Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016+)' started by wileydavis, Oct 23, 2017.
  1. Aug 12, 2019 at 4:27 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Gold Hill, CO
    03 DC TRD 4x4
    OME suspension + Dakar AAL + 255/75R17 BFG KO2 + Snugtop XTR + Tundra brakes
    These vertical racks are great ... until you want to go off-road and everything on the trail wants to rip the bikes and rack off your truck. Low departure angle. Bikes sit higher than the top of the truck... A Sprinter is a few feet wider than my truck and about eighty billion feet taller.
  2. Aug 12, 2019 at 4:46 PM
    SenatorBlutarsky
    SenatorBlutarsky Well-Known Member
    Utah
    2013 DCLB...Drifter ordered
    I have the expansion tray for a fat bike on one of my trays. It fits standard mtb and road bike tires just fine.
    These vertical racks are great and I honestly wish I had gotten one sometimes due to the compact design (trail limo is long enough without 4 bikes on the back!). However, the northshore rack holds bikes by the fork crown so they definitely cannot take a road bike. I've also seen them rub some paint off of fork crowns, which I don't like. I'd look at Alta racks (https://www.altaracks.com/) or Recon racks (http://recon-racks.com/).
  3. Aug 12, 2019 at 5:09 PM
    ervandew
    ervandew Well-Known Member
    This is a big reason I got rid of my north shore rack. I almost had a bike ejected going through a dip (nothing crazy), and me and some friends recovered a brand new Pivot laying in the middle of the road that was ejected from another friend's north shore rack without them even realizing it.
  4. Aug 13, 2019 at 5:12 AM
    lojack
    lojack Active Member
    Ahren
    South Shore, Wi
    19 DCSB OR CB
    Well, I stand corrected. Although I swear I put a road bike on their NS rack once. They had it on a Quigley Sportsmobile for a while, and now on a 4x4 Sprinter. I know they've taken it off road a bunch, and don't think they've ever had a problem ejecting a bike. That does not sound like a good time. :eek:
    Of course, they are driving out from Idaho now so I asked what they have and she says they have a 1up now, as well :D
    SenatorBlutarsky and JasonLee like this.
  5. Aug 13, 2019 at 1:17 PM
    kdtpnw
    kdtpnw Member
    2011 6spd TRD Off Road Access Cab
    I don't have my GFC, but I have that same Yakima rack - it cleared with my Leer Canopy, and I have 800mm bars. There was enough play/flex that it would occasionally flex and make contact in the bumps but when stationary there was an inch or so gap. So you may not want metal bar ends, but otherwise you should be fine.
    Edit just noticed you said you had a topper too, so maybe this isn't helpful. I'll be in the same predicament if so. I'm not super worried about it though, the GFC should sit in a similar place to the topper.
  6. Aug 13, 2019 at 2:05 PM
    bgraboyes
    bgraboyes Active Member
    mine was fine with old topper too, the gfc has a more square/vertical rear door that was way too close for my comfort. any rough roads and im pretty sure it would have broken the window. with the hitch extender though it works perfect though!
  7. Aug 13, 2019 at 2:41 PM
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    What generation Taco are we talking about here, and is this on the stock hitch?
    I am surprised your bars are anywhere near the window, especially on a bike that long and w/ 29" wheels.
    I run a rockymounts backstage swing away rack, and with 780mm handle bars I have a few inches between the end of the bar and the face of the rear panel hinge material. The 2nd tray obviously is not an issue.
    GvgvSuyl1J1gkd7cYQCCBMN-wPtK-eKVDofnIQgB_4ede56b1cb232f236888760a9db8e6047dcbc92b.jpg
    I actually wanted to sell this and get a 1-up rack, but this has me re-thinking that if I am going to have to run a hitch extender.
  8. Aug 13, 2019 at 2:50 PM
    JasonLee
    Gold Hill, CO
    03 DC TRD 4x4
    rajacat9 and smelly621 like this.
  9. Aug 13, 2019 at 3:34 PM
    bgraboyes
    I have a second gen. I am away at work for the next week otherwise i'd go take some pics. from the looks of it, your rack trays must sit higher than the 1up rack. it's probably bc the 1up has the upward angling arrangement of trays and the one closest to the truck is pretty low. My bars hit about 4" shy of the top of the window. I think it works perfectly fine with the hitch extender or the rakattach swing-away. not sure if that all makes sense. i can take pics when i get home this weekend.
    PNW Explorer likes this.
  10. Aug 13, 2019 at 3:41 PM
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Yep, looking at the link @JasonLee posted I can see how much lower the inner tray is.
    Looks like another reason to get an aftermarket bumper with a tire carrier swing-out and a hitch welded to it.
    ace7196 likes this.
