Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Jun 1, 2018 at 9:43 AM
    #2581
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    The wires leading to the panel also could be considered a backup. Kinda like a trailer chain/hook.
  2. Jun 1, 2018 at 9:54 AM
    #2582
    unclewilson
    unclewilson Well-Known Member
    Wilson
    Michigan or Colorado
    Several
    Lots
    @BivouacCoffee
    What solar panels are you using? They look like glass rigid not the slim flex panel....
  3. Jun 1, 2018 at 9:54 AM
    #2583
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    I have a single group 31 odyssey for everything and I've been able to leave stuff plugged in for a couple months at a time. I've had the battery for almost 2 years now. But I do have a battery minder AGM that I plug in once a month. If I had a solar panel permanently installed then charging would never be an issue. If I were running a second battery, I'd consider picking up a CTEK D250S DC-DC charger w/ mppt solar charge controller.
    With the CTEK it would basically maintain a completely separate system without any worry that the house battery will backfeed the starter battery. When leaving the vehicle stationary long term, you can get a perfect switch (as budget allows) single rectifier isolator to combine both batteries when charging.
    ace7196[QUOTED] likes this.
  4. Jun 1, 2018 at 9:55 AM
    #2584
    unclewilson
    Wilson
    Several
    Lots
    I run the CTEK with my dual battery. Works well and easy to use
    kalieaire[QUOTED] likes this.
  5. Jun 1, 2018 at 11:15 AM
    #2585
    BivouacCoffee
    BivouacCoffee Member
    Kyle
    2018 TRDOR-LB
    Custom leather 265/75/16- Duratrac Decked- en route GFC - en route 1kw. Goal Zero Solar
    Ok lots of questions there. 1st off Yes it is industrial outdoor Velcro that holds 2lbs per sq in. It’s literally made from metal. It is backed up with a cable lock for security.
    Yes they are ridged 100w boulder panels from Goal Zero. Our power is 100% separate with a goal zero yeti but is backed up by the PTO plugs in the bed if we are not making enough energy with solar.
    unclewilson likes this.
  6. Jun 1, 2018 at 11:30 AM
    #2586
    slowboater
    slowboater Well-Known Member
    Not sure how much good just connecting to AC once a month will really do you - if you keep everything charged up on a regular basis. But above comment is perfect. Just get an isolator so that the house battery (as opposed to the cranking battery) are isolated during use but both get charged during charging sessions (truck running or any other charging system). For simplicity, I would (will) probably only put solar onto the house battery. I'll keep the cranking battery isolated at all times using the single rectifier mentioned above to allow charging of the house battery while the truck is running. With such a system, the cranking battery should never be touched and not need trickle charged - ever - unless you're leaving the truck sit for extended periods of time in storage.
    From boating experience:
    1) keep the cranking battery isolated at all times! some folks don't and rely on keeping track of drainage - but this is always risky. especially on a boat (I had a 35' sailboat) where cranking the engine up could save you in an emergency situation.
    2) keep the system simple. high quality parts are beneficial (for example AGM batteries!!) but the more complicated the system the more chances you have of making a mistake or having something fail.
    thread jack over....
  7. Jun 1, 2018 at 11:36 AM
    #2587
    unclewilson
    Wilson
    Several
    Lots
    Also, don't mix battery types, example: Don't mix lead acid with AGM. They charge and maintain charge differently.
    Anyways, who's excited for the next GFC images.... I know I am ;-)
    YOTA 4X4 likes this.
  8. Jun 1, 2018 at 11:48 AM
    #2588
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    I can't tell from the pics, is that silver or white?
  9. Jun 1, 2018 at 11:49 AM
    #2589
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    :wave:
    I just want to see what they've worked up for the 1st gen, as we should be seeing that any time.
    Nothing like not knowing exactly what you've bought until the last minute. :D
  10. Jun 1, 2018 at 11:50 AM
    #2590
    unclewilson
    Wilson
    Several
    Lots
    I think it's white
  11. Jun 1, 2018 at 11:53 AM
    #2591
    slowboater
    Good point! But you may be able to do it with isolators... Something i need to review... it's been a while.
