Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Jan 28, 2018 at 8:26 AM
    #721
    slowboater
    slowboater Well-Known Member
  2. Jan 30, 2018 at 7:42 AM
    #722
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    @DoorDing - the bed rail reinforcements should be just fine as long as the utility track inside the bed is still usable.
    As for locking, there will be a latch to lock the rear hatch from the Inside. If you were worried about someone closing the outside latches on you you could lock them in the open position. They’re also reachable from the rear tent door worst case scenario :)
    As for wind, the tent does very well in the wind. Better than a ground tent and better than a soft roofed rtt. If we get a wind storm I’ll shoot some video. But I weathered a two violent pacific rain storms down in Baja recently and the tent did great when parked both into and away from the wind. Everything inside stayed dry as well.
    The lower panels would definitely flex in 30 mph winds but they won’t come off or be damaged. The panels are flexible by design not perfectly rigid. But they’re .080” 5052 aluminum and really tough. I purposely abused them on the Baja trip and they took it without issue. But if you did ever damage one they’ll be available individually and are easily replaced.
  3. Jan 30, 2018 at 7:50 AM
    #723
    wileydavis
    Wiley
    2017 SR5
    We are working on a fan solution that will be less cfm and draw than a fantastic fan and will work well with the steep roof pitch. That said, I have yet to find a need for a fan. And I say that as someone who used to own a converted van in which the fan was absolutely necessary.
  4. Jan 30, 2018 at 8:52 AM
    #724
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Every time I think every question has been asked (and answered) something else comes to mind. I know @wileydavis you mentioned here (or on ExPo) that a full sized cooler can be passed through the side openings; will this be true on the short bed version as well? Have you proto’ed a short bed (5’) yet? Thanks.
    ace7196 likes this.
  5. Jan 30, 2018 at 9:11 AM
    #725
    wileydavis
    Wiley
    2017 SR5
    We have the short bed version designed but not yet built (building one this month though.) The side access will be a little tighter. An 8 gallon Action packer will fit but not a Tundra 45 cooler, for example. I found that I never really loaded anything from the side openings but did use them all the time for access. It was always easier to load big items from the tailgate.
    Jim Bob likes this.
  6. Jan 30, 2018 at 9:13 AM
    #726
    wileydavis
    Wiley
    2017 SR5
    The two side windows and the rear door both have rain flaps that zip to cover the entire mesh opening. So they're very well protected.
  7. Jan 30, 2018 at 9:19 AM
    #727
    wileydavis
    Wiley
    2017 SR5
    We recommend always leaving a floor panel open if you can. If you do that, it doesn't take long for the whole thing to dry out with a bit of driving, even without a fan. I frequently close the whole thing up when wet. The frame was designed to block rain but flow air when closed and has proven to be very effective at drying things out.
    bigdood, DoorDing and ace7196[QUOTED] like this.
  8. Jan 30, 2018 at 9:24 AM
    #728
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    or you can always install one of these on the side panel to help air circulation :D
  9. Jan 30, 2018 at 9:31 AM
    #729
    slowboater
  10. Jan 30, 2018 at 9:46 AM
    #730
    dman100
    2016 TRD OR DCSB
    Yeah, I understand there are a lot of compromises with the short bed framing, and you’re right, lifting big stuff over the side is tough anyway ... My interest in the side accesss is because on our longer trips, we often have bikes on a rear hitch rack, which only allow my liftgate to open a few inches. Though I can lower the bikes (and do) for full rear access at stops. And since I don’t have windoors now, any side access at all would be a huge improvement ... the critical items that need to go in would be adding ice and food/beer to a cooler which would already be in the bed. Or pulling out a beer :) Thanks.
  11. Jan 30, 2018 at 10:18 AM
    #731
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    all of that should be super easy to access with how big the panels are. Way easier than a windoor.
    the things i think about from the side access for quick access are: Chainsaw, shovel, Axe, Tools. This is for quick simple trail fix situations. The bars might impede on getting something long like a shovel or axe out a bit, but certainly not that bad.
    Willbeck and DoorDing like this.
  12. Jan 30, 2018 at 10:20 AM
    #732
    bagtagley
    bagtagley Well-Known Member
    My bike and gear live under the topper during the summer. Currently the front and side sliders are 1/4 open all the time, allowing for some airflow. I live in VA, so during the stickiest times, stuff just stays damp. But that little bit of airflow is the difference between stuff just being damp and stuff rotting and mildewing. I’d planned to leave the sides “cracked” all the time. Hopefully that’s not an issue while driving?
  13. Jan 30, 2018 at 1:46 PM
    #733
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    I'd like a Fantastic Fan and some LED lights up in the tent part. Fantastic Fans are... well.. FANTASTIC. Holy crap they move a ton of air!
  14. Jan 31, 2018 at 5:06 PM
    #734
    wileydavis
    Wiley
    2017 SR5
    That's correct. :ohsnap:
  15. Jan 31, 2018 at 5:15 PM
    #735
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    YAAASSSSSSSSSSSS
  16. Jan 31, 2018 at 5:16 PM
    #736
    here4cake
    here4cake Well-Known Member
    Now I'm tempted to ask for breakfast to be thrown in! :D
    The_Black_Pearl likes this.
  17. Jan 31, 2018 at 8:53 PM
    #737
    Corverde
    Corverde Active Member
    Oregon
    2016 Gray Tacoma SR5 ACLB
    I am interested in the ability to set up the seating area (as pictured below).
    I didn't see anything in the photos from your trip to Baja with the prototype with this configuration.
    Is this still planned to be available with the base camper?
  18. Jan 31, 2018 at 9:34 PM
    #738
    wileydavis
    Wiley
    2017 SR5
    The floor panels and cushions fit in that location but the base model won't have specific bracketry for making a couch. A lot depends on how you end up setting up the back. In Baja I just set the panels on a storage box to make a couch in the configuration shown. We have plans for interior options that can be added later, such as a bed platform, couch hardware, etc., but those won't be available right out of the gate.
    Willbeck and tonered like this.
  19. Jan 31, 2018 at 9:42 PM
    #739
    wileydavis
    Wiley
    2017 SR5
    3" foam mattress and most likely Sunbrella covers.
    Willbeck, slowboater and tonered like this.
  20. Jan 31, 2018 at 11:00 PM
    #740
    angryskittle
    angryskittle Active Member
    Matthew
    PDX
    2017 Inferno DCLB OR
    Same. I've told myself I'm 75% committed to purchase but I want to see more about the interior options before I commit. I guess I have commitment issues.
