Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Sep 9, 2018 at 8:05 PM
    #4301
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    Don't have mine yet, but don't like the looks of that.
  2. Sep 9, 2018 at 8:22 PM
    #4302
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    Looks like you could grind those down a bit with a mini grinder. Should be done at the factory.
  3. Sep 9, 2018 at 8:30 PM
    #4303
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    @Sleevez - those rivets shouldn’t be making contact. I’m guessing it got assembled with the hinge too far in. If you dm me your order details I’ll have Ben, our operations manager, get in contact with you to resolve the issue. It’s an easy fix. And we have touch up paint matched to that color. But definitely don’t grind the rivets on the backside or they won’t be waterproof anymore :)
    tonered, ace7196, slowboater and 2 others like this.
  4. Sep 9, 2018 at 8:33 PM
    #4304
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Any updates on bolt upgrade packs and striker plates Wiley?
  5. Sep 9, 2018 at 8:36 PM
    #4305
    wileydavis
    Wiley
    2017 SR5
    I’m mot sure. I’ll check with Elise tomorrow. I know we have plenty of the parts.
  6. Sep 9, 2018 at 8:45 PM
    #4306
    Photoweekender
    Photoweekender Active Member
    N
    Rego Park, NY
    2016 TRDORSB Quicksand
    I love the Deckd system but I'm unsure if it leaves a bunch of unused space? I may go with it though base don the weather sealing and solid build though.
  7. Sep 9, 2018 at 8:57 PM
    #4307
    Photoweekender
    N
    Rego Park, NY
    Looking good man and the deckd system looks even better showing thru the GFC.
    are any of the latches loackable? I'm in NYC and things need to be locked down lol.
    PNWTacoma likes this.
  8. Sep 9, 2018 at 9:00 PM
    #4308
    PNWTacoma
    PNWTacoma Well-Known Member
    Paul
    PDX 3rd party OV Tuner
    2025 TRD Pro | Mudbath // 2017 Offroad DCLB OG
    PNW Adventures & PNW Tuning
    Thanks for this post. It makes it reassuring to hear since I have a decked system too and worry that it will be too hard for my 5’1” wife to get in and out of the GFC.
  9. Sep 9, 2018 at 9:59 PM
    #4309
    Borrego Taco
    Borrego Taco Well-Known Member
    2017 DCSB TRD OR 4x4
    If there is a short person using the gfc, you will want a platform, decked system, stool, cooler or fridge to make getting in easier.
    tonered and YOTA 4X4 like this.
  10. Sep 10, 2018 at 1:08 AM
    #4310
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Yep, all the operable panels have two latches, each one has a keyed lock. So 6 locks total, and of course in a Gen 3 your tail gate locks. Should be secure. I’d warn you though I’m pretty certain these panels “could” be prayed open without too much trouble if some one wanted too. They’re only aluminum. Although if you knew how easy it is to get inside a locked house you prob wouldn’t sleep as well either. Though I’m sure I’m NYC you secure all your stuff a little better.
    Keys on every lock are the same BTW.
    I’m actually kinda stumped on how i can “lock myself in”. Say i want to stealth camp at Walmart in my bed and not lift the GFC. Anyone have any idea if you can latch yourself in from the inside doesn’t need to be “locked”
    Not just for protection but really be sealed from bugs and rain. Unless the latches are closed the panels do not seal on the space frame.
  11. Sep 10, 2018 at 1:16 AM
    #4311
    YOTA 4X4
    No problem, this one gives a little better detail without the rear panel in the way. I prob look like a goon but i was pretty happy about my GFC.
    Anyway my wife is 5’4” and can get up easily in and out of the top section. She was reading and climbing up and down for a couple hours yesterday while i pulled my Decked apart and permantly mounted my tilting fridge slide!!!
    Like i mentioned without a platform, Decked or otherwise egress is not nearly as easy. I’m fact without the Decked it prob wouldn’t be super fun for me either at least at 0300 when nature calls lol...
    As mentioned a stool or step ladder would suffice. It’s worth noting though with the platform and my 63qt arb fridge installed the fridge is perfect seated height to use the 25x50 panel as a desk.... or dining room table if you can Rained in.
    ATdivide likes this.
  12. Sep 10, 2018 at 1:24 AM
    #4312
    YOTA 4X4
    I’ve got no horse in the race but I LOVE my Decked system. Absolutely zero complains. There’s a little wasted space but i can’t think of any platform system where you wouldn’t struggle somewhat. What it provides in storage and a big flat floor (above the wheels wells) is way way worth it to me. Plus to be honest the Decked holds ALL my camping gear as well as recovery. With the exception of bedding, dry good, and what’s in my fridge. They hold a lot if you plan right and have gear that fits long and narrow (I shopped spcifically around those needs).
    The only draw back i see is the weight. With my Decked AND GFC and fridge I’m 500lbs heavier before and food water or gear....
    macdadmorgan likes this.
  13. Sep 10, 2018 at 4:59 AM
    #4313
    YOTA 4X4
    Thanks DoorDing but you missed the second half of my paragraph. Say i want to sleep in my bed (of the truck only), like in Griz country or more likely stealth camping who knows where, no GFC Popped, because it’s cool but it sure isn’t stealth. Doesn’t have to be “locked” but latched would be nice since it’s not bug or water tight without being latched.... I want to latch the panels from the inside
    rajacat9 likes this.
  14. Sep 10, 2018 at 5:23 AM
    #4314
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Someone 3D printed some little pieces to do that I believe. Somewhere back in the last 2 months I think. I think they said you just close the panels and stick these “keys” in the latches to keep the latches closed and locked, without locking them from the outside
    Tacovore, tonered and ace7196 like this.
  15. Sep 10, 2018 at 5:48 AM
    #4315
    YOTA 4X4
    B1CA75C8-8C59-4336-9103-992B9E85428B.jpg CE5854DD-6EF3-47CC-A9DD-4A1B2C4236AA.jpg 28A7697B-8B28-4AEB-BEF1-C364CD15B92F.jpg 2FA0CBA6-F473-4746-862A-414CB0AE2115.jpg
    On another note a tilting fridge slide seems ideal for my application. Through bolted with stainless 5/16-18 bolts backed with fender washers. Best part is the Decked is JUST low enough that the weight of the fridge just sits on the tailgate so little to no forces on the slide or Decked when tilted.
  16. Sep 10, 2018 at 5:50 AM
    #4316
    YOTA 4X4
    I remember that.... maybe that guy/girl will jump on with more pics or sell me some lol...
  17. Sep 10, 2018 at 6:07 AM
    #4317
    I_eat_tacos
    I_eat_tacos Well-Known Member
    ace7196 and YOTA 4X4[QUOTED] like this.
  18. Sep 10, 2018 at 6:15 AM
    #4318
    YOTA 4X4
  19. Sep 10, 2018 at 6:21 AM
    #4319
    I_eat_tacos
    Np and yes I did! I knew about it for a while cause of work ;). Looks good. Have some parts to save up for since AEV is right in town. More excited about the GFC coming as it should finish production this week and I should be on Graeme's next East Coast run!
    YOTA 4X4[QUOTED] likes this.
  20. Sep 10, 2018 at 6:24 AM
    #4320
    YOTA 4X4
    Awesome! If you work for GM can you slap the bean counter that decided to put 31’s on it than..... what were they going for “almost” perfect lol
