Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Nov 25, 2018 at 12:22 PM
    #6021
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    I've been waiting a long time for my camper but a positive thing could be that many of the bugs, like leaks, will be corrected by the time I get my unit. :)
  2. Nov 25, 2018 at 1:20 PM
    #6022
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Looks good.
    How come I can see the mattress cover? Do you not have all the panels in? Are you having a hard time closing it with all the panels in place? Just curious what to expect since I don’t have my camper yet.
  3. Nov 25, 2018 at 3:04 PM
    #6023
    gman36
    gman36 Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    I’ve been leaving the two small squares out, it’s easier to close. Ive only tried to close it a few times with all the cushions in. It’s sealed up pretty well, so when you try to close it, there isn’t anywhere for the air to go and the tent get blown outward making it hard to tuck nicely. I tried with the windows part open, which helped a little.
    JLink[QUOTED] likes this.
  4. Nov 25, 2018 at 3:06 PM
    #6024
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    I went through this whole thing two back when mine arrived. The key is just to close it sloooooooooow and tuck it as you go. Once i did that no more problems. Just go slow spend maybe a min or two closing and tucking. No problems anymore.
    gman36[QUOTED] likes this.
  5. Nov 25, 2018 at 3:32 PM
    #6025
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    The concept is to raise the temperature inside enough with heat to be above the dewpoint. Challenge is the metal parts are good conductors of heat and are at the same temperature as outside. Adding insulation means the humid air inside does not contact the cold metal, and has a temperature gradient where the inside surface of the insulation is above the dew point temperature for your given humidity level.
    ace7196, rajacat9 and YOTA 4X4 like this.
  6. Nov 25, 2018 at 6:04 PM
    #6026
    YOTA 4X4
  7. Nov 25, 2018 at 7:15 PM
    #6027
    I_eat_tacos
    I_eat_tacos Well-Known Member
  8. Nov 25, 2018 at 7:21 PM
    #6028
    rajacat9
    Washington State
    A small, quite, efficient exhaust fan operating 24/7, powered off of solar and/or the house battery would help keep the GFC sweet smelling and mold free. I'd leave the fan on all the time, year around, not just when using the rig. Maybe the exhaust vent could be located on the front panel, up high in either corner. You could take a hole saw to the panel to cut the hole and install a small cowling to protect the fan from rain.
    ace7196 likes this.
  9. Nov 26, 2018 at 10:20 AM
    #6029
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    Wow, where did you find a battery operated dehumidifier?
    Edit, never mind it is the absorbing crystal type.
  10. Nov 26, 2018 at 10:23 AM
    #6030
    aaen
    Northern Alberta
    You must have responded jus as I was editing my post. I have the others, but using an inverter would suck the batteries dry in no time to power it.
    ace7196 likes this.
  11. Nov 26, 2018 at 11:54 AM
    #6031
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The Lewiston and eastern OR areas rock, even more so if you got something to carve corners with.
    OR4x4[QUOTED] likes this.
  12. Nov 26, 2018 at 2:16 PM
    #6032
    I_eat_tacos
    Right I saw those but not a huge fan cause it’s just another thing to charge lol. But the Anderson plugs sounds like a good option. I have a bed light package with a latching switch right now. For GM we have an option package that I just wired into and got a trailer harness tee to get the 12V signal. Beauty is it’s time red at 20 minutes and fused already. So it’s a great lighting solution and I am working on a better solution for full 12V without a timer. Might replace my main battery with an AGM and keep a portable starter in case. Rather not go solar or dual battery if I don’t need to.
    The ez breeze looks like the best solution since it’s passive and year round waterproof even with the vents open. I didn’t like it at first but it’s growing on me lol. The only thing I can think of is how to properly mount it to the roof panel since they all take screws? Silicone would seal, maybe an RTV and cured would hold it? Vibrations can get nasty so definitely need something robust and waterproof.
    ace7196[QUOTED] likes this.
  13. Nov 26, 2018 at 2:45 PM
    #6033
    I_eat_tacos
    Hmmm yeah maybe an that plus epoxy to glue it and then use a clear silicone to seal it? Love me some in jb weld. That’s in my trail kit. Never know when you need to fix a cracked oil pan in the boonies. Works like a champ. Should do fine with a measly fan.
    I did get to see the marinco fan in person and it really blends well and is compact. Could be a good option to get the day/night solar version as well.
  14. Nov 26, 2018 at 6:34 PM
    #6034
    I_eat_tacos
    Yeah that’s what I noticed too. Reviews weren’t too hot. The maxxfan looked awesome too. The main feature I love is a remote model. Nothing better than that!! I’m a fan of compact and simple so anything that gets me that with a 12V signal or solar is on my list.
    In the meantime winter is kicking in here and I am still waiting for new panels to be painted and the whole assembly re-shipped out east. Not missing out on too much yet since snow up north isn’t quite enough to justify a trip yet.
  15. Nov 26, 2018 at 11:10 PM
    #6035
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Can anyone comment on the upstairs airflow in hot weather (75-85 degrees)?
    I know most tents would be hot, but the small windows on the side are the reason I ask. Most of my camping is done in warmer weather climates and airflow is very important to me.
    Thanks!
  16. Nov 26, 2018 at 11:22 PM
    #6036
    YOTA 4X4
    Didn’t get mine till it was cool but... @wileydavis has repeatedly stated that the small windows are superior to larger windows due to the the pressure differential it creates (causing a force draft airflow).
    That said @inv3ctiv3 had his first and is in hot sunny California so I’m sure he will jump in if he sees this.
  17. Nov 27, 2018 at 7:10 AM
    #6037
    whitetaco16
    whitetaco16 Well-Known Member
    James
    Central NC
    2016 TRD OR Access Cab Long Bed
    Dobinson's 2.5, RCI Sliders, Mobtown Recovery Bar and Front Skid, 4.88's and Extremeaire Magnum
    I live and play in the southeast and had my GFC all summer. There were several nights when we got in the tent in the mid 80's with humidity in the 60-70's. As stated above, the cross ventilation is better than any tent I've experienced. I have a DeWalt 20v fan which we use and only one night was hot enough for us to run it all night. Normally, the cross ventilation will have you under cover before morning.
    tonered and ace7196 like this.
  18. Nov 27, 2018 at 9:38 AM
    #6038
    bigdood
    bigdood Well-Known Member
    Has anybody heard an ETA on the lighting kit? Word was a few months ago they were revising it and it'd be available soon
    henryrose likes this.
  19. Nov 27, 2018 at 9:42 AM
    #6039
    PNW Explorer
    PNW Explorer Well-Known Member
    Idaho
    2018 Tacoma TRD OR DCLB Mag Gray
    I believe they mentioned that they were focusing on production and that accessories were put on hold until January. However, I did see that they mentioned roof rack parts potentially coming out on the end of December on their Instagram story yesterday/today.
    bigdood[QUOTED] and tonered like this.
  20. Nov 27, 2018 at 7:04 PM
    #6040
    Aggie_Eng
    Aggie_Eng Member
    Time for me to join the fun! Been browsing the forum for a while and finally pulled the trigger a few months back.
    Today a package arrived from the folks at GFC. What a great way to help with the color decision and get me absolutely stoked!
    Full disclosure, I’m a ZR2 owner! Love the community here and the ideas flowing around on some great builds!
    Just got back from a 3000 mile trip to West Texas. Sure would have loved to have a GFC along for the ride.
    Can’t wait to join the GFC club!
    dskakie, rkam65, tonered and 6 others like this.
