Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Jun 18, 2018 at 11:37 AM
    #2941
    thesloppy1
    thesloppy1 Well-Known Member
    2016 quicksand Tacoma trd sport
    Order # 189 places 30 minutes ago. It's going to be a long, painful wait.
    YOTA 4X4, riz_atx and crazysccrmd like this.
  2. Jun 18, 2018 at 12:22 PM
    #2942
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Sadly they don’t make a longbed bedside rail cap replacement. I’m not sure if anyone does. I wonder if I took off the factory plastic caps and laid down some rubber type material, if that would work. I’m sure I can find something.
    I’m guessing his has been discussed earlier in this thread? Gonna try to search a little and see what I come up with
  3. Jun 18, 2018 at 12:34 PM
    #2943
    bagtagley
    bagtagley Well-Known Member
    There is some question as to whether or not there's enough clearance for the antenna on a third gen with lower profile bed rails. I haven't seen a definitive answer, but I may have missed it.
  4. Jun 18, 2018 at 1:03 PM
    #2944
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It was said that GFC might make some.
    It sounds like the caps on the 2nd Gen were pretty thick. The 3rd Gen caps are thinner. A metal cap would not be significantly thinner than the plastic ones.
  5. Jun 18, 2018 at 1:12 PM
    #2945
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
  6. Jun 18, 2018 at 1:28 PM
    #2946
    whitetaco16
    whitetaco16 Well-Known Member
    James
    Central NC
    2016 TRD OR Access Cab Long Bed
    Dobinson's 2.5, RCI Sliders, Mobtown Recovery Bar and Front Skid, 4.88's and Extremeaire Magnum
    I have the factory bed rails and no problem with any leaksl. The bulb seal GFC uses is very thick and pliable so once the rail attachments are cranked down tight, there is little chance of a leak. I've been through two major downpours while on the interstate and not a drop...
    riz_atx, socalktk, Quadabaum and 4 others like this.
  7. Jun 18, 2018 at 4:29 PM
    #2947
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Oh no doubt, Just that a smooth surface will always seal better :)
    riz_atx likes this.
  8. Jun 18, 2018 at 4:29 PM
    #2948
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    wow....just went to their site...expecting $5,000 or less since they are in production now....but instead saw $5250 then windows at 250, lights for 325.....pretty expensive.....alos it is a pretty permanent mount and difficult to put on and take off.....The Tepui is very similar and around $1500.....or did I miss something
  9. Jun 18, 2018 at 4:33 PM
    #2949
    unclewilson
    unclewilson Well-Known Member
    Wilson
    Michigan or Colorado
    Several
    Lots
    Quicker setup, storage of a truck cap, lighter that RTT and cap combined, etc. But might not be for everyone.
    DoorDing, tonered and Evanike like this.
  10. Jun 18, 2018 at 4:36 PM
    #2950
    r1200gs4ok
    O. K.
    Irvine, Ca
    what is the weight?......
  11. Jun 18, 2018 at 4:38 PM
    #2951
    unclewilson
    Wilson
    Several
    Lots
    240-260 for Tacoma I think. Better question for those that have received them or @gmacmt or @wileydavis
  12. Jun 18, 2018 at 4:41 PM
    #2952
    r1200gs4ok
    O. K.
    Irvine, Ca
    thanks....that weight is about 125lbs more then the Tepui....but i get it....i agree less set up time, but for a weekender or 3-5 days get-aways, could be over kill and very expensive...but you correct, might not be for everyone.....I camp now with my BMW gs motorcycle.....as I get older, I plan on using my truck and want something easy to set up and use but not break the bank....thanks for your help
  13. Jun 18, 2018 at 4:45 PM
    #2953
    unclewilson
    Wilson
    Several
    Lots
    One other thing is that from what I’ve seen online and comments from those that are lucky to have them now, the quality and durability of the GFC is likely significantly better than a RTT. Another benefit is it was designed so owner could replace items if needed as it’s kind of modular.
    Willbeck and DoorDing like this.
  14. Jun 18, 2018 at 5:01 PM
    #2954
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    You missed something. The rough equivalent Tepui, the hard top version is 4K not $1500. There's no entry from the bed. It's smaller, looks less refined and not as well built. It doesn't include the whole camper shell. It appears to be fiberglass not aluminum/composite, I could go on. Go back and do some more research and all the differences will be clear. The hard shell Tepui is not even close. It really is just a roof top tent. The GFC is in another league.
    Willbeck, Tacovore and Borrego Taco like this.
  15. Jun 18, 2018 at 5:06 PM
    #2955
    overcast
    overcast Well-Known Member
    CA
    2012 OR Drifter
    Just installed, its definitely ~1" lower, but I did it primarily for strength and a tighter weather seal. Mind that you may have to mod the shark fin for these to fit on 2nd gens.
    I have a 2012, and with an RTT for those years, the plastic caps had worked through paint where the cross bars were exposing a little rust. Although very little, some rustoleum, some silicone, and now the kbvoodo steel caps are flush and 10x as strong.
    riz_atx[QUOTED] likes this.
  16. Jun 18, 2018 at 6:03 PM
    #2956
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Tepui and most other RTTs are mass produced in China. GFC machines, produces and hand builds each one of these in Montana. I had an ARB RTT mounted on bed bars and for only about 50lbs more weight I have a far better and higher quality setup.
    Tacovore, lukester78 and DoorDing like this.
  17. Jun 18, 2018 at 8:43 PM
    #2957
    r1200gs4ok
    O. K.
    Irvine, Ca
    i’m being won over...keep it up guys....
    The_Black_Pearl and Tacovore like this.
  18. Jun 18, 2018 at 9:04 PM
    #2958
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    You also get bed protection for all your expensive gear or whatever you haul in the bed. Its also lockable. Price a hardshell and a bed cap that can handle the weight and offroad abuse and your in the $3500-$4500 range, assuming you buy new and get one of those $1800-$2000 hardshells in a group buy. Then remember you cant use the bed as a "room" when its raining, set up will be quick but breakdown takes more time, and its not as strong as well built and no where near being built in america (if you care). To me its not that big a jump to go to the GFC. I already have hardshell and I was looking at some of the really cool bed rack/cap options (@Dissent86 builds) and I was still going to be a few thousand deep and not have the same features not to mention a soft shell that high up is horrible on mpg. Thats how I justified it. With my work schedule I only get one weekend off a month (granted 4 days and I have 3 weeks of paid vac) so I will be using my GFC 10-12 times a year, mostly 2-5 day trips maybe 1 big 10 day trip, and it still seemed worth it to me.
  19. Jun 18, 2018 at 10:20 PM
    #2959
    Gimmeanm3
    Gimmeanm3 Well-Known Member
    David
    Denver, CO
    '18 DC LB TRDOR / 2011 BMW 1M
    Nice pics!
    Any photos of those brackets and sheets?
    Jim Bob likes this.
  20. Jun 18, 2018 at 10:50 PM
    #2960
    TRD_SLO
    TRD_SLO Member
    2018 DCLB TRD Offroad
    @wileydavis (or any 3rd gen GFC owners) do you have the stock bedrail caps on your truck? I know kbvoodoo doesn't have their bedrail caps for longbeds, but was curious if there was such an option if it would affect the sharkfin at all. Any chance on a measurement from fin to bottom of GFC with how it sits stock?
    socalktk likes this.
