Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Nov 29, 2018 at 3:17 PM
    #6081
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    FWIW, Most of the rockies will still be snowed in, with very little access to back roads. Depends on snowpack of course, but most of the trails here don't open until July or later.
    Early May is a good time for southern Utah, but late May and June can start getting pretty hot.
    PNW Explorer likes this.
  2. Nov 29, 2018 at 3:18 PM
    #6082
    bgraboyes
    bgraboyes Well-Known Member
    just sitting there all lonely for a few weeks at least
    tonered likes this.
  3. Nov 29, 2018 at 3:24 PM
    #6083
    PNW Explorer
    PNW Explorer Well-Known Member
    Idaho
    2018 Tacoma TRD OR DCLB Mag Gray
    @SoCalTacoTruck , to mirror what @Squeaky Penguin said, most of Glacier and Yellowstone are closed into May and June as well. Yellowstone typically opens up sooner than Glacier which can run as late as July. Last year we were still getting random snow showers into late June across the boarder of Montana and into Idaho.....this isn't sunny Southern California.
  4. Nov 29, 2018 at 3:25 PM
    #6084
    kwesterh
    kwesterh Well-Known Member
    Colorado
    2020 CM Tundra
    Deposit in... let the waiting begin.
  5. Nov 29, 2018 at 3:38 PM
    #6085
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Has anyone seen the new Prinsu Habitat Rack? Think this will work with the GFC?
    riz_atx likes this.
  6. Nov 29, 2018 at 3:49 PM
    #6086
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Looks like it to me. It says that it uses the 2 forward mount points... which is exactly what i would have left on if I cut mine down.
    Need to get some better dimensions from them on it cuz it says 66 x 10 x 10...
  7. Nov 29, 2018 at 4:02 PM
    #6087
    JoeCOVA
    Joe
    Colorado Springs
    Ya those dimensions are wierd. I'm not a fan of their pricing, they jumped the regular rack to $700 and this thing is half the rack but still over $600.
    Prinsu can pound sand on that
    rkam65 and crazysccrmd like this.
  8. Nov 29, 2018 at 4:08 PM
    #6088
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    Thanks for the advice. Didn't know that at all. Forgot how different the weather it - I figured by May, it'd be at least in the 60's and some open trails. Oops.
  9. Nov 29, 2018 at 4:10 PM
    #6089
    socalexpeditions
    Good to know. Thanks for the tip!
  10. Nov 29, 2018 at 4:13 PM
    #6090
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    GFC is developing a cab rack that will be tested in Baja thru December and could hit the market 1st quarter next year.
    Built2Ride, YOTA 4X4 and riz_atx like this.
  11. Nov 29, 2018 at 4:15 PM
    #6091
    kwesterh
    Colorado
    2020 CM Tundra
    Any pictures of this rack floating around?
  12. Nov 29, 2018 at 4:15 PM
    #6092
    socalexpeditions
    Wondering how the pricing will be now that there is "competition." I do like how GFC tests everything out though....
    My Prinsu was a solid "meh." I switched to FrontRunner pretty quickly.
  13. Nov 29, 2018 at 4:16 PM
    #6093
    JoeCOVA
    Joe
    Colorado Springs
    I'm in for this!! my GFC is scheduled for Q1
  14. Nov 29, 2018 at 5:02 PM
    #6094
    bgraboyes
    i thought it looked light too... will tell yall for sure when i pick it up
    ace7196[QUOTED] likes this.
  15. Nov 29, 2018 at 5:13 PM
    #6095
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Those knobs sure are different??? How did I miss that change. That said I can’t see the advantage over the original design????
  16. Nov 29, 2018 at 5:15 PM
    #6096
    Quadabaum
    So i made it back to civilization last Sunday and wanted to share my experience with everyone. I like data so here is a little for you all.
