Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Feb 5, 2018 at 9:08 AM
    #801
    bigdood
    bigdood Well-Known Member
    Trigger pulled....now the long wait begins, made even longer by our underwhelming snow season
    macdadmorgan likes this.
  2. Feb 5, 2018 at 10:38 AM
    #802
    blaze1
    blaze1 Well-Known Member
    Zach
    Portland Oregon
    2004 Tacoma DCSB 4x4, SR5
    What number in line??
  3. Feb 5, 2018 at 10:55 AM
    #803
    bigdood
    (just kidding, 60)
    08brickfjc likes this.
  4. Feb 5, 2018 at 11:00 AM
    #804
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Haha, didn’t see that little piece at the bottom when I first looked. Still, 60 is a solid number of orders for a pre-production product.
    bigdood[QUOTED] and DoorDing like this.
  5. Feb 6, 2018 at 1:14 PM
    #805
    Evanike
    Evanike Well-Known Member
    Evan
    Encinitas, CA
    GFC Camper, OME Suspension
    When do you guys plan to show the different color options (White, Black, Grey) for the camper? Will they only be matte finishes like the test camper? Trying to decide which color option I want!
    ace7196 and DoorDing like this.
  6. Feb 6, 2018 at 3:45 PM
    #806
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    So the upper frame and machined parts will be exactly the same color as the prototype (forge gray for the extrusions and titanium anodize for the machined parts). The lower tube frame can be had in either the orange of the prototype or in the forge gray to match the upper frame if you don't want to be as flashy. The outer panels will be a semi-gloss black, white, or a gray we're still deciding on. I can say now that the panel gray will split the difference between the tacoma silver sky metallic and the magnetic gray, that way it will look good on either factory color since there will be enough contrast to make it look intentional and not like a bad color matching job :)
    The two production units we're building the first week in March will be white and gray but I can take photos with the gray test piece against a truck once we choose it.
  7. Feb 6, 2018 at 5:21 PM
    #807
    Evanike
    Evan
    Encinitas, CA
    Awesome love the options! I have a white Tacoma so I feel like all those colors would look good, looking forward to seeing the first two production units to help me decide.
    Will you also be offering a bare metal option similar to the Habitat? Diggin this look tooAE51F122-62B6-41BE-B286-20CAF0161C26.jpg
    08brickfjc, Quadabaum and DoorDing like this.
  8. Feb 6, 2018 at 8:42 PM
    #808
    bigdood
    Fck. I'm stoked. Our winter has sucked so I'm thinking of spring/summer fun. Is it May yet?
  9. Feb 7, 2018 at 4:55 AM
    #809
    yellowdogpaddler
    yellowdogpaddler Well-Known Member
    doug
    2018 DCLB OR
    GoFast Camper, Faulken WildPeak, TRD Pro (4Runner) Wheels), Goal Zero Yeti/Solar
    A work of art!
  10. Feb 7, 2018 at 5:10 AM
    #810
    yellowdogpaddler
    doug
    2018 DCLB OR
    Two questions regarding tent portion: 1) side windows, does the mesh zip down/off? 2) it appears that it is intended to sleep with a person's head oriented towards the cab rather than the tailgate, if so is there a reason for this? I ask b/c of the side window orientation near a person's head... which if is the case would condensation be more of an issue than a person sleeping with his head oriented at the rear with the taller space of the tent?
  11. Feb 7, 2018 at 5:56 AM
    #811
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    There would be a large window by your head if you slept the other direction, its the window at the end door. Windows at the lower height do just what you are describing, vent the moisture, and create a draw from the smaller side windows to the large vent at the tall, open end.
  12. Feb 7, 2018 at 10:53 AM
    #812
    wileydavis
    Wiley
    2017 SR5
    dskakie, Willbeck, DoorDing and 5 others like this.
  13. Feb 7, 2018 at 10:57 AM
    #813
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  14. Feb 7, 2018 at 11:08 AM
    #814
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    tonered likes this.
  15. Feb 7, 2018 at 12:14 PM
    #815
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    tonered likes this.
  16. Feb 8, 2018 at 6:49 AM
    #816
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Sub’d and.... put my money where my *mouse* is.... looks like I’m order number 062. Really looking forward to see what options are available. Namely the ability to bolt on common brackets for a rear or either side awning/ enclosure. This thing looks exactly like what I’ve been dreaming of.... i was VERY close to going with the ARE lifttopper these past few years but this looks so much more robust and at little to no weight penalty. Super pumped. Thank you GFC
    -Yota
    wileydavis[OP], tonered and DoorDing like this.
  17. Feb 8, 2018 at 9:49 AM
    #817
    crumb
    crumb Member
    Nick
    Phoenix, AZ
    2016 Quicksand 4x4 ORDC
    I'd like to know more about entering and exiting the upper tent area. How much of a pull-up does it take to get up top?
  18. Feb 8, 2018 at 12:10 PM
    #818
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    just eyeballing it, but right about or just above hip height for the average person.
  19. Feb 8, 2018 at 12:12 PM
    #819
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    so more like a push out of a dip im assuming.. lol
    crumb likes this.
  20. Feb 8, 2018 at 12:31 PM
    #820
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    thats assuming you are standing on the tail gate though.
