Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016+)' started by wileydavis, Oct 23, 2017.
  1. Dec 26, 2018 at 9:35 PM
    #7121
    ace7196
    ace7196 Well-Known Member
    2017 Tacoma SR5 4X4 V6 DCLB
    GFC Mods: http://bit.ly/GFCMods
    Never had a sunrise at 4:45 :D Unless you're being hyperbolic :)
  2. Dec 26, 2018 at 9:49 PM
    #7122
    trouttaco
    trouttaco Well-Known Member
    Portland, Oregon
    I wish we could go back to arguing about locks.
    tonered and YOTA 4X4 like this.
  3. Dec 26, 2018 at 10:28 PM
    #7123
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    Up there in Fairbanks I suspect you worry more about bears than burglars.:D
    I've never been that far North, been through Anchorage though, on the way back from tendering herring in Bristol Bay.
  4. Dec 27, 2018 at 6:36 AM
    #7124
    crazysccrmd
    crazysccrmd Well-Known Member
    dlo13, tonered, trouttaco and 3 others like this.
  5. Dec 27, 2018 at 9:13 AM
    #7125
    PaulK
    PaulK Life is hard. It's harder if you're stupid.
    Paul
    Dublin, OH (but still a Pittsburgh guy)
    2013 Black Baja Access Cab
    I'm waiting for a lock for the top too. My trips will likely be a combination of camping and hotels, and I want it locked up when I'm at the latter. Locking the panels is worthless if someone can just open the top and steal my gear. Nothing will stop a crowbar user or a window breaker, but why make it simple and obvious for the opportunists? Just seeing a lock might be enough discouragement. In my mind the locks have nothing to do with anything when I'm in the camper, but are only there for situations when I'm away from the truck. Even though you could get into the cab with a rock, I still lock my doors when I park the truck in public areas. Why wouldn't you do the same in back?
    Jicka21 and rajacat9 like this.
  6. Dec 27, 2018 at 9:38 AM
    #7126
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Most people that I've shown the shell to are confused about how the latches on the lower panels even work. Many don't even realize that the side panels can be opened. When you tell them the top pops up they don't get it at all.
    If someone is thinking about stealing something out of the truck they're going to pry the rear panel open and not waste their time fiddling with strange latches up on the roof they have never seen - clawing their way up into a tent they will have to unzip - and then figure out how the sleeping panels work to get down to the goods.
    Understand that BadMan isn't keeping up on the latest trends in "Camper Couture" and is going to hope you have some power tools back there because it looks like you may work as a plumber. He's going to treat it like any other camper shell.
  7. Dec 27, 2018 at 9:53 AM
    #7127
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Actual camper content!
    mYm6QTrW61pIjOlUWGGycADcXAS10EKzhg8AciNK_9410cffe4411fd220dbd79bc066e996487e78e9a.jpg
    Made this little power center with ciggy 12V, USB, and Power Pole connections. I also put a blue sea fuse block behind the panel with circuits for lights. It's all fed from my aux battery under the hood with 8 gauge wire.
    dA0zhnYZ8ZT5Gqhrl-ziNYp9Licjr0nJUR_PZsuV_4a43f0e7e3408e58f5a190b0c196769c3f6b0f08.jpg
    Also found some 90 degree aluminum led channel/diffuser that fit perfectly between the space frame and the lip for the sleeping cushions. It runs down both sides and across the tailgate area.
    More in the works.
  8. Dec 27, 2018 at 10:33 AM
    #7128
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    This would be easy to fab up your own solution. However, idk why anyone would want their bike to stick out that far and have the handle bars like that. That is just stupid.
    When I was messing about with mounting bikes I did this.
    Just rotate the damn handle bars. haha
    Never finished the mounts but would be simple enough to make something.
    ace7196 and kwood4life like this.
  9. Dec 27, 2018 at 11:19 AM
    #7129
    ETAV8R
    ETAV8R Out DERP'n
    Republik of Kalifornia
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Looks good. I'm almost done with my 6gang with voltmeter, dual USB, and 12v.
    Aggie_Eng, VE7OSR, smelly621 and 6 others like this.
  10. Dec 27, 2018 at 11:51 AM
    #7130
    ace7196
    Nice!
    Link to the channel?
  11. Dec 27, 2018 at 11:53 AM
    #7131
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Approximately how big is that space where the channel is? Just curious
  12. Dec 27, 2018 at 2:31 PM
    #7132
    ace7196
    The space frame is 1.5" OD.
    The lip that supports the bedding extended beyond tangent to the frame, if that makes sense.
    I'm guessing at least 1" from tangent (at the top) to the end of the lip.
  13. Dec 27, 2018 at 3:24 PM
    #7133
    JLink
    Josh
    Ocean, NJ
    Ok I think I understand that. Thanks
    ace7196 likes this.
  14. Dec 27, 2018 at 8:14 PM
    #7134
    trouttaco
    Portland, Oregon
    Sweet lil penis!
    BEAR_KNIFE_FIGHT likes this.
  15. Dec 27, 2018 at 11:29 PM
    #7135
    gman36
    gman36 Well-Known Member
    San Diego, CA
    2018 Cement DCSB OR
    Finally mounted my front runner tracks to strap down boxes and gear!
    Edit, also added a waterport in the back
  16. Dec 28, 2018 at 6:29 AM
    #7136
    MapJunkie
    MapJunkie Active Member
    2015 Tacoma OffRoad
    @gman36, are those two tracks from the Front Runner Roof Rack? I like your solution for holding the Wolf Packs in place.
  17. Dec 28, 2018 at 6:42 AM
    #7137
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2013 DCLB...Drifter ordered
    @gman36 Do you have info on your drawer setup? Is that all frontrunner gear?
    That's almost exactly what I'm hoping to build, bike fork mount and all.
  18. Dec 28, 2018 at 7:37 AM
    #7138
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
  19. Dec 28, 2018 at 7:43 AM
    #7139
    gman36
    San Diego, CA
    2018 Cement DCSB OR
    They are front runner cargo tracks, I wanted L-track, but I got a deal through a friend. L-track is nice cause it’s so widely used.
  20. Dec 28, 2018 at 7:45 AM
    #7140
    gman36
    San Diego, CA
    2018 Cement DCSB OR
    I have measuments somewhere, I made it all at home from wood. Should be more pics through this thread, but pm me if you have other questions.
