Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Dec 5, 2018 at 12:58 PM
    #6221
    ervandew
    ervandew Well-Known Member
    for those wonder what the boot is:
    butters_ and tonered like this.
  2. Dec 5, 2018 at 1:27 PM
    #6222
    butters_
    butters_ Well-Known Member
    Mammoth Lakes, Ca
    2000 4x4 trd manual
    Not enough
    it wasnt easy for me, i sure could use a remote start. or and long stick to press the clutch start cancel button and then another to turn the key.:rofl:
    tonered[QUOTED] likes this.
  3. Dec 5, 2018 at 1:29 PM
    #6223
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Ha!
    My luck, I'd drop both sticks.
  4. Dec 5, 2018 at 1:34 PM
    #6224
    butters_
    Mammoth Lakes, Ca
    2000 4x4 trd manual
    Not enough
    right spend like 10mins trying and breaking things when you could just hop out and turn in on like that. haha
  5. Dec 5, 2018 at 2:03 PM
    #6225
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    chopped prinsu or new roof rack?
    PNW Explorer likes this.
  6. Dec 5, 2018 at 2:23 PM
    #6226
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    They are sold at Lowe’s as well, that’s where I picked mine up from.
    socalktk[QUOTED] likes this.
  7. Dec 5, 2018 at 2:26 PM
    #6227
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I wasn't thinking about often. Hell, I only wash once every couple months, if that. Maybe a couple times a year depending on visibility? I hear you though.
    If I had another couple feet of garage ceiling clearance, I might consider doing something really bad for my marriage.
    Nice tool! I bet a rubber band or small zip tie would do it? Just curious what you measured gap is?
    ace7196[QUOTED] likes this.
  8. Dec 5, 2018 at 2:30 PM
    #6228
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Not sure how often you plan to clean, but what about throwing a few pieces of PVC between the gfc and the bed rails to roll it back little?
    The clearance on my 2nd gen access cab is very tight - .5 to .25" just eyeballing it. Tough to envision getting any sort of rag on a stick between there and being able to do a very good job.
    tonered and ace7196[QUOTED] like this.
  9. Dec 5, 2018 at 2:35 PM
    #6229
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For me, it is fingerprints! I am doing okay with water spots on both the hood and windows, except the side mirrors.
    That eBay stick looks neat. I was going to suggest a carbon fiber rod but guessed that it would flex too much also.
    It sounds like there is a workable amount of room if you have something stiff enough. Haha!
    Maybe enough room for window slide on the outside. Dreaming big. :D
  10. Dec 5, 2018 at 2:39 PM
    #6230
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    I don't think it's going anywhere too fast - the bulb seal is going to create a lot of friction.
    Other idea - if you are able to get the fixed sides of the cab window with your cleaning stick - you might be able to get the sliding center pane by stuffing the right sized rolled up rag in there with the window open, and then open and closing it a few times.
  11. Dec 5, 2018 at 2:51 PM
    #6231
    butters_
    Mammoth Lakes, Ca
    2000 4x4 trd manual
    Not enough
    couldn't you go from inside the cab to atleast clean the window, your extension mod looks like it could work well for everything else.
    tonered likes this.
  12. Dec 5, 2018 at 3:10 PM
    #6232
    The Smith
    The Smith Well-Known Member
    Trinity Alps
    '17 4x4 V6 SR5
    @ace7196
    If you've posted about your bike rack set-up before, maybe you can link me to it; otherwise, I'm really interested in what you've got going there. Thanks in advance.
  13. Dec 5, 2018 at 3:36 PM
    #6233
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    It does. And everyone who's tested it so far says it's as comfortable as the 3" one in the campers. It's a dual density laminate.
  14. Dec 5, 2018 at 3:52 PM
    #6234
    wileydavis
    Wiley
    2017 SR5
    Fabric Town is making up a 2" camper set for testing in Baja at the end of the year. Our plan is to eventually switch the campers to a 2" mattress if it tests well. I can't say at all when that switch would occur but if it does, then a 2" cushion set would be available as a retrofit.
    On a side note, I actually have one of those Enlightened Equipment Itasca down quilts on the way. It's the perfect size and will compress down as much as anything can. I'll report back once I've used it.
    JLink, gman36, Quadabaum and 3 others like this.
  15. Dec 5, 2018 at 4:49 PM
    #6235
    socalexpeditions
    They did - Totally forgot about that.
  16. Dec 5, 2018 at 5:08 PM
    #6236
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Prinsu does a half rack that costs more than the full rack did last year. There’s a very similar design made by another guy on the forums for much cheaper that can also make a half length rack.
  17. Dec 5, 2018 at 5:14 PM
    #6237
    slowboater
    slowboater Well-Known Member
    now delivery scheduled for friday. keeping my fingers crossed.
  18. Dec 5, 2018 at 6:01 PM
    #6238
    The Smith
    Trinity Alps
    '17 4x4 V6 SR5
    Thanks!
  19. Dec 5, 2018 at 9:53 PM
    #6239
    butters_
    Mammoth Lakes, Ca
    2000 4x4 trd manual
    Not enough
  20. Dec 5, 2018 at 10:22 PM
    #6240
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    I have one also, got an ebay deal at $65. Havent had to use it but is good insurance. Especially since I run my fridge.
    butters_ and ace7196[QUOTED] like this.
