Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Jun 25, 2018 at 9:17 PM
    #3161
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That sounds like a bad idea. A lot of weight hanging off some small screws. What about four plates you could slide under the bottom of the frame and bolt to the mounting tabs welded to the frame?
  2. Jun 25, 2018 at 9:47 PM
    #3162
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    Cut the Prinsu rack and got er back on!
    Willbeck, Tacovore, Evanike and 5 others like this.
  3. Jun 25, 2018 at 10:00 PM
    #3163
    Ralston
    Ralston Well-Known Member
    High in the Rockies
    Super White - 4x4 - TRD Off Road
    Not at the moment. I know, I know. I should know better. Going to do a few Plusnuts into the composite bed, just hesitant on resale devaluation... Strapped down with OEM D-rings for now.
    ace7196 and trouttaco[QUOTED] like this.
  4. Jun 26, 2018 at 12:08 AM
    #3164
    shortround13
    shortround13 Well-Known Member
    Sacramento
    04 DblCab TRD 4x4
    Anybody else see the dog has arms and a body?
    Haha. Rack looks good on there.
    smelly621 and socalktk[QUOTED] like this.
  5. Jun 26, 2018 at 5:43 AM
    #3165
    rocket_scientist
    rocket_scientist Well-Known Member
    Northern VA
    How far out do the mounts extend (how big is that gap)?
  6. Jun 26, 2018 at 6:04 AM
    #3166
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    1.635" to be exact :) Just enough to clear the lift strut.
    transworldmoto likes this.
  7. Jun 26, 2018 at 6:10 AM
    #3167
    wileydavis
    Wiley
    2017 SR5
    That should be just fine. I'd recommend bolting the plates to the bottom extrusion since it has support the whole length via the mounting bolts. Place one set of brackets at the back and the other set just above the front of the space frame. If you use 4 bolts per bracket it will be plenty strong. I'm planning on having some simple steel lift brackets in the store very soon.
  8. Jun 26, 2018 at 7:30 AM
    #3168
    transworldmoto
    transworldmoto Well-Known Member
    Ben
    California Coast
    2016 Access Cab TRD OR 4X4
    Just wanted to send a huge thanks to Graeme, Wiley, (Ron?), Mateis (?), and the entire crew at GFC. I drove all the way out from the San Francisco Bay Area, arrived a bit early, and used the extra time before the install to visit Hyalite Reservoir with my (then) girlfriend and best friend where I popped the question (she said yes, thankfully - that would have been an awkward ride back to Cali!)
    The GFC team was awesome, very friendly, helpful, and definitely hard at work getting space frames welded and the tents sewn up. I've included some photos below (surprised the Prinsu rack fits!). Enjoy...
  9. Jun 26, 2018 at 7:38 AM
    #3169
    SJaYx2P
    SJaYx2P Well-Known Member
    1GDCPRE
    @transworldmoto lets see some night pics of the bed lights with the GFC. I bet its sexy AF.
    riz_atx likes this.
  10. Jun 26, 2018 at 7:49 AM
    #3170
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Sweeeet! Are you on factory bed rail caps? The plastic ones?
    DoorDing likes this.
  11. Jun 26, 2018 at 7:53 AM
    #3171
    Gimmeanm3
    Gimmeanm3 Well-Known Member
    David
    Denver, CO
    '18 DC LB TRDOR / 2011 BMW 1M
    Thanks @wileydavis ! That's exactly my plan; A square or rectangular plate where each is mounted with four of the T-nuts to the lower extrusion. Rear plates would be almost at the end and I envisioned the fronts being somewhere just in front of the space frame for balance.
    A little off topic, but how do you like the BP-51's? I have Fox 2.5/2.0 with remote resis and All-Pro's expedition leaf pack on my 2nd gen now. Want to have something on the 3rd gen that I'm going to build but don't want to go the same route...don't like how stiff and harsh the truck is on road. Can you speak to it's small bump compliance and ride comfort?
