Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Apr 18, 2019 at 8:54 AM
    #8201
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Anyone else get around the KodasTacoma way of doing it with the panels flipped upside down? I haven’t tried it yet but it seems to make sense.
    Once mine broke in it got much much easier to close, plus as mentioned if you really tuck the fabric good (which gets easier as it loosens up) it closes without much drama.
    ace7196 likes this.
  2. Apr 18, 2019 at 9:23 AM
    #8202
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I tried it yesterday and it seemed to be a bit easier to close. If I understood what was posted then it works but you have to force the cushions down through a space smaller than they are. The small panels are 25”x25”, the opening to mash the cushion into is only about 23”x24” because of the lips designed to support the panel. Since all the supporting lips are metal I’m not sure how well the cushion fabric will hold up to doing that repeatedly.
  3. Apr 18, 2019 at 9:28 AM
    #8203
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I like this mod.
    If there is a concern, you could use another bit of fabric between the cushion and lip as a sacrificial layer.
  4. Apr 18, 2019 at 9:37 AM
    #8204
    thesloppy1
    thesloppy1 Well-Known Member
    2016 quicksand Tacoma trd sport
    Yea, forcing the 25x25" cushions was a bit of a chore but I don't think it will do any long term damage. I'm not too concerned about it. Once it's in, it's not going to be moving anywhere to force any wear. If I'm moving day to day, I'd skip this option and just leave the two small panels out. But for "Long term" storage, I like being able to have everything in place (Minus the long narrow cushion) and have my bedding stored up top.
    Not a perfect solution but it does seem to work well.
    YOTA 4X4 and tonered like this.
  5. Apr 18, 2019 at 9:56 AM
    #8205
    ScenicCityOverland
    ScenicCityOverland Well-Known Member
    Alex
    2015 Inferno Orange Tacoma TRD Pro
    My RTT has 8 little loops sewed into the fabric on the side walls. When you get ready to close it you can attach little elastic hooks between them which pulls the walls together as you close it. I'd love to do something similar to the GFC when it gets here. That should make tucking it a little easier.
  6. Apr 18, 2019 at 10:03 AM
    #8206
    thesloppy1
    The GFC comes with one bungee for that purpose.
    It's actually not that hard to close. I've only had mine open a couple times and it's been pretty cold here. Leaving the windows slightly unzipped makes it much easier. The biggest problem is getting the pocket of air to get out of the tent as you are closing. Leaving the windows open helps a lot. Leaving out the two small panels makes it a complete non issue. You can close it in about 5 seconds that way. Even with all the panels in, in the normal configuration, it takes less than a minute for me to close. You just need to let the air seep out so you can push the fabric in without the air pushing it back out. It's definitely not as difficult as people make it seem and it can only get easier as the fabric breaks in.
  7. Apr 18, 2019 at 10:03 AM
    #8207
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    A long bungee from the hinge area the whole way around to the other side of the hinge on the outside of the tent might do the trick without potentially compromising the fabric.
    Otherwise, you might want to ask GFC what their recommendation would be for bonding to the fabric. That would at least give you some coverage.
  8. Apr 18, 2019 at 11:06 AM
    #8208
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    The XL units are harder to close because of the added area. I do all the things you suggested and I still have to climb up and sit on the roof's corners to close it. Granted I've only had it for a month so I'm hoping it loosens up and/or I get my closing technique refined. The roof is at a higher level than on Tacos therefor its more difficult to exert much downward pressure without a stepladder or sitting on the roof.
    Maybe GFC should make a video showing the proper closing technique.
  9. Apr 18, 2019 at 11:56 AM
    #8209
    thesloppy1
    That makes sense. I've never tried to close an XL. In fact, today was the first time i've actually seen one in person. He just happened to pull into a gas station I was at. Also, I'm 6'2", so it's pretty easy for me to grab the top and pull down and am tall enough to just lean on the top to get the latches closed.
