Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Feb 18, 2018 at 8:10 PM
    #1021
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    Sorry if I missed something- I haven't been through all 60 thread pages, but is every opening part sealed off when closed? Mainly trying to figure out if dirt will find its way into it over long, dusty trips.
    The_Black_Pearl likes this.
  2. Feb 18, 2018 at 8:20 PM
    #1022
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    It's as sealed as a regular topper would be. Meaning some dust will get in around the tailgate, but in general it stays pretty clean inside.
  3. Feb 18, 2018 at 8:28 PM
    #1023
    SoCOTaco
    Mitchell
    Lakewood, CO
    Sweet. I want one of these so bad, not sure it would happen for a couple years unfortunately though. Can't wait for the updated pics to come!
  4. Feb 18, 2018 at 9:17 PM
    #1024
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    I actually have in mind to try to find a small portable AC to rig up in the truck when/if I end up with a GFC. I have a small generator, it would be plenty for a 5000BTU portable unit... just want to find a SMALL one... I'll also want to be able to take it out and use a propane furnace for heat. I'm a pussy when it comes to extreme temperatures in either direction. And by "extreme" I mean lower than 60F and higher than 90F. lol
  5. Feb 18, 2018 at 10:18 PM
    #1025
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    This is pretty much wha i had going on as well with my kbvoodoo rack. Like that it kept the RTT out of the airstream.
    ON a side note regarding fuel economy and the GFC/RTT, when I put my JB up onto of the ALUCAB, the fuel economy actually never changed from having it on a kbvoodoo rack (midheight) so it sat flush with the cab of my truck. TO be honest, since i drove that day to go get the JB, my fuel mileage has been shit, I figured once I took off the RTT and just an with the ALUCAB I would have some fuel economy back, nope, its pretty much the exact same as it was. I've also had two other canopies on the truck and never had this bad of fuel mileage.
    I think what is currently killing me is the damn Cooper STT Pro tyres, I have on the truck, they are an e rated tyre and heavy as hell. I may need to switch back to the KO2's or Duratracs, to get some cab quietness(currently working on sound deadening the truck, as much as possible). Probably wouldn't hurt to go back to c rated either to drop some unsprung weight.
    Interested to see how the flat face of the GFC will affect the fuel economy. The JB RTT are fairly aerodynamic. Think I read that Wiley was getting 14mpg, which is pretty ashtonishing to be honest. Granted, you eat a doughnut and you lose a mpg with these trucks.
  6. Feb 18, 2018 at 10:41 PM
    #1026
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    So far my renogy 100w solar panel has held up well as a deflector. Has taken a few limb, rock and bird strikes and is still holding strong.
    DoorDing likes this.
  7. Feb 19, 2018 at 2:36 AM
    #1027
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    http://www.noriahome.com/
    CHECK THIS OUT!!! To be honest it's about 2 years overdue for launch... but when it finally it does it should be perfect, My last build I was debating about installing one of these in an aluminum windoor on my cap.
  8. Feb 19, 2018 at 2:39 AM
    #1028
    FrayAdjacent
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    Looks interesting! Compact size... I wonder what the back looks like... I know the condenser needs to vent outside, I'm kinda wondering if one could mount it vertically, and run a tube or pipe to an outlet. I'll check it out!
  9. Feb 19, 2018 at 2:53 AM
    #1029
    YOTA 4X4
    I doubt it... If I were you I'd but a "spare" rear or side panel for your GFC and reinforce and cut a hole to fit. Problem solved. only cost you the cost of one panel and some time. AC units generally don't work in the improper orientation... Something about refrigeration cycles, and condensing. HAHA.
  10. Feb 19, 2018 at 3:00 AM
    #1030
    FrayAdjacent
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    Yeah, it seems that it should be easy enough to get replacement panels. Maybe get one to cut an appropriate hole in, then fabricate some manner of cover when it's not in use. Rig up something that will work with a propex furnace as well. Swap the units out depending on weather.
  11. Feb 19, 2018 at 5:49 AM
    #1031
    unclewilson
    unclewilson Well-Known Member
    Wilson
    Michigan or Colorado
    Several
    Lots
    It's been a while since we've seen any photo teasers.... even some in process stuff would be sweet!
  12. Feb 19, 2018 at 6:01 AM
    #1032
    YOTA 4X4
    YES!!!!!
    :worthless:
    (MORE pics). ***Please***
  13. Feb 19, 2018 at 6:07 AM
    #1033
    wileydavis
    Wiley
    2017 SR5
    Everyone took a vacation before the madness begins :) But we'll be installing our new CNC fabric cutting table this week. I'll post some pics when we get it in.
  14. Feb 19, 2018 at 6:14 AM
    #1034
    YOTA 4X4
    Innovative, Smart, and a nice boss.... do you have any job openings????
  15. Feb 19, 2018 at 6:28 AM
    #1035
    wileydavis
    Wiley
    2017 SR5
    We just might! We've got a lot of product ideas in the pipeline and expect healthy sales when the campers start hitting the streets :)
  16. Feb 19, 2018 at 6:34 AM
    #1036
    YOTA 4X4
    Well good luck. I actually put in my vacation day requests last night (i work midnights in a powerhouse so it’s a 24/7/365 operation) for Overland Expo East dates. Mid-November. I plan on Repp’ing the sh*t out of my new GFC down there in NC, providing it performs as well as i am hoping in August for my two week trip. I think you’ve got a really good thing going and i wish you all the best. American ingenuity and manufacturing is just what this country needs! Good work GFC! Enjoy your well deserved break!
    -Yota
    ETAV8R, gmacmt and wileydavis[OP] like this.
  17. Feb 19, 2018 at 6:34 AM
    #1037
    wileydavis
    Wiley
    2017 SR5
    Indeed. We looked into outsourcing at first but made the determination we have to do it in-house to maintain quality control and be able to innovate some of the processes and design elements of the soft goods. We're outsourcing the fitted sheets sets, but anything related to the tent or to the planned soft interior concept we're working on will be designed and manufactured by us. We're really fortunate that Bozeman has a lot of soft-goods talent so we have access to folks who have worked for Patagonia, GoRuck, Yeti, Mystery Ranch, Simms, etc.
  18. Feb 19, 2018 at 8:31 AM
    #1038
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    GFC guys ... are you planning to go to any outdoor/RV shows in the West this spring? I’ll be out of the country during Overland ExPo.
  19. Feb 19, 2018 at 9:53 AM
    #1039
    SoCOTaco
    Mitchell
    Lakewood, CO
    I was gonna ask that too, I'll be at Expo West and really want to see one in person to motivate me to drop $5k.
  20. Feb 19, 2018 at 8:40 PM
    #1040
    RedBeard1
    Red
    @wileydavis
    Any chance we can get a close up of the side panel hinges? I’m with @DoorDing those riveted areas look sweet.
