Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. May 13, 2018 at 5:05 AM
    #2181
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    It’s 1.5” od.
  2. May 13, 2018 at 5:26 AM
    #2182
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Thanks Wiley
    DoorDing likes this.
  3. May 13, 2018 at 10:16 AM
    #2183
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    It would be excellent if white on the inside and black or silver on the outside would be offered in the basic paint package.
    rooster32 and eyemajeenyus like this.
  4. May 13, 2018 at 1:39 PM
    #2184
    YOTA 4X4
    It’s powder coated so that’d be tricky.
    But.... you could install, or have white vinyl installed VERY easily and cheaply. Or get white and install vinyl in whatever ever color you like on the outside panels.
    Just a thought.
  5. May 13, 2018 at 1:51 PM
    #2185
    slowboater
    slowboater Well-Known Member
    Have a source for reasonably priced - color matched - vinyl? A quick google search looked like close to a grand for enough to wrap a GFC. For that price - I'll have a non color matched topper. :)
  6. May 13, 2018 at 2:15 PM
    #2186
    YOTA 4X4
    2 panels 5-6ft long 2ft high (sides)
    2 panels 4.5ft long 2ft high (front and back)
    That’s what 45 sqft? Call it 50 worst case, so you’d need about a 2 ft wide roll. I don’t know what color your trying to match but a 10yd roll is like $60 bucks for normal stuff. I’m not a vinyl guy (though my buddy is). I guess if you were ordering a paint matched color it could be expensive maybe? I don’t know what color you need. But you’re only taking about covering 4 flat panels. That’s about as easy as it gets.
    You can get the GFC powder coated to match as an option than just do the inside in White for a few bucks.
    I’m ordering black for mine. Figured black matches everything and the roof is white anyway.
    Just my $.02
    Willbeck, tonered and rajacat9 like this.
  7. May 13, 2018 at 2:20 PM
    #2187
    Texas-Shrapnel
    Texas-Shrapnel Well-Known Member
    Kevin
    2015 DCSB TRD off road
    Can you (I) put vinyl on the roof to make it less transparent. I want to sleep in and don't care for the transparent top.
  8. May 13, 2018 at 3:10 PM
    #2188
    rajacat9
    Washington State
    I'm getting black too. Thinking of fitting thin (1/2") closed cell insulation on the inside between the framing. I'll cover with some washable white material, maybe white formica w/ contact glue. Keep the insulation thin so not to hurt headroom very much when they're open.
  9. May 13, 2018 at 3:26 PM
    #2189
    camrsummers
    camrsummers Well-Known Member
    Cameron
    2018 SR5 DCLB 4x4
    Do you think it is possible to attach the rain gutter style crossbars to the GFC?
  10. May 13, 2018 at 3:29 PM
    #2190
    YOTA 4X4
    No, they have brackets for round (Yakima) bars that attach to the extrusions.
  11. May 13, 2018 at 3:31 PM
    #2191
    YOTA 4X4
    Not too sure that’ll work... the design of the camper has the panels sealing against the space frame. So unless you’re going to just attach to where the frame is not. You’ll interrupt the seal.
  12. May 13, 2018 at 3:46 PM
    #2192
    slowboater
    Yeah, that's my math too. But, it looked like color matching is expensive. I'm planning to go with silver so that it's least offensive to any color truck (IMHO). I would go with black but it'll get too hot for the dog.
    YOTA 4X4[QUOTED] likes this.
  13. May 13, 2018 at 5:29 PM
    #2193
    rajacat9
    Washington State
    Yes, they'll not intercede between the tubing and the frame. Perhaps they could be removable. Insulation from heat, cold and sound. Granted its not perfect coverage but it should make a noticeable difference. I'm not sure I'll do it this way, just brainstorming. Nice that in very hot weather you can open all the hatches but that will also expose the black windoors vertically to the sun.
    blind cowboy likes this.
  14. May 13, 2018 at 6:55 PM
    #2194
    rajacat9
    Washington State
    Yeah, that would be the simplest solution but I'd rather not have uncovered Reflectix as the finish. Also the closed cell foam is more efficient and the formica is easy to keep clean.
  15. May 14, 2018 at 6:43 AM
    #2195
    wileydavis
    Wiley
    2017 SR5
    Wall thickness is .065" and the spec is A513.
  16. May 14, 2018 at 8:47 AM
    #2196
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    I've already discussed with Graeme my colors and extra options, so thats a YES, but via email.
    Evanike and Willbeck like this.
  17. May 14, 2018 at 9:26 AM
    #2197
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    It's definitely not transparent. Very much translucent, and from what I understand, a lot of the pictures that @inv3ctiv3 has posted are long exposures, making it look like it lets through more light than it does.
    tonered likes this.
  18. May 14, 2018 at 9:46 AM
    #2198
    Evanike
    Evanike Well-Known Member
    Evan
    Encinitas, CA
    GFC Camper, OME Suspension
    How long ago did you receive this email? And I remember you saying a while back that you were planning on getting the white glove delivery option as well correct? I’m #26 and was originally going to drive up and get it from San Diego but I’m thinking I might want to do the white glove delivery option!
    socalktk[QUOTED] likes this.
  19. May 14, 2018 at 9:50 AM
    #2199
    rajacat9
    Washington State
    Sure, if I decide to do it I'll post pics and temperature difference results. IDK if I can accurately determine temp. difference, it'll be more an impression. Insulation will help with condensation too. I believe the more insulation, the better. Installing it so that its unobstusive and neat looking is the problem.
    DoorDing and tonered like this.
  20. May 14, 2018 at 10:22 AM
    #2200
    socalktk
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Email was sent out to me May 1st about it beginning to be built, but im sure its delayed a bit again since all the GFC's i see being built on their page are with the orange frame, not the grey i had ordered.
    Graeme said they were going to do a delivery run to LA right after expo west.. so maybe they are bringing a bunch of em out to us Socal'ers.
    Borrego Taco likes this.
