Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Mar 8, 2019 at 10:10 AM
    #7721
    I_eat_tacos
    I_eat_tacos Well-Known Member
    Yep! It'll still cure with water present on it. They stressed more that you limited the panel open/closing the first week or so and then everything will be golden. Keep in mind I only had ~2 days cure time on mine when it was delivered. So far it's been fantastic. Haven't had time to camp in it yet though, but as a day to day topper its done great. I did have to readjust the positioning as it was off on one side, but not a big deal.
  2. Mar 8, 2019 at 10:16 AM
    #7722
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I stand corrected. Good info!
  3. Mar 8, 2019 at 10:47 AM
    #7723
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    Thank you. I can drive to Belgrade, get the work done, avoid hotels and have a nice extended exploration of Glacier, Yellowstone, etc.
  4. Mar 8, 2019 at 2:16 PM
    #7724
    Taco TRQ
    Taco TRQ Well-Known Member
    TuRDTaco
    Based on that, it sounds to me like they are allowing it to fully cure to ensure quality before they leave.
  5. Mar 8, 2019 at 2:35 PM
    #7725
    Taco TRQ
    TuRDTaco
    From their site.....
    Orders placed starting 2/28/19 have a base price of $6450.
    XL Orders placed starting 2/28/19 have a base price of $6950.
    **Due to large order volume, camper orders placed today have an estimated start date of June 2020.
    tonered and ace7196 like this.
  6. Mar 8, 2019 at 5:24 PM
    #7726
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Yea mine are aluminum too.. have had zero issues with them. Powder coat is holding up well.
    Double Down likes this.
  7. Mar 8, 2019 at 7:17 PM
    #7727
    Curtis_S
    Curtis_S Active Member
    Los Angeles area
    2016 diesel Colorado
    GFC #270
    11 campers completed this week; might be a new record. I'm one of 42 ready for production. Feeling a little rush -- Christmas in June -- I hope.
    eyemajeenyus, JLink, tonered and 2 others like this.
  8. Mar 8, 2019 at 7:44 PM
    #7728
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    Curious if anyone knows the distribution between 5 ft and 6 ft campers? I still can’t make up my damn mind if I want to lock myself into a long bed down the road or not if I were to order one for my access cab right now.
  9. Mar 8, 2019 at 10:19 PM
    #7729
    Kclamer
    Kclamer Well-Known Member
    Konstantin
    2018 Toyota Tacoma TRD Off-Road 4x4
    2.5" lift, 4.88 gears
    Just saw this today and I am definitely intrigued. Read and watching everything i could find about it. For $6500 though, there a few things I would want done differently. First are the black rubber strips that join the side walls at the top seam, looks super hokey. I would rather have solid aluminum sidewalls that do not open and do not have a seam at all, nice and smooth contour all the way around. I get the concept, its cool, its useful, just not good looking.
    Second thing is that all the doors look like they are fiberglass or something similar, it just looks cheap no matter how well you paint it. Aluminum sidewalls as an option maybe? A skylight option? Prep for solar option?
    I love the top portion, everything about it, the workmanship is top notch. I think the top is your specialty. Tent is simple, functional, looks good. How it unpacks and packs is amazing.
    The bottom is just not fitting with the top, quality and materials do not match in my opinion. Im gonna keep watching this project to see how it evolves and improves. Would drive out to Montana to get it installed if it met my needs, right now Im still planning on coughing up 10k for an ATOverland Habitat which is way overpriced but meets what im looking for.
