's on my '99 Tacoma, but I had read that that size was too big for a 3.4L.
  7. May 5, 2014 at 10:14 AM
    #967
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Not at all - I've also swapped out the stock 3.73 gears for 4.56 gears.
    It drives and accelerates like stock.
  8. May 5, 2014 at 7:49 PM
    #968
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Crawlbox arrives this week. :yay:
  9. May 6, 2014 at 2:13 AM
    #969
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    :woot:
  10. May 6, 2014 at 6:17 AM
    #970
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    There are tons of people on here that are running 33's with a 3.4 and stock gears. Yes you will lose power but it shouldn't bog down terribly if at all. 35's or a 4 cyl would be a different story.
    :popcorn:
  11. May 6, 2014 at 7:04 AM
    #971
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :woot: :bananadance:
  12. May 8, 2014 at 8:28 PM
    #972
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    We have box :yay:
    Too bad I'm not home... :pout:
  13. May 9, 2014 at 12:11 PM
    #973
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I like box.
    HomerTaco[OP] likes this.
  14. May 9, 2014 at 2:11 PM
    #974
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Who doesnt? :cool:
  15. May 9, 2014 at 2:12 PM
    #975
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Want to box? :duel:
  16. May 9, 2014 at 2:37 PM
    #976
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  17. May 9, 2014 at 2:54 PM
    #977
    XXXX
    sKiP
    05 Prius
    People usually post pics of the stuff in the box, not the box.
    I'm guessing its Angelina joles head.
  18. May 9, 2014 at 2:58 PM
    #978
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I did not have time to unpack it - had to go out this evening. :(
  19. May 9, 2014 at 3:01 PM
    #979
    XXXX
    sKiP
    05 Prius
  20. May 9, 2014 at 3:13 PM
    #980
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
