Honda question
Discussion in 'Technical Chat' started by mustangwilly, Jul 16, 2010.
  1. Jul 16, 2010 at 5:08 PM
    mustangwilly
    mustangwilly [OP] Well-Known Member
    IL
    2017 DCSB OR Quicksand MT
    I'm sorry to ask a Honda question on this site but I'm sure someone on here can help me out. My wife drives a CRV and I just changed the tranny fluid. The manual says it holds 2.5 quarts so I bought 3 quarts and figured I would be fine. I put all 3 quarts in and it's still not up to the low mark when the fluid is hot. Should I keep adding fluid? Is their spec really 1 quart off? Any help would be apreciated.
  2. Jul 16, 2010 at 5:10 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Don't you check it while it running? Would that make a difference?
  3. Jul 16, 2010 at 5:10 PM
    mustangwilly
    IL
    It is a AUTO.
  4. Jul 16, 2010 at 5:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    its probably off a little. add a lil more....drive it then check it.
  5. Jul 16, 2010 at 5:11 PM
    mustangwilly
    IL
    I checked per the manual which says to turn off when checking.
  6. Jul 16, 2010 at 5:13 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    are you sticking the dipstick all the way in when checking it
  7. Jul 16, 2010 at 5:14 PM
    mustangwilly
    IL
    Yes it's all the way in.
  8. Jul 16, 2010 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Correct. They should have 2 marks on the dip stick. One side is when running, one is when off. Check the manual.
  9. Jul 16, 2010 at 5:15 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    also what year is it
  10. Jul 16, 2010 at 5:16 PM
    mustangwilly
    IL
    Here is what the manual says
    ATF Level Check
    [FONT=Arial,Helvetica][FONT=Arial,Helvetica]NOTE: Keep all foreign particles out of the transmission.
    [/FONT]
    [/FONT][FONT=Times New Roman,Times][FONT=Times New Roman,Times]1. [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]Park the vehicle on the level ground.
    [/FONT]
    [/FONT][FONT=Times New Roman,Times][FONT=Times New Roman,Times]2. [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]Warm up the engine to normal operating temperature (the radiator fan comes on), and turn the engine off. Do not allow the engine to warm up longer than the time it takes for the radiator fan to come on twice.
    NOTE: Check the fluid level within
    [/FONT]
    [/FONT][FONT=Times New Roman,Times][FONT=Times New Roman,Times]60-90 [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]seconds after turning the engine off. Higher fluid level may be indicated if the radiator fan comes on twice or more.
    [/FONT]
    [/FONT][FONT=Times New Roman,Times][FONT=Times New Roman,Times]3. [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]Remove the dipstick (yellow loop) (A) from the dipstick guide tube, and wipe it with a clean cloth.
    [/FONT]
    [/FONT][FONT=Times New Roman,Times][FONT=Times New Roman,Times]4. [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]Insert the dipstick into the guide tube aligning the notch [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica](8) [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]with the guide tab (C).
    [/FONT]
    [/FONT][FONT=Times New Roman,Times][FONT=Times New Roman,Times]5. [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]Remove the dipstick and check the fluid level. It should be between the upper mark (A) and lower mark (8).
    [/FONT]
    c ​
    [/FONT]
    [/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]6. If the level is below the lower mark, check for fluid leaks at the transmission, and hose and line joints. If a problem is found, fix it before filling the transmission.
    NOTE: If the vehicle is driven when the ATF level is below the lower mark:
    • Transmission damage will result.
    • Vehicle does not move in any gear.
    • Vehicle accelerates poorly, and flares when starting off in the D and R positions.
    • The engine vibrates at idle.
    • [/FONT]
    • [/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]l'
    [/FONT][/FONT][FONT=Times New Roman,Times][FONT=Times New Roman,Times]7. [/FONT][/FONT][FONT=Arial,Helvetica][FONT=Arial,Helvetica]If the level is above the upper mark, drain the ATF to proper level (see step 3 on page 14-239).
    above the upper mark, the vehicle may creep
    forward while in the N position, or have a shifting
    problem.
    1. If necessary, fill the transmission with ATF through the dipstick guide tube opening (A) to bring the fluid level midway between the upper mark and lower mark ofthe dipstick. Do not fill past the upper mark. Always use Honda ATF-Z1 Automatic Transmission Fluid (ATF). Using a non-Honda ATF can affect shift quality.
    2. Insert the dipstick into the guide tube aligning the notch with the guide tab.
    [/FONT]
    [/FONT]
  11. Jul 16, 2010 at 5:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The only engines that I know of that had a counter clockwise rotation, were old Volvo's......fwiw.
  12. Jul 16, 2010 at 5:26 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    the motor should be off when checking the fluid,so if the motor is off how is direction rotation going to affect the fluid level?
  13. Jul 16, 2010 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  14. Jul 16, 2010 at 5:30 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    well first thing we need to know is what year it is,this will make a big difference on how to check it.
  15. Jul 16, 2010 at 5:47 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    did you do just a drain and fill or a flush? I just did my wife's 06 civic. If it was just a drain and fill, then the 2.5 or so "should" be correct. A drain and fill on the civic took in 3 qts.
    If you drained out all of it (flush), it should be way more than 3 qts..
  16. Jul 16, 2010 at 5:48 PM
    Tojo
    Tojo Well-Known Member
    Colorado/Arizona
    10 TRD Off Road 4x4
    Mobil 1 0-20W, Tacoma bed mat, tailgate anti-theft, oil filter drain hose, back seat headrest removal, a/c back seat platform, rear spring tsb, Tek.Prodigy P2 electric brake cntrl, Toyota Bed Extender
    I've gotta 05 4wd crv and owners manual calls for 3.3 US qrts on change w/7.6 qrts total, converter/flush etc..
  17. Jul 16, 2010 at 6:00 PM
    mustangwilly
    IL
    It's a 2008 4wd. It calls for 2.6 quarts when doing a drain and fill which is what I did. I drained the fluid right after a 20 minute on a 90 degree say so it was HOT...would that let more fluid come out?
  18. Jul 16, 2010 at 6:09 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    it should have taken 3 quarts on a drain and fill,but it must have been a little low.make sure you don't have any leaks.then add fluid till its up to the upper mark,when the engine is hot,and not running.
  19. Jul 16, 2010 at 6:11 PM
    mustangwilly
    IL
    Thanks!
  20. Jul 16, 2010 at 6:17 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    also Honda ATF-Z1 Automatic Transmission Fluid (ATF) is dextron 3