    I could see the XL being more difficult. The guy I met today, had all of his panels out and in the bed of the truck. He got his the same time I got mine, right around 6 weeks ago. I was amazed how much space there was in the back of the full sized truck. It's like a palace.
    tonered likes this.
  10. Apr 18, 2019 at 12:06 PM
    #8210
    ScenicCityOverland
    Alex
    Good deal. I also got the extra door in mine, so we'll see how much harder that makes it.
    Look, anything is easier than closing up my tent with a 2 inch foam topper and comforter in it. lol
    rajacat9 and tonered like this.
  11. Apr 18, 2019 at 12:10 PM
    #8211
    thesloppy1
    True. My RTT was such a pain especially in the snow and rain. So far, the GFC is by far the easiest set up and take down I've had so far.
  12. Apr 18, 2019 at 1:47 PM
    #8212
    rajacat9
    Washington State
    If I removed all the panels, which I haven't done, I suspect that I'd have no problem closing it. I'm 5'-11". I can just stretch out and grab the fabric till the bar is in reach and get it down. I can close it with all of the panels in place but have to use the sit on the corner technique for the last 1/2". One tip is that it will close more easily if you make sure that the top is perfectly centered between the corner pieces.
    I can live with it the way it is but it would be great if I didn't have to get on top especially when its raining.
    Hmm... I wonder if using memory foam instead of the stock foam would make a difference.
  13. Apr 18, 2019 at 3:25 PM
    #8213
    rajacat9
    Washington State
    Please do it!:thumbsup: I haven't seen that price on memory foam around here. The stock foam has a lot of pushback and is very firm..
  14. Apr 18, 2019 at 3:32 PM
    #8214
    SJaYx2P
    SJaYx2P Well-Known Member
    1GDCPRE
    For any one that wants the exact specs of the stock foam it's a 2# polyurethane 35 ILD. If you want softer get a lower ILD but don't go too low or you'll just bottom out. Higher if you want more firm.
  15. Apr 18, 2019 at 3:55 PM
    #8215
    YOTA 4X4
    https://m.youtube.com/watch?v=fH5ZAISuo3w
    How about this one of JimBob closing his? Though it’s a Taco not full size.
    Bottom line, and we all go through this when it’s new is just go SLOW!!!!!!!, tuck the fabric good and close it slooooooow, it’ll close with little to no drama. Especially once it’s broken in a bit.
    PNW Explorer likes this.
  16. Apr 18, 2019 at 3:57 PM
    #8216
    rajacat9
    Washington State
    ace7196[QUOTED] likes this.
  17. Apr 18, 2019 at 4:22 PM
    #8217
    rajacat9
    Washington State
    Wow! That was fast and easy. One thing I notice is when standing on my tailgate is that the top is about 6" lower than my shoulders whereas Jim Bobs shoulders look to be well over a foot above the top. I can't get as much leverage as well as having to deal with more area. Its hard to get my strength into position where it can be used effectively. It's funny that everybody thinks that I'm just trolling or something but I'd like to see someone close my camper that fast with all the panels in. Like I was saying, when my camper was delivered both the driver and I working together, had a difficult closing the top. It's getting better and of course, I love my GFC.:)
    rkam65 and YOTA 4X4[QUOTED] like this.
  18. Apr 18, 2019 at 4:27 PM
    #8218
    YOTA 4X4
    I don’t think your trolling. When i first got mine I struggled too. Slowing down and tucking the fabric really well made all the difference to me.
  19. Apr 18, 2019 at 4:33 PM
    #8219
    rajacat9
    Washington State
    I think it's easy to underestimate how much more difficult the extra size and height make when closing the roof. I do slow down and have walked away for awhile waiting for the compressed air to leak out.
    Are there any other XL owners out there who'd care to share their experiences?
  20. Apr 18, 2019 at 4:37 PM
    #8220
    YOTA 4X4
    Windows full open i assume...
    And yours is full size, let’s see some pictures! I haven’t seen one of those. Well i saw Forge Overland’s Power Wagon at Expo but that’s a tent. His floor is 2” instead of 3” so I’m sure that helps
