Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Oct 7, 2018 at 11:42 PM
    #5061
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    SoCal is where ALL the damn GFC’s are. I’m surprised you don’t see one or two of them everyday at the local mall.
    Seriously though you will have no trouble finding a GFC in Southern California...
    Also for what it's worth I assure you the fulfillment target didn't really move 4 months in two days, they may have just updated it. Bottom line the sooner you order the sooner you get it. They are taking $500 deposits now to allow people to get inline before paying in full. Makes for a nice option honestly, I'd say hop in line sooner than later. Also if your in SoCal I'd imagine there are some Vagabond Drifters you could check out if you'd like to compare. GFC is awesome and my personal choice BUT if I were you and had the option to compare others and see it in person I certainly would. None of these were much more than an evolving concept when I purchased mine. I'm glad I picked GFC for the weight and durability but I certainly would have looked at the Drifter and the GFC in person if I had the option.
  2. Oct 8, 2018 at 12:58 AM
    #5062
    YOTA 4X4
    @inv3ctiv3 -Jim Bob, any chance I could get you to post some pictures and specifics on your back seat fridge install on here? I saw the clips on IG and while I run mine in the bed of the truck I know at least a few people who would be very interested in your install. It looks super tight and clean, not to mention bomb proof. Thanks in advance.
  3. Oct 8, 2018 at 12:59 AM
    #5063
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
  4. Oct 8, 2018 at 1:03 AM
    #5064
    YOTA 4X4
    rkam65 and Quadabaum[QUOTED] like this.
  5. Oct 8, 2018 at 5:23 AM
    #5065
    rkam65
    rkam65 Well-Known Member
    2013 Black Offroad Tacoma
    OMG... This is perfect! I'm doing that fridge mod for sure. Thanks and I'm gonna follow that build thread @inv3ctiv3 !
  6. Oct 8, 2018 at 7:04 AM
    #5066
    Jicka21
    Jicka21 Well-Known Member
    Sorry, I forget I’m not talking to locals...
    Salt Lake is pretty centrally located so you can get to a lot of cool places with a week off work.
    I_eat_tacos and YOTA 4X4[QUOTED] like this.
  7. Oct 8, 2018 at 7:45 AM
    #5067
    Speenbean
    Speenbean Member
    Spencer
    Utah
    I'm in SLC as well and getting my camper mid-winter if you want one to look at. Currently a build date in February. Also if you swap out your suspension let me know :)
  8. Oct 8, 2018 at 7:49 AM
    #5068
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Since someone mentioned mounting a fridge in the cab, I’ll share what I’ve used for 5 years. Not fancy, but it uses the seat hinge hardware and only takes 2 bolts to swap it out for the seat. I run a ratchet strap under the plywood to strap down my arb 50qt fridge.
    Edit: found a (messy) pic with the fridge installed.
    YOTA 4X4, rkam65 and tonered like this.
  9. Oct 8, 2018 at 8:03 AM
    #5069
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    My fridge platform is a combo of those two ideas. I removed the driver’s side seat (back and bottom) and used an extra set of hinges on the platform to make an easy swap. The hinges were drilled out to accept quick release pins so swapping the platform is fast. The platform has two eyebolts in the front and one in the rear to secure the fridge to and I use another strap from the rear handle to the child seat hook mounted to the cab body. I ran wiring from my second battery and installed a Blue Sea 12v outlet in the side of the rear plastic cubby for easy power.
    Sorry, no pictures, I’m a few thousand miles from my truck right now.
    JLink likes this.
  10. Oct 8, 2018 at 8:28 AM
    #5070
    LONGWHITELINE
    LONGWHITELINE Well-Known Member
    Martin
    2017 White Tacoma TRD Off Road DCLB
    Stock
    Does anyone know what the weight capacity of the sleeping area is?
  11. Oct 8, 2018 at 8:32 AM
    #5071
    TacodileSupreme
    TacodileSupreme ¯\_(ツ)_/¯
    Thomas
    Dallas, TX
    Super White SR5
    I believe it is rated for 400lbs. But I'll double check.
  12. Oct 8, 2018 at 9:20 AM
    #5072
    Jicka21
    Let me know when you get yours for sure. I can’t wait to see one in person.
    I’m planning on keeping things stock for now but if this TRD Pro suspension doesn’t handle the weight well I might swap it out. I’m going to keep everything modular so I can keep the bed empty day to day and load it up differently depending on what trip I’m doing. I like the idea of being up to load bikes in the back of the truck for short biking trips (instead of using a hitch rack) so I don’t want to have a bunch of permanent stuff mounted in the bed.
    rajacat9 and Tacovore like this.
  13. Oct 8, 2018 at 9:29 AM
    #5073
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    @gmacmt - any idea when you'll be passing through the bay area next? Been waiting to hear back from orders@gfcengineering.com for a week now - thought I would go direct to the source.
    Order #94, build order #54.
    YOTA 4X4, gman36 and ace7196 like this.
  14. Oct 8, 2018 at 10:32 AM
    #5074
    JLink
    Josh
    Ocean, NJ
    I agree. It was fine with just 1 dog back there, but now with 2 dogs we've relocated the fridge to the bed. I miss the convenience of having it in the cab, but I appreciate the extra room in the cab now that its in the bed.
  15. Oct 8, 2018 at 10:41 AM
    #5075
    gman36
    gman36 Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    Gonna change up the status format,
    Too many to count: Not Shipped
    39: In Production
    7: Ready to Ship
    62: Completed
  16. Oct 8, 2018 at 11:00 AM
    #5076
    I_eat_tacos
    I_eat_tacos Well-Known Member
    Pretty sure (?) they are going to shoot for a west coast run between when they get extrusion shipment on the 22nd and Nov 9th. They confirmed via email with me that they're heading to Asheville for Expo East. Mine has been in production since August 27th (maybe earlier) and looks to be affected by the shortage too. Although if yours is complete, maybe they will stop over sooner?...
  17. Oct 8, 2018 at 11:10 AM
    #5077
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Mine has been complete for a few weeks. Not sure what gives. I must not have enough follower on instagram. Need that influencer level status.
    Shellshock, jubei, gman36 and 3 others like this.
  18. Oct 8, 2018 at 11:15 AM
    #5078
    I_eat_tacos
    :rofl:I feel the pain. Mine was pushed back a bunch due to it being a Chevy ("complicated" apparently). Don't forget to include "overland" in your username and tag every company who's parts you installed.
    tonered and ace7196 like this.
  19. Oct 8, 2018 at 11:18 AM
    #5079
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    I don’t have instagram and got mine without any real issues. Are you waiting on them to deliver it?
  20. Oct 8, 2018 at 11:24 AM
    #5080
    YOTA 4X4
    What’s your IG I’ll follow. That’ll be one more if it’ll help lol.... i do feel your pain though. It’s Oct.... though i thought you had planned to go get yours???
    rkam65 likes this.
