Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Feb 8, 2018 at 12:49 PM
    #821
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Right, or normal bed height. If you have a drawer system you have even less of a gap to climb
  2. Feb 8, 2018 at 12:56 PM
    #822
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I dont see the point. If you climbed in that way, you'd want the tail gate down, so to close the tail gate you have to open the back hatch..so you'd have to crawl back down, open the hatch, close tail gate, close hatch.
    Might as well just climb in through the bed :notsure:
  3. Feb 8, 2018 at 1:08 PM
    #823
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    i interpreted it as climbing in through the bed. I think he was just asking how far he has to jump to get up into the tent from the bed?
    I could be wrong.
    here4cake likes this.
  4. Feb 8, 2018 at 2:02 PM
    #824
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    No answer on the bare aluminum finish? Nothing looks that great with old man tan, but thinking that would be pretty good.
    jubei, Evanike and DoorDing like this.
  5. Feb 8, 2018 at 2:03 PM
    #825
    Blackdawg
    Monte
    Wyoming/St. Louis
    ah i took it as asking about climbing in through the big door. nevermind.
  6. Feb 8, 2018 at 3:03 PM
    #826
    crumb
    crumb Member
    Nick
    Phoenix, AZ
    2016 Quicksand 4x4 ORDC
    I meant accessing the tent while you are in the camper. So once you climb into the bed, how far do you have to pull yourself up to get to the sleeping platform?
    Just curious how big my lats are going to get :muscleflexing:
    socalktk likes this.
  7. Feb 8, 2018 at 3:18 PM
    #827
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
  8. Feb 8, 2018 at 4:04 PM
    #828
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    M
    My guess is around 40" from the truck bed to the platform. Earlier in the thread it was mentioned that the height of the framing above the bed rails is 22", bed sides are about 19". A toughbox or bed drawer to step up on would probably make it easier going up and down.
  9. Feb 8, 2018 at 4:18 PM
    #829
    here4cake
    here4cake Well-Known Member
    I'd leave a storage box in there somewhere to act as a step stool.
  10. Feb 8, 2018 at 4:29 PM
    #830
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    We probably won't offer bare aluminum. The powder coating helps a smidge with condensation and also aids in keeping the panels from sounding tinny. I'm pretty sure the habitats are coated with sharkhide but that has to be periodically reapplied and does come off with some cleaners.
  11. Feb 8, 2018 at 4:31 PM
    #831
    wileydavis
    Wiley
    2017 SR5
    @crazysccrmd is right, 42" if you don't have a platform over the wheel wells.
  12. Feb 8, 2018 at 4:37 PM
    #832
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    For those that want different colors, getting a vinyl wrap after the purchase would be a simple solution. Given the panels are flat, wouldn’t be that costly either, or a DIY option.
  13. Feb 8, 2018 at 4:42 PM
    #833
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Wrap the inside too, and help with condensation/frost and provide a light reflective color inside of desired.
    DoorDing likes this.
  14. Feb 8, 2018 at 4:44 PM
    #834
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Vinyl wrap with premade branch pinstriping and mud splashes, so you look really kool downtown at the mall!
  15. Feb 8, 2018 at 4:59 PM
    #835
    wileydavis
    Wiley
    2017 SR5
    About 23" tall and 22 linear feet.
    ace7196[QUOTED], VE7OSR and DoorDing like this.
  16. Feb 8, 2018 at 5:02 PM
    #836
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Only really need to do 3 of the 4 panels, but simply estimate 24” high x 72” length of the bed x 2 of those, and 52” wide x 24” height x 1 or 2 for the ends. That should be close enough to get an estimated quote.
  17. Feb 8, 2018 at 5:03 PM
    #837
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    So there’s lots of talk about the aluminum panels, I thought the original plan also included soft sides like a Softopper ... any update on this, or am I wrong?
  18. Feb 8, 2018 at 5:08 PM
    #838
    wileydavis
    Wiley
    2017 SR5
    We're still going to offer it. But almost everyone on the deposit list seems to be wanting hard sides so most of the early effort has gone into those. It's on the early list of options to finish and will be compatible with the hard side frames, so switching at a later date will also be an option.
    crazysccrmd likes this.
  19. Feb 8, 2018 at 7:22 PM
    #839
    shortround13
    shortround13 Well-Known Member
    Sacramento
    04 DblCab TRD 4x4
    Did you ever get your Luggable Loo?
    :rofl:
    tonered likes this.
  20. Feb 8, 2018 at 8:52 PM
    #840
    yellowdogpaddler
    yellowdogpaddler Well-Known Member
    doug
    2018 DCLB OR
    GoFast Camper, Faulken WildPeak, TRD Pro (4Runner) Wheels), Goal Zero Yeti/Solar
    Black? I think Black could look nice with the tan.
