Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Feb 8, 2018 at 8:55 PM
    #841
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Funny you say that, because I threw out black immediately and was debating between the grey and white. :rofl:
    Not making me decision any easier.
  2. Feb 8, 2018 at 9:13 PM
    #842
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    compromise on Grey, can't go wrong then.
  3. Feb 8, 2018 at 9:28 PM
    #843
    Maxcustody
    Maxcustody Looking for answers, Refer to the EAD manual.
    Scott
    Berkeley Springs, West Virginia
    found my answer
    Thanks Scott
  4. Feb 8, 2018 at 9:32 PM
    #844
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Highest order number I’ve seen posted is 62.
    Maxcustody[QUOTED] likes this.
  5. Feb 8, 2018 at 9:40 PM
    #845
    Maxcustody
    Scott
    Thanks, After I posted I reread some stuff and someone said they were 127??
    went back and read it he was kidding.........
  6. Feb 8, 2018 at 9:48 PM
    #846
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    im thinking a black camper with my white truck.
    Evanike and Maxcustody like this.
  7. Feb 8, 2018 at 9:51 PM
    #847
    Maxcustody
    Scott
    Looking at putting deposit. Is the $5000 with all aluminum base with the tent. Kind of confusing on the site.
    socalktk[QUOTED] likes this.
  8. Feb 8, 2018 at 10:08 PM
    #848
    socalktk
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Yes it is. $5k includes everything you see so far.
  9. Feb 8, 2018 at 10:08 PM
    #849
    socalktk
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Put that deposit down soon, I think this 5k deal ends end of this month if im correct. Afterwards, they will start charging for shipping.
  10. Feb 9, 2018 at 4:19 PM
    #850
    Evanike
    Evanike Well-Known Member
    Evan
    Encinitas, CA
    GFC Camper, OME Suspension
    I also have a white Tacoma but am torn on what color to go with. I feel like the white would be too much white especially with the flat panels with no other colors to break it up. What number are you? I’m number 52, so if you are a lot farther up than me, I would love to see pictures of a black camper on your white Tacoma when you get it!
  11. Feb 9, 2018 at 4:22 PM
    #851
    blaze1
    blaze1 Well-Known Member
    Zach
    Portland Oregon
    2004 Tacoma DCSB 4x4, SR5
    Anybody with a tacoma in quicksand debating color choice? I’m torn between black and color matched.
  12. Feb 9, 2018 at 4:25 PM
    #852
    nasadk81
    nasadk81 Member
    Bay Area, CA, US
    2017 DCSB TRD OR QS 4X4
    I'm not on the waiting list yet, but I was actually thinking that the white might look nice on my quicksand... kind of a retro look.
  13. Feb 9, 2018 at 4:32 PM
    #853
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    The Go Girl converts an XX to be able to use a pee bottle just like an XY. It's like an upgrade.
    DoorDing likes this.
  14. Feb 9, 2018 at 4:45 PM
    #854
    Evanike
    Evan
    Encinitas, CA
    I think black would look really good on your rig especially with the black rims and black fender flares that you already have.
    tonered likes this.
  15. Feb 9, 2018 at 4:56 PM
    #855
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    If you generally travel in hot areas perhaps black wouldn't be the best choice because it absorbs too much heat.
  16. Feb 9, 2018 at 6:59 PM
    #856
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    The seal is attached to the panels. And there are interior stiffening ribs and hardware for the lift struts. And the front and rear edges are bent inward to protect the seal. So inverting them isn’t an option.
    The panels do come off easily though, so folks could have them repainted, vinyl wrapped, or sprayed with plastic dip pretty easily if they wanted to switch it up :)
  17. Feb 9, 2018 at 7:07 PM
    #857
    slowboater
    slowboater Well-Known Member
    I want black - but I too am worried about it absorbing too much heat for the dog. I may have to go white and then vinyl to match the truck.
  18. Feb 9, 2018 at 7:14 PM
    #858
    here4cake
    here4cake Well-Known Member
    With no windows in the camper I wouldn't put the dog in the back. I plan to retrofit some small, sliding windows into the GFC whenever I get mine, so that windows can be opened for cross-ventilation to keep the dog comfortable. And will likely add 12v fans on the dog's crate, and/or windows to move even more air.
  19. Feb 9, 2018 at 7:19 PM
    #859
    slowboater
    Yep, I want windows too - but they're not going to have them.... They're pretty inexpensive but then I have to install them...
  20. Feb 9, 2018 at 8:27 PM
    #860
    rajacat9
    Washington State
    Windows would be easy to install in flat plate aluminum. Just drill a starter hole and use a power jig saw with a metal cutting blade for the cut. Actually adding some portholes would be easy and relatively cheap. You can get portholes of plastic, bronze or aluminum in a variety of styles and sizes complete with screens . Hatches too.
