Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Mar 7, 2019 at 7:51 PM
    #7701
    TacomArizona
    TacomArizona Well-Known Member
    15' ACOR 2wd 4.0
    Same here, only delivered.
  2. Mar 7, 2019 at 8:39 PM
    #7702
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    X2. I like the look of the growler. I’ll have to stop there too.
    And I just got the “in production email”!
    :woot:
  3. Mar 7, 2019 at 9:22 PM
    #7703
    vdubtaco
    vdubtaco Active Member
    Anybody with a second gen have any issues with the bed rail caps and sealing? I was looking at the Voodoo bed rail caps, but with the recent issues I have read I am nervous to purchase them. As of now just planning on leaving the stock rail caps.
  4. Mar 7, 2019 at 9:36 PM
    #7704
    Double Down
    Double Down Well-Known Member
    Colorado Springs, CO
    '23 ACLB TRD OR
    Magnuson, King, OVRLND, Deaver, Method, BFG
    I plan to install mine on my 2nd Gen this weekend before I pick up the GFC next week.
    Other than being sure to seal the bedsides underneath before you put the caps on with aluminum foil tape or similar, I haven’t heard of any issues.
    What issues have you heard?
    PNWTacoma likes this.
  5. Mar 7, 2019 at 9:40 PM
    #7705
    vdubtaco
    I have read the voodoo rail caps are having issues with rusting and not being powder coated properly.
  6. Mar 7, 2019 at 9:57 PM
    #7706
    nartmot
    nartmot Well-Known Member
    I don't have the KB rail caps but did own a set of his cross bars. They were rusting badly after a few weeks in SoCal weather. I emailed him to see if there was anything he could do for me and never got a response. I decided it wasn't worth my time and ended up selling them for a deep discount a few weeks ago. I think I read that the issues with powder coating are resolved now but for obvious reasons I decided to stick with the stock caps after sealing them.
  7. Mar 7, 2019 at 10:00 PM
    #7707
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The issues are definitely not resolved, he just keeps saying the defects are a normal part of powder coating and it’s not his fault.
    Tacoless and nartmot[QUOTED] like this.
  8. Mar 8, 2019 at 5:08 AM
    #7708
    2ayne
    2ayne Well-Known Member
    Zayne
    Ohio
    2017 Cement TRD Pro
    When did yours go “In Production Notified”?
    Mine went today. Just trying to get a timeline.
  9. Mar 8, 2019 at 5:31 AM
    #7709
    lburgwv
    lburgwv Well-Known Member
    2018 TRD OFFROAD, Magnetic
    Yeah they are assembling them fast once they come in
    pics...send.
  10. Mar 8, 2019 at 6:07 AM
    #7710
    TacodileSupreme
    TacodileSupreme ¯\_(ツ)_/¯
    Thomas
    Dallas, TX
    Super White SR5
    I have the caps and they are rusting as well. But the newer caps are made of aluminum so even if the coat flakes you'll be okay as far as rust goes. KBVoodoo may not be the best to deal with but for now they are the only ones making caps and they are leaps and bounds better than the factory crap. Use foil tape and silicone to seal them up and you're good to go. The factory caps clip into the bed holes so they may be more difficult to seal up.
  11. Mar 8, 2019 at 7:44 AM
    #7711
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    What does "Sealant Curing" entail? Where is the sealant applied and what kind of sealant is used? Is this a new, improved production technique? Thanks.
  12. Mar 8, 2019 at 8:17 AM
    #7712
    TacodileSupreme
    Thomas
    Dallas, TX
    Super White SR5
    I believe its part of the new seal system. Not sure what sealant is used but it goes between the hinge and tube frame.
    rajacat9[QUOTED] and 2ayne like this.
  13. Mar 8, 2019 at 9:04 AM
    #7713
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Probably what is used to fasten the rubber bulb seal along all the openings.
  14. Mar 8, 2019 at 9:09 AM
    #7714
    Double Down
    '23 ACLB TRD OR
    *Order confirmed on 07/13/2018 with an ETA of 01/28/2019 for build start date.
    *Received the "In Production" email on 1/14/2019.
    *Received the "Components Produced" email on 2/1/2019.
    *Received the "In Assembly" email on 3/6/2019.
    *Received the "Sealant Curing" email on 3/7/2019.
  15. Mar 8, 2019 at 9:11 AM
    #7715
    Double Down
    '23 ACLB TRD OR
    Mine are aluminum so should be fine there. Powder coat looks pretty solid on mine as well.
  16. Mar 8, 2019 at 9:11 AM
    #7716
    I_eat_tacos
    I_eat_tacos Well-Known Member
    It's a mixture of a bulb seal and a rubber RTV type gasket. It's aerobic, so it has cure time. I can vouch that it is working great. I have been immersing it in the salt life of the midwest for the last month and don't have any leaks between that portion. The new gaskets on the panels work well, but has very minimal leaking if it does. I've seen more leaks come from the fenders up through the bedcaps than the actual camper itself.
  17. Mar 8, 2019 at 9:18 AM
    #7717
    rajacat9
    Washington State
    Unfortunately, my camper was delivered just before this improvement was instituted
    Could the camper be used, assuming no rain, while the gasket is curing?
  18. Mar 8, 2019 at 9:24 AM
    #7718
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Most likely (I could be completely wrong), is that the GFC is hanging out for a week in cabana mode while the seals cure.
    ace7196 likes this.
  19. Mar 8, 2019 at 9:38 AM
    #7719
    rajacat9
    Washington State
    I'm thinking that I could drive to Belgrade to have the gasket and sealant installed but I'd rather not cough up the money for a week in a hotel.
  20. Mar 8, 2019 at 9:46 AM
    #7720
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Without having the GFC would be wasted time for sure.