  10. Mar 8, 2019 at 10:36 PM
    #7730
    snwbrdr852
    snwbrdr852 Well-Known Member
    Utah
    '17 DCSB OR V6 AT 4WD
    You've got options ...And one of them is pretty much exactly what you're describing.
    https://www.tacomaworld.com/threads/wedge-campers-assorted-oddities.538935/
  11. Mar 8, 2019 at 10:43 PM
    #7731
    Kclamer
    Konstantin
  12. Mar 9, 2019 at 5:39 AM
    #7732
    I_eat_tacos
    A few notes on that. Side panels are all aluminum and powdercoated to your choice of color. Standard colors are black, grey and white. As for not having them open they aren't going to change that at all, so if that's a deal breaker then probably it isn't for you. As for usefulness, don't knock it till you've tried both concepts. I'd suggest going to an expo to see both and compare what you like and don't like. If you are looking more for a camping setup without any flexibility for it being used daily as a truck the vagabond or AT Overland is probably better in that regard. But if you want to maintain a setup that's geared for daily use, off roading and camping the GFC is a lot more flexible. The side panels opening out are invaluable for grabbing gear out the side when you are deep in mud and trenches on odd angles.
    2ayne, JLink, COdude3 and 1 other person like this.
  13. Mar 9, 2019 at 6:21 AM
    #7733
    Taco TRQ
    TuRDTaco
    All the panels are aluminum, the textured powdercoating is there so light damage won’t be so obvious. Personally I think bare aluminum would look cooler even when scratched, but then you’d have galvanic corrosion with the steel fasteners. The top is translucent; clear sounds cool but I’m not sure how scratches, clouding, fading, UV damage won’t make it look horrible over time. The seals, I can’t say that there wasn’t a certain level of disappoint seeing them after all the initial cnc aluminum, extruded aluminum, etc.... but then it dawned on me that’s how auto manufacturers basically handle openings; everyone from Kia to Bentley. I’m pretty happy they are neither visible nor do they see much if any UV when closed on the windowless versions.
    If we’re really nitpicking, I’m not in love with the rivet solution on the strip where the panels meet the tent. I’d also rather the space frame was aluminum or better yet, the entire unit be made of titanium. Motorized panels and a flushing toilet (not trying to be an ass) would be slick too. But well frankly, beggars (myself being one of them) can’t be choosers. I’d much rather pay $6000 for this than $60,000 for the perfect one. For me personally, I think they cut corners in all the right places. Look at the other campers on the market at the 6k pricepoint, pay particular attention the the hinges and latches. Complex, quality, low production stuff is going to be expensive.
    Fwiw, I really dig the GFC tent, but we really wanted something where we could stand or sit sheltered from the rain. Being able to go potty without going outside in the wind, rain or when it’s 13 degrees out is a huge plus. We were eyeballing the AT too!... us being cheapskates was what sealed the deal.
  14. Mar 9, 2019 at 9:20 AM
    #7734
    Kclamer
    Konstantin
    I looked at at the Vegabond last night and I think that would meet all of my nit picks, not knocking on the GFC as its fabulous. It is just too renegade for me!
  15. Mar 9, 2019 at 11:26 AM
    #7735
    JLink
    Josh
    Ocean, NJ
    Different strokes for different folks..
    I don’t think there’s anyone in this thread that would claim the gfc is perfect for everyone.
    tonered and rajacat9 like this.
  16. Mar 11, 2019 at 6:39 AM
    #7736
    thesloppy1
    thesloppy1 Well-Known Member
    2016 quicksand Tacoma trd sport
    You are correct. It was pretty good too. Good food and beer. But, they have a three beer max, hence the growler to go. Keep that in mind.
  17. Mar 11, 2019 at 6:51 AM
    #7737
    thesloppy1
    Here are some shop and install pics. More to come.
    dskakie, 2ayne, rajacat9 and 2 others like this.
  18. Mar 11, 2019 at 7:16 AM
    #7738
    thesloppy1
    Couple more from the shop and back at home.
  19. Mar 11, 2019 at 7:17 AM
    #7739
    thesloppy1
    Interior with the sheets. Well worth the extra money. They are awesome.
  20. Mar 11, 2019 at 7:19 AM
    #7740
    thesloppy1
    The last few I took so far. The new seals look great. They will definitely not be any water intrusion issues at the top of the panels.
