Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. May 1, 2019 at 8:31 AM
    #8301
    msegal55
    msegal55 Insta: babe.the.blue.ox
    Mitch
    Orange County CA
    18 Cavalry Blue Trd Pro
    Unfortunately not in time. Hopefully another one comes up soon.
  2. May 1, 2019 at 9:16 AM
    #8302
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Mine might be for sale in a bit, still up in the air about what I’m doing with my life in the next couple months.
  3. May 1, 2019 at 9:19 AM
    #8303
    AvocadoTaco17
    AvocadoTaco17 Well-Known Member
    steve
    Oregon
    2017 Black Tacoma OffRoad TRD, Extended Cab/Bed
    Bed stiffeners, 32” hidden light bar
    Where you based out of?
  4. May 1, 2019 at 9:19 AM
    #8304
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Alaska.
    YOTA 4X4 likes this.
  5. May 1, 2019 at 10:33 AM
    #8305
    SJaYx2P
    SJaYx2P Well-Known Member
    1GDCPRE
    Me too. Just waiting on the next gen tundra.
  6. May 1, 2019 at 10:48 AM
    #8306
    OR4x4
    OR4x4 Well-Known Member
    Portland, OR
    2018 DCLB 4x4 TRD-OR Super White
    You could try and change your notification settings for a while. Get an email for every reply to this thread. It’s a bit overkill and your phone will be going off like crazy...
    I only recommend this because I have yet to see a GFC last more than 30 minutes to an hour.
    I bought my reservation within an hour of it being posted. It just got marked as ready for production on the leaderboard! :D
    msegal55[QUOTED] likes this.
  7. May 1, 2019 at 10:51 AM
    #8307
    OR4x4
    Portland, OR
    Add photography to the list of things I need to learn from you after moving up to Oregon! Excited to see this rig in person!!
  8. May 1, 2019 at 3:12 PM
    #8308
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    Has anyone sealed off the top of the bedsides under the bedside caps? If so, what did you use to do it?
    PNWTacoma and OR4x4 like this.
  9. May 1, 2019 at 5:25 PM
    #8309
    trouttaco
    trouttaco Well-Known Member
    Portland, Oregon
    Yeah, I used aluminum tape stuff and a bunch of gorilla glue epoxy silicone. I can send you exact products if you need
    PNWTacoma and ScenicCityOverland like this.
  10. May 1, 2019 at 5:28 PM
    #8310
    SoCOTaco
    Mitchell
    Lakewood, CO
    Yeah that would be great! I'm also considering weather stripping right near the inside part of the bed rail just as an easier solution. Is there a reason you used aluminum tape? I just ask because you aren't the first person I've heard recommend it.
    PNWTacoma likes this.
  11. May 1, 2019 at 5:30 PM
    #8311
    trouttaco
    Portland, Oregon
    Just to help seal everything up and then the silicone kinda helps seal around all the tabs. If you pull it apart it makes a bit more sense.
  12. May 1, 2019 at 5:31 PM
    #8312
    ScenicCityOverland
    ScenicCityOverland Well-Known Member
    Alex
    2015 Inferno Orange Tacoma TRD Pro
    My new bedside caps will be here tomorrow, so perfect timing! I’d definitely be interested in what products you used as well.
  13. May 1, 2019 at 7:32 PM
    #8313
    The Smith
    The Smith Well-Known Member
    Trinity Alps
    '17 4x4 V6 SR5
    ^Months ago, I remember reading in this thread about sealing things up under the bedside caps, but for the life of me, I can’t remember why. Anyone care to refresh my memory?
  14. May 1, 2019 at 7:47 PM
    #8314
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Thought is being it’s a camper and you want it dry as possible in there. And in truth no matter how dry the camper is. Even if it seals 100% doesn’t let even one drop of water in... it’s still just a truck bed, water comes in it’s just a fact of life. I run mine with a Decked drawer system so any water that seeps in from the tailgate or bedrails goes right under the drawers which are all plastic and 100% waterproof. If you were running something wood or similar back there waterproofing is more important I’d guess. No matter what I’d guess it’s tough to keep all water out from a truck bed just by the nature of it. I’ve never had a problem but as I said i stay high and dry up above it.
  15. May 1, 2019 at 8:58 PM
    #8315
    The Smith
    Trinity Alps
    '17 4x4 V6 SR5
    ^Thanks.
  16. May 1, 2019 at 9:34 PM
    #8316
    trouttaco
    Portland, Oregon
    I used this stuff under the bed rail caps and I used it to fill up the small gaps on the top of the bed rail nearest the cab...
    Gorilla Clear 100 Percent Silicone Sealant Caulk, Waterproof and Mold & Mildew Resistant, 10 ounce Cartridge, Clear, (Pack of 1) https://www.amazon.com/dp/B01MQW8AEM/ref=cm_sw_r_cp_api_i_ImNYCbB3VGJ0M
  17. May 2, 2019 at 4:43 PM
    #8317
    OR4x4
    Portland, OR
    It's not perfect, but here is my attempt to take a picture of the color samples in direct sunlight with my Super White Tacoma. Out of all the colors, the gray space frame changes the most when in direct sunlight vs. shade. Finally was able to pick colors for my GFC. Going into production soon!
    The black panel color matches the black plastic trim very well (the OR fenders).
    jolagues, tonered, JDR07 and 2 others like this.
  18. May 2, 2019 at 6:06 PM
    #8318
    JDR07
    JDR07 Well-Known Member
    Colorado
    2016 DCSB TRDOR
    Duct Tape
    HAs anyone been tracking the leaderboard? What are they producing per week now?
  19. May 3, 2019 at 12:31 AM
    #8319
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    Be sure youre filming when you send it off those sweet jumps
  20. May 3, 2019 at 4:14 AM
    #8320
    White Mountains
    White Mountains Well-Known Member
    Kevin
    Massachusetts
    Looks like they recently passed 700 orders and 200 completed units.
