Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Jul 20, 2019 at 11:50 PM
    #9001
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Damn. A new frame is a lot more than I thought you’d say. I’ll be driving my Tacoma for all of my trip, from what google maps satellite imagery and online searching shows I will be able to make it through everything. If not I have almost two months off work to figure out how to backtrack and get around the problem. I’d love to take one of my bikes but my dog will be with me so that’s not really an option this go around.
  2. Jul 21, 2019 at 12:03 AM
    #9002
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Nice. The route is about 80% FS roads, and nothing over a four digit number so they should all be passable. In most areas if the main route is impassable it looks like there are combinations of other FS roads that will end up in the same place. My main goal is to make my way from the Pacific to Colorado on as little pavement as possible.
    tacomgee and ace7196[QUOTED] like this.
  3. Jul 21, 2019 at 3:29 AM
    #9003
    White Mountains
    White Mountains Well-Known Member
    Kevin
    Massachusetts
    What is the reason? Thank you for your information.
  4. Jul 21, 2019 at 8:04 AM
    #9004
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Damn! Adventure groms
    ace7196[QUOTED] likes this.
  5. Jul 21, 2019 at 2:58 PM
    #9005
    mac_2_nite
    mac_2_nite Well-Known Member
    Mac
    SoCal
    2017 DCLB Sport 4x4
    Been there, extremely frustrating. I guess I was first with this problem.
    Luckily drilling out the rivets and re-riveting wasn’t too bad. But I don’t have whatever that new sealant is between the frame and extrusion, so I dunno how that’ll work. I just slipped the new hinge material in with a friend’s help as it was awkward by myself.
    The more I look at the doors now, the more I see that back corner on both sides, I really notice that it gets pushed up more than the front. Not sure if a slightly shorter/weaker throw from the strut would change anything or not.
    I am considering asking them for at least one more replacement hinge for each side, because I think it’ll keep happening in the future
  6. Jul 21, 2019 at 3:07 PM
    #9006
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    It might leak there. When they upgraded my unit, to eliminate leaks, they applied the sealant all around perimeter and I've had no leaks as the result.
  7. Jul 21, 2019 at 3:36 PM
    #9007
    rtacowma
    rtacowma Well-Known Member
    The back corners of my unit raise more than the front corners. Mentioned that during my install and was looked at like I was crazy until the guy who installed it said "yeah, I have noticed they are pretty much all like that".
    mac_2_nite[QUOTED] likes this.
  8. Jul 21, 2019 at 3:56 PM
    #9008
    mac_2_nite
    Mac
    SoCal
    2017 DCLB Sport 4x4
    I was late to the sealant party (I have #43 and never paid attention to TW until my tent broke). But I have never seen any leaking from that area on mine. I’m sure it’ll come, and I was offered an overhaul if I give them the GFC for 8 weeks (ha.).
    Man, I looked at my buddy’s too because I thought I was crazy. The back corners push up more! And, if you haven’t had the pleasure of your hinge breaking (welcome to the club @ace7196 ), you probably wouldn’t know it but the door won’t close when the hinge is cracked because the strut pushes straight to the sky. There’s something there that can probably be reengineered, but I’m not that smart.
    I looked all over the innernets and could only find a UK company that makes struts that ‘pause’ called Camloc. After several emails between them and Suspa Springs going over all the details, they said they didn’t have a comparable model to whatever Suspa spring is on our GFC.
    When I saw the door wouldn’t close because that back strut was pushing skyward, I suspected that, over time, was the culprit to the wear on the hinge
    PNW Explorer and ace7196 like this.
  9. Jul 21, 2019 at 4:15 PM
    #9009
    mac_2_nite
    Mac
    SoCal
    2017 DCLB Sport 4x4
    You’re handier than I am, I rolled for a couple weeks with two ratchet straps around the whole thing!! I hope they get you the hinge piece and rivets soon, took me under an hour to repair. Ask for extras!!
  10. Jul 21, 2019 at 5:04 PM
    #9010
    2ayne
    2ayne Well-Known Member
    Zayne
    Ohio
    2017 Cement TRD Pro
    The fix would be a metal/stainless hinge imo.
    Mine too raises higher in the rear.
    mac_2_nite likes this.
  11. Jul 21, 2019 at 6:18 PM
    #9011
    rajacat9
    Washington State
    I'm thinking that some type of stainless strap hinge that would span over the stock hinge and through bolt with nylock nuts to the door. The strap hinge would attach to the extrusion's T track via a metal plate mounted with GFC track T nuts. Perhaps use three per door and the stock hinge would provide the waterproofing. You would use plastic or rubber spacers to clear the stock hinge and provide isolation. Of course, it would be best if these hinges be installed before failure of the stock hinges. Paint or plastic coat the hinges to match.
    I'm not sure if I want to be the first to do this. I'd like to see GFC's fix first.
    TacomArizona likes this.
  12. Jul 21, 2019 at 6:47 PM
    #9012
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    That’s cool.
    But why are you ignoring everyone else’s reply to your comment about “I know why”?
  13. Jul 21, 2019 at 7:27 PM
    #9013
    mac_2_nite
    Mac
    SoCal
    2017 DCLB Sport 4x4
    I’ve seen some on trailers that have a rubber section doing the hinge ‘work’ and the rest is buried under metal casing. I don’t think it would be practical in a GFC application. What hinges have you been looking at?
    The problems with a stainless steel piano hinge are that it’s not rust proof, nor would it be waterproof. Matching the hinge point on an overlay hinge outside of the stock plastic material would need to be very precise, for sure out of my engineering range. The door won’t open correctly if the hinging points are off, and may cause even more problems
  14. Jul 21, 2019 at 7:59 PM
    #9014
    trouttaco
    trouttaco Well-Known Member
    Portland, Oregon
    Anyone interested in a GFC that is trying to get rid of a 4wc Fleet or Eagle?
    PNW Explorer likes this.
  15. Jul 21, 2019 at 8:09 PM
    #9015
    trouttaco
    Portland, Oregon
    Ha Ha.
    I just was up at hood for the van expo and got to step inside one.
    I think I want a more “livable” space. Just putting out the feelers.
  16. Jul 21, 2019 at 8:40 PM
    #9016
    UMC
    UMC I will not comply
    Thomas
    South Fork of the American river.
    13 TRD Sport DCLB 4x4
    37's & rear locker
    BS! If you knew why you would say so.
  17. Jul 22, 2019 at 9:51 AM
    #9017
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Alternatively, you could explain to the folks here what you know (if you actually know something), or you could just not say that you know why if you aren't going to say why
  18. Jul 22, 2019 at 6:20 PM
    #9018
    rajacat9
    Washington State
    Yeah, that looks good but it would have to be a factory install unless you are willing to deal with the old sealant mess, lifting, the extrusion, making sure its on straight, etc.
    That's what they should've done in the first place.
  19. Jul 22, 2019 at 8:17 PM
    #9019
    blind cowboy
    blind cowboy Well-Known Member
    Don
    Auburn CA
    2002 TRD XC 5sp
    While not a lot of lumber up there, it's still nice to be able to use the truck as a truck.
    slowboater, d.shaw, BoneTaco and 4 others like this.
  20. Jul 22, 2019 at 9:36 PM
    #9020
    PNW Explorer
    PNW Explorer Well-Known Member
    Idaho
    2018 Tacoma TRD OR DCLB Mag Gray
    When did you snag those new rack mounts? I've been told "in a couple of weeks" for about two months....ugh
    ace7196 and Double Down like this.