    2017 Tacoma TRDOR DCSB 4x4
    Relevant Mods: 265/75R16 Falken Wildpeaks, ADS 2.5" suspension with RR and clickers, HD Dakars in the rear, simple bed platform (NO armor)
    Gear weight: Id guess 250-300lbs range plus 250lbs? for the GFC
    Order date: 4/17
    Build start date: 9/23
    Build completion date: 11/9 (they had the supplier hiccups, Graeme said ~3 weeks start to finish is the typical timeline)
    Install date: 11/18
    Trip miles: ~5,000. Macon, GA to Bozeman, MT to Jackson, WY to Moab, UT to South Rim Grand Canyon, AZ to Macon, GA
    Days: Roughly 10. Departed Macon 11/15 at 4pm and made it home to Macon 11/25 7pm
    MPG average on the way to install: 17.5mpg (2109 miles, 8 fill ups, fill up @1/4 tank, cruise control top constant speed of 70mph)
    Best mpg:19.4
    Worst mpg:15.3
    MPG average post install: 17.3mpg (2901 miles, 12 fill ups, fill up @1/4 tank, cruise control top constant speed of 70mph)
    Best mpg:20.5
    Worst mpg:14.5
    Install time: under 2hrs, possible under 1.5hrs but I wasnt timing (more on this experience below)
    Nights slept in GFC: 7
    Temperature range: Mid teens with snow up to 40F at night
    Install
    On the way to the install we slept in the truck 2 nights and hotel for a shower 1 night. We arrived at the GFC facility on Sunday 11/18 at 1pm for install as agreed with Elise. Mathias (I believe thats the installers name, I am bad with names, drives a land cruiser) did the install and was an awesome host. They have installs down to a science and it was smooth, I also got a new "improvement" that includes a mini anderson plug for the taillight for when you need to remove the camper (these will be rolling out). To top it all off, @gmacmt Graeme came to the shop, on a Sunday afternoon, after bombing it from Arizona the previous day to give us a personal tour of the entire facility(s), walk us through the processes, the improvements, what it took to go from nothing to what they have, and give us some insight into the company. And, there were 2 other employees in the fabric town working that day to get some orders done and they walked us thru the fabric side of the process. Them being there was a surprise and they were pleased to be there and talk to us. These people seriously love what they do, what theyre a part of, and the customers, it was eye opening. Side note, there were a ton of campers and RTT's completed everywhere and Graeme was excited to be celebrating camper #100 being assembled that week. To top this all off, they even helped install my Eezi-awn awning to the GFC even though I was going to do it myself. Mathias and Graeme were excited to install it and had me show it off (I failed to open it being my 1st time, lol) and took measurements to develop some awning brackets. Graeme also walked us thru the open and closing process with some pro tips. I can not say enough good things about everyone and the whole experience.
    GFC
    I have to echo what everyone has said every time, seeing one and using one yourself is mind blowing. The quality and attention to detail is unreal. The wife and I loved it and it really made a difference in our quality of life and experience. These GFCs are a work of art and are highly functional. I love cabana mode, ended up not even using the awning on the trip. Being able to access the entire truck with the doors is awesome. For closing the tent we leave 2 cushions out and open the small windows, I just find it easier to close this way with mine being new and not "broken in". We used a Mr Buddy heater and it gets hot in the tent with it on. We also used large 2 person sleeping bag and slept comfortably every night, the cushions are super comfy. We also used the cushions downstairs with the heater on the hang out in the bed of the truck. My wife always has to get up to use the restroom thru the night but she was able to remove cushions and open the doors without much trouble, although she wasnt always pleased with the process just because she had to get up and pee in freezing weather. We are still learning and trying configurations but the GFC opens up a realm of possibilities.
    Driving
    After the install I did adjust my suspension firmness from ~5 clicks to 10 clicks then settled on 12 when driving the mountain roads. The clickers come in handy for sure, for DD and loadout configs. I did attempt some spirited driving on some dirt roads and turned the clickers to 15 for some sliding, corrugations, and small "jumps". You can hardly tell the weight of the GFC is there and being able to adjust for weight and driving styles is nice. These campers are dialed in pieces of equipment and once your truck is dialed in you will be amazed. I am still learning and adjusting but its a great experience.
    TL,DR: You will not be disappointed and it is worth the wait. I am sure I left a lot out or could add a lot more detail but I will leave that up to your imagination. We enjoyed our 1st time out West and cant wait to go back. The GFC is a game changer.
    Planned trips: Tray mountain 12/14, Talladega NF 12/22-23, and Ozark NF 12/26-1/1
  17. Nov 29, 2018 at 5:16 PM
    #6097
    Quadabaum
    Pretty sure @ace7196 3d printed those. You can see the layers if you look closely.
    ace7196 and PNW Explorer like this.
  18. Nov 29, 2018 at 5:49 PM
    #6098
    YOTA 4X4
    Yeah i can see they’re 3D printed, but it looks like a GFC logo on them. I guess if they were GFC they would be machined not printed.
  19. Nov 29, 2018 at 6:02 PM
    #6099
    YOTA 4X4
    I seriously doubt GFC will mind. Being as it’s on a GFC. Looks cool.
  20. Nov 29, 2018 at 6:10 PM
    #6100
    YOTA 4X4
    I ran my buddy heater all night “down stairs” with one panel removed off my 5lb tank. Worked awesome temps were ideal in the tent it was 20 outside. I have no insulation in mine. Kept the side windows open about 4” on both sides. Had little to no condensation at all.
