Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Jun 5, 2018 at 11:05 AM
    #2721
    tjhaugh
    tjhaugh Member
    Plus one on this!
    Tacovore and Evanike[QUOTED] like this.
  2. Jun 5, 2018 at 11:16 AM
    #2722
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    I had to remove my rack for some windshield work/rust repair, and with the market for Prinsu in Denver I sold my prinsu for the price of a new one and ordered the half rack. I was about $30 out of pocket to order the half rack. My receipt says shipping June 21 (if i remember correctly). I was almost going to just chop it in half, but like the idea of having a cleaner look. If i had an access cab or long bed i would have definitely cut just the end of it for more rack.
    riz_atx[QUOTED] likes this.
  3. Jun 5, 2018 at 11:18 AM
    #2723
    TacodileSupreme
    TacodileSupreme ¯\_(ツ)_/¯
    Thomas
    Dallas, TX
    Super White SR5
    I assume you had to call about the half rack? Not seeing it on their site and this is an intriguing option.
    Pull the trigger man. Another Texas GFC!
  4. Jun 5, 2018 at 11:20 AM
    #2724
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    I just read about the half rack from a post above
    Once the money from the house sale lands in my bank account, things are getting ordered!
  5. Jun 5, 2018 at 11:22 AM
    #2725
    riz_atx
    Sohail
    Spicewood Texas
    Ive got a long bed! So this means the overhang would be less and thus less of the prinsu removed... right?
  6. Jun 5, 2018 at 11:23 AM
    #2726
    crolison
    Ar vah da, CO
    POS
    Yep, whereas where you would need to chop the top on the short bed its in the middle of one of the slots for the adjustable bars.
  7. Jun 5, 2018 at 11:24 AM
    #2727
    riz_atx
    Sohail
    Spicewood Texas
    Interesting indeed. Guess Ill just have to order it and find out when it shows up one day
  8. Jun 5, 2018 at 11:24 AM
    #2728
    crolison
    Ar vah da, CO
    POS
    I actually emailed about 1.5 months ago inquiring if they were going to make one, and they were. I had to order over the phone with Mike (i believe that's who i needed to talk to). They originally were going to introduce it for tacoma habitats, but the go fast has the same issues as the habitat in regards to overhang.
  9. Jun 5, 2018 at 11:50 AM
    #2729
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    You mean store stuff underneath on the inside of the camper? That fixed portion would be the overhang over the cab I would think.
  10. Jun 5, 2018 at 12:22 PM
    #2730
    TacodileSupreme
    Thomas
    Dallas, TX
    Super White SR5
    Right on, thanks for the info man.
  11. Jun 5, 2018 at 2:40 PM
    #2731
    rocket_scientist
    rocket_scientist Well-Known Member
    Northern VA
    The fixed portion extends into the bed area on the camper. I measured it as 23” at expo. I’m building a shelf under mine at bed rail level to hold some lightweight items.
    I measured the cab overhang on the access cab model as well and the front edge of the camper extends 21” forward from the back of the cab. Measurements done with a tape measure while mostly sober, so may be and inch off either way.
  12. Jun 5, 2018 at 3:18 PM
    #2732
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I've run a similar sized shelf on top of the bed rails (or rather on the inner lip of my camper shell) for years and it's so handy. It's not limited to lightweight stuff either - as I often would sit on mine in my last shell.
    Mine is a scrap of 3/4" OSB sub-floor, re-enforced with angle iron glued and screwed along the long dimensions (to keep it from bowing), painted black, and now even has strips of L-track along the perimeter.
    I currently have it mounted to the utility track with some angle iron brackets and @wileydavis (aka Hondo Garage) t-nuts. Just hauled a 75lb fridge/drawer slide 50+ miles strapped to it last night.
    Those T-nuts are so handy, I already have used the first 8 I ordered.
  13. Jun 5, 2018 at 3:58 PM
    #2733
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    It's not the best for showing the detail of its construction, but this shows the general idea. Currently mounted in the middle of the bed, it also provides a theft deterrent for larger items under it with the tailgate locked.
    4VduudEMmfMgxgl7gSUOjA__yTPOTIW5kOEpFpqG_d77293a5f7223d60d292340627b5dd0ba1cc4c40.jpg
    whitetaco16 and ace7196 like this.
  14. Jun 5, 2018 at 4:28 PM
    #2734
    Sleevez
    Sleevez Well-Known Member
    LA / Toronto
    2017 SW TRDPro, 2000 PinkTaco
  15. Jun 5, 2018 at 5:53 PM
    #2735
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Can someone with a shortbed version measure some spacing for me? Trying to see if there is room between the bracing on the side panels to mount Maxtrax pins. Four pins at the corners of a 35”x10.6” rectangle.
  16. Jun 5, 2018 at 6:43 PM
    #2736
    The_Black_Pearl
    The_Black_Pearl IG: the_black_pearl_tacoma
    Colorado Springs, CO
    2013 All Black Tacoma Double Cab Long Bed
  17. Jun 5, 2018 at 6:55 PM
    #2737
    unclewilson
    unclewilson Well-Known Member
    Wilson
    Michigan or Colorado
    Several
    Lots
    One more out the door, one less before me....
    Borrego Taco likes this.
  18. Jun 5, 2018 at 7:05 PM
    #2738
    Borrego Taco
    Borrego Taco Well-Known Member
    2017 DCSB TRD OR 4x4
    Glad to see progress and people getting ahold of their campers. The pictures in the latest email look awesome.
    Any word on fitted sheets yet?
    I forgot to ask when I talked to Graeme on the phone. It looks like one unit has something different with the red checked cushions.
    Quadabaum likes this.
  19. Jun 5, 2018 at 7:08 PM
    #2739
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    :thumbsup: :cheers:
  20. Jun 5, 2018 at 7:08 PM
    #2740
    Borrego Taco
    That’s my plan. First priority will be to use it!
