Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Mar 5, 2019 at 9:49 AM
    #7661
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just in case, the thread title and pics on the website have been changes to a single twin scroll turbo. Depending on the design, they can spool early and quickly.
  2. Mar 5, 2019 at 9:51 AM
    #7662
    kceastsparks
    kceastsparks Fkn Kyle
    Kyle
    Sparks, NV
    2015 DCSB, SOLD 2010 DCLB, RIP 2017 DCSB
    The turbo setup could be great for sure, but that’s not going to change the main issue you’re having which is your gear ratio. And I’d be willing to bet gears are going to be quite a bit cheaper than a turbo kit.
    But you do you :thumbsup:
    tacomgee likes this.
  3. Mar 5, 2019 at 10:02 AM
    #7663
    Gimmeanm3
    Gimmeanm3 Well-Known Member
    David
    Denver, CO
    '18 DC LB TRDOR / 2011 BMW 1M
    Yeah, I understand the twin scroll set up. BMW's N55 used this which is the motor that came after the N54 in my 1M. The N54 uses two and it's regarded as a better platform that the N55. Not that that is necessarily the reason for that, but two is always better than one, right? ;)
    I doubt it will be cheaper, but I'm not ready to put more money into this right now either way so there will be options when/if I decide to do anything.
  4. Mar 5, 2019 at 10:14 AM
    #7664
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It always depends. :D
    We've only had single turbos. A couple took some light massaging to get good, early spool. This last one spools like a freaking diesel.
    Twin are better, esp if one is a bit bigger.
    Gimmeanm3[QUOTED] likes this.
  5. Mar 5, 2019 at 10:18 AM
    #7665
    TacomArizona
    TacomArizona Well-Known Member
    15' ACOR 2wd 4.0
    C'mon "Components Produced" change to "In Assembly" !!:annoyed:
  6. Mar 5, 2019 at 10:30 AM
    #7666
    lburgwv
    lburgwv Well-Known Member
    2018 TRD OFFROAD, Magnetic
    Yeah Im with ya, what number are you?? I imagine this leaderboard is going to see some big changes soon (hoping) as there seem to be a lot out at powdercoat. I am #198 and went to powdercoat on Feb 14th.
  7. Mar 5, 2019 at 10:33 AM
    #7667
    the_tacocamper
    the_tacocamper The Taco Camper
    Tyler
    Portland, Oregon
    2017 Tacoma DCSB 4x4
    -Prinsu designs cab rack -Southern Style slimline bumper -Smittybuilt XRC 9500 lbs winch -Cascadia 4x4 flipster -CBI off road ditch might brackets -KChilite flex dual ditch lights -Mountain Hatch tailgate reinforcement -Cali Raised LED faux TRD Pro grille -Cali Rasied LED bed stiffeners -Cali Raised LED 25 degree sliders -RCI metal works bed rack -RCI front skid plate -CVT Mt. Shasta Rooftop tent -K&N cold air intake -Tinted windows 15% -Chrome deleted (emblems/bumper) -Full size spare -OEM bed mat -Maxxtraxx SUSPENSION: -ARB BP-51s suspension w/reservoirs -OME heavy duty dakars -OME heavy springs -BFGoodrich KO2 285/70r17 -Method Roost race wheels INTERIOR: -Marathon seat covers -Hondo Garage phone mount -Ram ball mounts -Ram squeeze mount -LED interior lighting -Attic by Blue Ridge Overland -Weathertech Floor mats -Tacoma red dash inlay CAMP GEAR -Tembo Tusk skottle -Front Runner wolf packs (2) -Ruger 10/22 breakdown rifle -Waterport pressurized water system -Yeti Panga 28 backpack w/dry sidekick -Yeti Panga 50 duffel bag -Yeti Roadie 20 cooler -Rtic 65 cooler -Fiskars chopping axe and hatchet -Hyke and Byke down sleeping bag -10x10 Coleman easy up -Coleman two burner stove FUTURE MODS: -GFC Camper #184 (mid February-March) -CBI Rear bumper w/tire swingout -Bed drawer system -Bed lighting system -Wilco Offroad spare tire bedrail mount
    I also went into "Components Produced" and had everything sent to powder coat on 2/14 and I'm build #184
  8. Mar 5, 2019 at 10:34 AM
    #7668
    I_eat_tacos
    I_eat_tacos Well-Known Member
    That turbocharger is not going to build boost where you want it. You'll be exacerbating the situation. The airflow for that turbo is high up, 3-4k is where it builds boost. Even if you modulate the exhaust pulses, scavenge air to the turbo and keep it a true twin scroll you won't be able to spool up fast enough to achieve what you are talking about. It would be way more effective to use a centrifugal supercharger like magnuson. A centrifugal will make the 3.5L wake up real fast and where you want it; often times it results in better fuel economy because it can keep top gear uphills, etc. A much better use of your money would be going that route.
    Your issue is more the 3.5L to begin with. The Atkinson cycle should have never been used for that truck, the torque request under higher dynamic loads just isn't able to be achieved with that engine due to the torque curve, so it compensates by downshifting to get to the torque. Atkinson cycle uses the power stroke to build piston speed faster, which means that engine was basically built to rev out, not make power down low. Gears would definitely help especially with that much added weight/drag/rolling resistance, but a magnuson will do much better.