    Thanks,
    Dave
  12. Jun 26, 2018 at 7:58 AM
    #3172
    TacodileSupreme
    TacodileSupreme ¯\_(ツ)_/¯
    Thomas
    Dallas, TX
    Super White SR5
    For the off topic part it sounds like you may need to mess with your valving on the fronts and rears to better soak up those small bumps. Also the expos will be really stiff with no weight in the back (If that's the case). Upgrading your shackle hangers could help too. Would you say your front spring rate and preload is appropriate as well?
  13. Jun 26, 2018 at 8:16 AM
    #3173
    08brickfjc
    08brickfjc
    Ross
    Montana
    ‘08 FJ Cruiser ‘94 FZJ80
    It's Ross, not Ron...you guys made our Facebook page today! Thanks again and wish you guys a lifetime of happiness
    Ross
    Tacovore, DoorDing and Quadabaum like this.
  14. Jun 26, 2018 at 8:18 AM
    #3174
    Evanike
    Evanike Well-Known Member
    Evan
    Encinitas, CA
    GFC Camper, OME Suspension
    @transworldmoto do you have an Instagram account? Would love to see more pics of your truck, that thing looks sweet!
  15. Jun 26, 2018 at 9:03 AM
    #3175
    Gimmeanm3
    David
    Denver, CO
    Thanks. I do not have compression or valving adjustment on mine. I understand the expos are rough, I have a leer cap on the back along with All Pro's front and rear bumper and ifs skids. I called fox and talked with their engineers and we changed the front springs to better handle the weight, which it did, but it's still a heavy, harsh truck in my opinion.
    For the 3rd gen I'm ordering, I'm trying to decide between a Toytec Boss kit with add-a-leafs (and likely some firestone airbags and daystar cradles to handle the extra weight with GFC and gear when loaded) or a "all in" kit like the BP-51's with a Dakar pack, which I'm pretty sure is what @wileydavis is running.
    All of this will depend on overall height anyway...will need to fit in a 7' garage door :)
  16. Jun 26, 2018 at 9:11 AM
    #3176
    wileydavis
    Wiley
    2017 SR5
    I have the BP-51s and a Deaver U402 Stage I pack (The lowest spring rate one). For my truck it's perfect as I don't pack more than 100 lbs of gear beyond the weight of the GFC. The Dakar was way too stiff for my needs.
    Willbeck likes this.
  17. Jun 26, 2018 at 9:21 AM
    #3177
    transworldmoto
    Ben
    California Coast
    Affirm, factory bed rail caps (plastic). I have the relentless fab metal tailgate cover but wanted the extra height of the bed rails to clear the Prinsu rack. Worked great!
    DoorDing and riz_atx[QUOTED] like this.
  18. Jun 26, 2018 at 9:21 AM
    #3178
    TacodileSupreme
    Thomas
    Dallas, TX
    Super White SR5
    You can adjust compression/rebound on the foxes but it will require disassembly as compared to the external bypass settings on the bp51s. It's the biggest benefit of rebuildable coil overs/shocks and allows you to change their characteristics according to your driving style and ride preference. You'll run into similar things with the boss kit (I think they are swayaways but not 100%) but the rear will ride smoother with that setup compared to a heavy lift pack. I have dakars and can say they aren't the smoothest without weight and the biggest benefit to the bp51s is their external adjustment (for bypass settings) but they will still need to be taken apart to have the main valving dialed in. Basically no setup is going to be really plug and play for optimal ride quality as that's subjective to each driver.
    Apologies for the BS in this thread and honestly either setup will be pretty sweet compared to stock. Just don't give up on your current setup as it could be pretty awesome with some work :cheers:.
  19. Jun 26, 2018 at 9:23 AM
    #3179
    transworldmoto
    Ben
    California Coast
    Ross! Sorry man, I had the pleasure of meeting so many of you yesterday I couldnt keep up! Thanks again for everything!
    08brickfjc[QUOTED] and DoorDing like this.
  20. Jun 26, 2018 at 9:30 AM
    #3180
    riz_atx
    Sohail
    Spicewood Texas
    This is fantastic news! Although I am willing to take a saw to my prinsu, I’m glad I don’t have to. We both have long beds and so this makes me super happy