  11. Aug 13, 2019 at 4:12 PM
    wangamachang
    wangamachang Well-Known Member
    San Jose
    '09 Timberland Mica Tacoma TRD Off-Road 4x4 Access Cab
    While not a GFC, the 1up rack in combination with my 780mm bars ended up hitting the glass on my Drifter. It would need an extension of at least 3”.
    Figuring out a solution to go into the bed (6’) since I don’t want to hang a bunch of weight off the back and a swingout is a bit too burly for my needs. That being said, got a barely used 1Up rack for sale in Northern California.
    Additionally, I wanted to use the 1Up because with the bike removed, it clears the tailgate. A great alternative for those with wedge campers and not a swingout. Obviously need to take the bike off.
    If you don’t mind rotating your bars a bit, you can easily do so, but that just means you need to eye out straightening your handlebars and properly tightening your headset each time you go mountain biking, which I’m not a fan of.
    smelly621 likes this.
  12. Aug 13, 2019 at 5:11 PM
    PNW Explorer
    PNW Explorer Well-Known Member
    Idaho
    2018 Tacoma TRD OR DCLB Mag Gray
    @bgraboyes You might be talking about my exact idea today, but I want to make sure someone else is running a similar setup before dropping the cash. Basically my thought is to run in this order
    c4 fabrication overland bumper to RakAttach swing away to extender to 1up Super Duty Double. Besides the bumper is that what you are running? I need a little extra room to prevent the bikes from hitting my spare tire/gas can holder on my swing out bumper and adding an extender between the RakAttach and the 1up is the best solution I can come up with since I don't have the ability to weld a hitch onto my swingout bumper.
  13. Aug 13, 2019 at 5:43 PM
    Double Down
    Double Down Well-Known Member
    Colorado
    '12 TRD Off Road
    TRD Supercharger, King 2.5 Remote Resi F/R, TC UCA's, Deaver Exp U402 Leaf Pack, LEER 100XL Topper
    1Up rack on my 2nd Gen with a GFC.
    I can carry two bikes with 800mm bars and no window contact.
    I just didn’t push the 1Up all the way into the receiver hitch. I have a few inches sticking out. Hasn’t moved once since I installed it, despite heavy off road use.
    smelly621, JasonLee and wangamachang like this.
  14. Aug 13, 2019 at 6:15 PM
    wangamachang
    San Jose
    That’s pretty rad that it clears the GFC! Do you have the 2” hitch with the slot or the 1.25” to 2” quick? If you have the 2”, do you have your hitch lock in it?
  15. Aug 13, 2019 at 6:38 PM
    Double Down
    Colorado
    '12 TRD Off Road
    2” with the slot. But the Tacoma receiver is too wide for the hitch lock to work, I just run it without.
  16. Aug 13, 2019 at 7:20 PM
    Espinoza700
    Espinoza700 Well-Known Member
    Jeremy
    2012 DCSB TRD OR
    Knowing this, it will be a tough call between a swing out system a 1up if my Yakima rack doesn’t play well with the GFC.
    I appreciate all the info everyone is offering up on bike rack compatibility!
    TRACTIONMAG likes this.
  17. Aug 13, 2019 at 8:35 PM
    wangamachang
    San Jose
    Is it pulled beyond the lock being able to get in the slot? Wondering if that was my issue as I was nervous to run it without a hitch lock of some sort. (Borrowed mine from the Kuat because I had the same issue with the width).
  18. Aug 14, 2019 at 12:43 AM
    TRACTIONMAG
    TRACTIONMAG Well-Known Member
    California
    2018 Cement TRDOR-DCLB
    I also use a 1Up Rack with my GFC and the ability to move the rack fore and aft in the receiver while still having a significant amount of material in the hitch is why it’s the best solution for me. With 800mm bars I have about 2.5 inches between the end of bar and the GFC window and on rough roads never had it contact. Super happy I upgraded the rack from a Thule.
    Still room to lock the rack to the hitch and less of a profile and increase in length that a swing out requires. Swing out is handy for sure but I’d rather not have the extra length and possible play.
    smelly621 and wangamachang like this.
  19. Aug 14, 2019 at 7:21 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I’ve thought about doing that but I don’t want to stress the spindle any more than I have too. Already have a 35” tire, hi lift jack, and 2 3 gallon rotopax cans of gas.
    What kind of spindle does yours use? Maybe I’ll just have to do something to beef it up..
  20. Aug 14, 2019 at 7:34 AM
    JasonLee
    Gold Hill, CO
    03 DC TRD 4x4
    Double shear is your friend. Something like the Aluminess bumper design.
    mac_2_nite likes this.