  9. Mar 5, 2019 at 10:44 AM
    #7669
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    As a note that I would guess that you know, the Atkinson cycle on this motor is simulated by the VVT. Even better, OVT dropped tunes for the MTs that deletes it for the most part. I am finishing up my first full tank on that tune and do like the much improved low end grunt. It is looking like MPGs are holding to pre-tune levels.
  10. Mar 5, 2019 at 10:57 AM
    #7670
    TacodileSupreme
    TacodileSupreme ¯\_(ツ)_/¯
    Thomas
    Dallas, TX
    Super White SR5
    Welcome to the club @riz_atx. Looks great.
    riz_atx likes this.
  11. Mar 5, 2019 at 11:01 AM
    #7671
    I_eat_tacos
    Wasn't aware that they adjusted the cam timing to delete the Atkinson variation. I'd expect less MPG on a flat road with normal loads, but same or more MPG with load if you can actually keep 6th gear going into wind or up a small grade. Either way looking at their dyno graphs the improvement is about 12% down low, but max torque is still far out of reach; gears with a tune will probably get most of normal driveability back. I just highly doubt that that turbo kit will be able to spool below 3k which means you'll be downshifting on the highway to get to the boost. With a 6 speed you will really notice those changes, it'll feel like a roller coaster lol.
    tonered[QUOTED] likes this.
  12. Mar 5, 2019 at 11:07 AM
    #7672
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It was a recent, special request that got spammed out as an option for the MT tunes. The MT folks also got the 7k rev limit kicked off. That's just a hoot, where I can finally feel the power dropping off.
    A well designed turbo kit could spool earlier. Our saab had a decent sized turbo for the motor (almost no taper near the rev limit). I could get nice spool below 2k and solid boost right around there. It just depends.
  13. Mar 5, 2019 at 11:13 AM
    #7673
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Thanks!! So stoked here! Can't believe it's here!
  14. Mar 5, 2019 at 11:23 AM
    #7674
    I_eat_tacos
    Right. Not saying a better matched turbo wouldn't produce tq down low, but that specific borg warner they are advertising to be using is just not going to cut it for torque down low. The reason the smaller ecoboost engines get good economy is cause they have 2 separate tiny turbos that make up for the displacement loss. More air down low is what you want especially with this engine. I'd caution a bit to downshifts especially with a manual, super easy to over-rev and float a valve. Either way I expect Toyota to replace this V6 with a inline 4 turbo in the next few years.
  15. Mar 5, 2019 at 11:29 AM
    #7675
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nice catch!
    That is the great thing about a twin setup and the other possible ways to plumb them.
    A turbo 4 would be a great option. Although, it might not be a good idea to replace the V6. It will be interesting to see how it all develops.
    :cheers:
  16. Mar 5, 2019 at 11:46 AM
    #7676
    I_eat_tacos
    See the issue is CAFE and EPA. They are in the business to make money and the way the regulations are set you can go two paths. Path 1: Keep current vehicle wheelbase and size and downsize the engine to get economy up; Path 2: Keep economy the same and increase the wheelbase and overall size. You can't have it both ways and either option costs more money which is why everything costs so much now since the green agenda is being burdened onto the consumer. I think with Ford and GM going with those options now and the future Toyota will have to innovate fast enough and still meet emissions and CAFE targets, but that means 4 cylinder will be an option or replacement. Just depends where you want to make money. Fiat just sells a bunch of muscle cars with poor economy and pays Tesla for ZEV credits and the gvmt for CAFE violations, but they make enough money that way it's feasible. Pick your poison...
  17. Mar 5, 2019 at 11:50 AM
    #7677
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is difficult, but we are still living in a golden age of power. I remember my parents thinking that V8 were dead 30yrs ago. They're still alive and doing well by playing the rules. The next decade or so is going to be pretty wild for many aspects.
  18. Mar 5, 2019 at 12:01 PM
    #7678
    Gimmeanm3
    David
    Denver, CO
    Interesting. I know that's why BMW had to phase out the N55 in the M2; it just didn't meet the emissions requirements. So they shoved the 'real' M motor from the M3 into it, the S55 and now call it the 'M2 Competition'. Poor owners of the original M2 are going to see their depreciation go through the roof...something we Tacoma owners never see!
    I agree, although I think we are at the end of an era for ICE sports cars with manual transmissions on offer that you can actually drive yourself without interference from all of the mandated safety systems. Grab them while you can.
  19. Mar 5, 2019 at 12:04 PM
    #7679
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is very true. With that, I lost any enjoyment for the exotics.
    I did my part with the nice basic Taco. Non-Tech / Non-Prem MT pre-TSS-P.
    On the sporty side, I got my bike. That will alway be my speed and cornering fix.
  20. Mar 5, 2019 at 12:13 PM
    #7680
    TacomArizona
    15' ACOR 2wd 4.0
    I should be part of the next 10 frames back from PC.
    Email Feb 1st. - frame welded, panels formed and out to Powder Coat.
    Memory serves correctly someone 10 or more pages back showed that PC was a 4-5 week process (minus setbacks) b4 going to "in assembly" if that sounds right? 4th week was last Fri.:goingcrazy::frusty:
