Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Jun 7, 2018 at 6:14 PM
    #2761
    Evanike
    Evanike Well-Known Member
    Evan
    Encinitas, CA
    GFC Camper, OME Suspension
  2. Jun 8, 2018 at 3:54 AM
    #2762
    whitetaco16
    whitetaco16 Well-Known Member
    James
    Central NC
    2016 TRD OR Access Cab Long Bed
    Dobinson's 2.5, RCI Sliders, Mobtown Recovery Bar and Front Skid, 4.88's and Extremeaire Magnum
    Just a little run to Uwharrie NF. Rough trails and lots of dust and the GFC passed with flying colors.
  3. Jun 8, 2018 at 6:32 AM
    #2763
    thesloppy1
    thesloppy1 Well-Known Member
    2016 quicksand Tacoma trd sport
    I'm a very impatient person. Dropping $6k and having to wait an indeterminate amount of time is going to kill me. But, I'm dropping the money in the next couple days and can't wait.
    Question, can you leave your bedding in the tent like most rooftop tents? That's the best part of having a RTT or camper is not having to pack up the sleeping bag every morning. Not a deal breaker, I'm buying it either way.
    Ralston and Tacovore like this.
  4. Jun 8, 2018 at 6:41 AM
    #2764
    unclewilson
    unclewilson Well-Known Member
    Wilson
    Michigan or Colorado
    Several
    Lots
    tonered and Borrego Taco like this.
  5. Jun 8, 2018 at 6:42 AM
    #2765
    thesloppy1
    Cool. Thanks. I can make that work.
    tonered likes this.
  6. Jun 8, 2018 at 7:47 AM
    #2766
    unclewilson
    Wilson
    Several
    Lots
    Question for anyone: Seeing as it's been mentioned that the panels are likely too thin to be durable enough to carry traction pads/mats, how are you planning on carrying them? Roof? Tire Carrier? Other?
  7. Jun 8, 2018 at 7:57 AM
    #2767
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    I have the MaxTaxx rear tire mount that I’m going to run.... of course you need a rear tire on your Tacoma for this. Since i may not ALWAYS have a Spare on the back i definitely plan on provisions for them on the roof too.
    My buddy runs them on the ROOF of his FJ and they work well... he mostly uses them to level his truck when camping. I can imagine if you bury them in mud, roof isn’t quite as great an option.
    Also keep in mind the extrusions all around the GFC for some reason i invision GFC having a MaxTraxx (or others solution) that will go right in those extruded tracks.
    (Right behind his RTT, so they aren’t any less aerodynamic in the HW)
  8. Jun 8, 2018 at 8:35 AM
    #2768
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Doubt it. If you mounted a maxtraxx there, it would mean you couldn't open the sides with them installed. Seems the roof is the best bet here or maning up and drilling holes in the aluminum side panels in the right spots to bolt in mounts. maxtraxx aren't that heavy. You could easily put in a heavier duty gas strut if you really wanted as well.
  9. Jun 8, 2018 at 8:35 AM
    #2769
    unclewilson
    Wilson
    Several
    Lots
    I though about mounting the on the extrusion, but you either mount them level with roof, likely blocking side opening, or mount them higher and become the highest point on GFC....
    What i think would be sick is a GFC fairing with an access panel/hinge where you could mount the maxtrax (the similar) underneath and out of the air path....
    Might just strap them to the roof like your buddy did in the end. Likely the quickest least complicated method.
  10. Jun 8, 2018 at 8:45 AM
    #2770
    Texas-Shrapnel
    Texas-Shrapnel Well-Known Member
    Kevin
    2015 DCSB TRD off road
    I'm still wondering how difficult or how easy it is to remove the side panels so I can have my dog in the back. I assume you'd have to remove at least the rear panel too if you are going down the freeway. Anyone?
  11. Jun 8, 2018 at 9:15 AM
    #2771
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    the bed of the truck?
  12. Jun 8, 2018 at 9:17 AM
    #2772
    unclewilson
    Wilson
    Several
    Lots
    Yes, but prefer to keep the muck out of the truck if possible.
  13. Jun 8, 2018 at 9:32 AM
    #2773
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Same. I posted the dimensions of the maxtrax pin mounting locations hoping someone with a GFC would take a few minutes and see if the mounts can fit without interfering with the tube frame and reinforcements on the panel.
  14. Jun 8, 2018 at 11:45 AM
    #2774
    crumb
    crumb Member
    Nick
    Phoenix, AZ
    2016 Quicksand 4x4 ORDC
    My thought is to mount 1, possibly 2, T-Slot bars (similar to a prinsu crossbar) on the outside of the panel. That way you don't have to worry about drilling exact holes and you have a more modular system on the outside. The con is the added weight. You would definitely need stronger gas struts.
  15. Jun 8, 2018 at 11:52 AM
    #2775
    rocket_scientist
    rocket_scientist Well-Known Member
    Northern VA
  16. Jun 8, 2018 at 12:13 PM
    #2776
    I_eat_tacos
    I_eat_tacos Well-Known Member
    I personally think the best location would be under the cab over portion using the front runner table rack. I bet you could shim and/or create mounting points to accept maxtrax that slide in underneath. That way you make use of that wasted space. My original idea is to use the front runner steel table and mount it underneath, using dimensions from door ding's post it fits as well. Either that or a Prinsu half rack might be the best places that are easy to reach and areas no one cares about getting dirty. https://www.frontrunneroutfitters.com/en/us/table-brackets-for-mki-table-incl-latch-rrac097.html
  17. Jun 8, 2018 at 1:55 PM
    #2777
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Well, out camping on another wet weekend wishing I had a GFC and not a ground tent to setup and dry out.
    Happy to be chilling regardless.
    VE7OSR and DoorDing like this.
  18. Jun 8, 2018 at 2:14 PM
    #2778
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    Wooo, have my build date now. October 1st
    TacodileSupreme, lambo and tonered like this.
  19. Jun 8, 2018 at 3:56 PM
    #2779
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    Just as a heads up, we've been working on our roof rack system and will have some cool stuff to show soon. Now that the shop is more or less running (not fast enough yet but I don't need to be there all the time to tell people what to do) I have time to design more products. So in addition to the rack tower for round bars, we'll be releasing a flat bed rack soon. This will work for the roof of the GFC of course, but we'll also have options for tacoma and 4runner roofs, as well as an 18" cantilever cab-over rack for the GFC that would be perfect for stuff like firewood or MaxTrax :thumbsup: ETA on the new racks is about 6 weeks.
  20. Jun 8, 2018 at 4:01 PM
    #2780
    TacodileSupreme
    TacodileSupreme ¯\_(ツ)_/¯
    Thomas
    Dallas, TX
    Super White SR5
    When did you order if you don't mind my asking?