    Can't wait to get my GFC. It's pushed back a bit more than I thought (I guess mainly because I didn't realize I was #46 in the build queue) but I'm sure looking forward to getting it!
  12. Jun 1, 2018 at 12:09 PM
    #2592
    COdude3
    Colorado
    Glad I asked, because I was thinking silver.
  13. Jun 1, 2018 at 12:11 PM
    #2593
    unclewilson
    Wilson
    Several
    Lots
    Yeah.... I think it's more of an off white
  14. Jun 1, 2018 at 12:17 PM
    #2594
    unclewilson
    Wilson
    Several
    Lots
    White
    Gray left White Right
    Gray
  15. Jun 1, 2018 at 12:19 PM
    #2595
    Gimmeanm3
    Gimmeanm3 Well-Known Member
    David
    Denver, CO
    '18 DC LB TRDOR / 2011 BMW 1M
    Ok, I did it. I read through the whole thread! I feel special.
    All I want to know is...if the back window is closed, the driver's side is open 1/2 way and the passenger's side is open 1/3rd of the way and I'm parked facing NNE and it's raining on a Tuesday is the bed going to get wet? And let's talk about the fan some more. Just kidding.
    But seriously, this hasn't been asked:
    Would the mounting points of the GFC interfere with the pins for the OEM tonneau? On a long bed? Looks like it will...can anyone confirm?
    24A889D4-2861-4EBC-9619-3FDB3FBEE059-47836-000027A4D51CBA33.jpg OEM Tonneau Pins.jpg
    406tacoS and tonered like this.
  16. Jun 1, 2018 at 1:08 PM
    #2596
    kalieaire
    Santa Clara County
    Just a note, the 31-pc2150 can be left alone for a couple of months with no problem. Though a consideration should be made for standard Denso rectifiers do not have a high enough charging voltage for the 31-PC2150 which is happier with a 14.6v charge, that's why I use an AGM specific charger.
    I work with our County Fleet maintenance team and they also recommend against linking batteries together. The biggest issue is when a battery in the system is partially or completely drained, linking the batteries will create a large current inrush. This can damage multiple components in your system, especially things like solenoid contactors, the battery with the greater voltage and/or the empty battery. The batteries themselves are not chargers and do not provide constant current and ramp up the voltage, they charge by dumping as much current as possible with a slowly decreasing voltage, this can quickly lead to sulfation.
    Avoiding multiple battery types is a non-issue if they are separated with a dc-dc charger like the D250S since its sole purpose is to charge and maintain batteries by drawing power from:
    1. The Alternator
      and|or
    2. Solar Panels
    At no point does this specific setup have any influence with the starting battery.
    Actually avoiding mixing battery types doesn't really make a lot of sense either because even batteries within a specific brand have their own considerations. IE, Odyssey 34-790 vs the 34-1500 will have different considerations as well since a 34-790 will behave like an OEM battery wrt charge characteristics but the 34-1500 will require a slightly increased charging voltage like the 31-PC2150
    slowboater[QUOTED] likes this.
  17. Jun 1, 2018 at 2:27 PM
    #2597
    bgraboyes
    bgraboyes Well-Known Member
    Just wondering if anyone has any data on gas mileage difference with the GFC installed?
  18. Jun 1, 2018 at 4:27 PM
    #2598
    rocket_scientist
    rocket_scientist Well-Known Member
    Northern VA
    Just talked to Graeme, whose name spelling I just butchered, finalizing my options. #24 should be delivered the 3rd week of June.
    Evanike, Borrego Taco and YOTA 4X4 like this.
  19. Jun 1, 2018 at 4:38 PM
    #2599
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Nope, I believe Graeme is correct.
    :woot:
  20. Jun 1, 2018 at 5:25 PM
    #2600
    Borrego Taco
    Borrego Taco Well-Known Member
    2017 DCSB TRD OR 4x4
    Same here. Build #22.
    Evanike likes this.
