Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Oct 25, 2017 at 12:00 PM
    #101
    socalktk
    socalktk Well-Known Member
    Kalvin
    San Gabriel Valley
    2016 DCLB TRD: OR
    Kings, Pelfreybilt skids, mobtown sliders, dakars, SCS
    I have the sticker on my ipad that is usually mounted on the unholy mount and big squeeze :D
    wileydavis[OP] likes this.
  2. Oct 25, 2017 at 12:06 PM
    #102
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    We did. But I liked the simplicity and wind performance of the single pivot design better. And the thing is long enough that you can sleep with your head toward the pivot end, even if you're 6' 4" like me. And i can stand up in the entire open floor area even on a platform over the wheel wells. It's also more stable when popped when you have a load on the rack (surfboards, bikes, etc.)
  3. Oct 25, 2017 at 12:08 PM
    #103
    wileydavis
    Wiley
    2017 SR5
    Nice. The Westy-style popup is really ideal for a small truck camper IMHO.
    tarandus and BloodyTaco like this.
  4. Oct 25, 2017 at 12:11 PM
    #104
    wileydavis
    Wiley
    2017 SR5
    Won't be any different than a regular topper in terms of sealing.
  5. Oct 25, 2017 at 12:27 PM
    #105
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    what is the weight of just the camper?
    could this be mounted on a thule rack?
    Benhamine likes this.
  6. Oct 25, 2017 at 12:33 PM
    #106
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    This looks really cool. If I was in the market I'd be very interested.
  7. Oct 25, 2017 at 12:34 PM
    #107
    gbpckrs
    gbpckrs Well-Known Member
    Dustin
    2016 Inferno TRD Sport DCSB
    This this looks awesome!!!
  8. Oct 25, 2017 at 12:40 PM
    #108
    perkj
    perkj Well-Known Member
    Can you explain in a little more detail as to how the panels will seal the interior of the bed from water/dust? On a normal topper/shell the shell is a single piece thus the sides, top, from, back, etc are "sealed" by default. Windows/Windoors are then cut into the 1 piece shell with rubber seals to both hold the glass in and keep water/dust out.
    In your design the shell is now 5 separate (and removable) aluminum pieces/walls that mount to a frame so I'm looking to understand how the panels-to-the-frame will be sealed as well as (and more importantly) the panels to each other at all the corners/edges to keep rain/dust from getting in. I'm just trying to understand how in a rain and driving at say 40 MPH or above the points where the panels come together to form a corner/edge will prevent rain (and/or dust) from making its way in. It just seems like the edges and corners will be extremely difficult to seal to ensure water doesn't pass thru.
  9. Oct 25, 2017 at 12:53 PM
    #109
    yotatomy
    yotatomy Active Member
    Tom
    Washington
    Will the tent be available with out the rack?
  10. Oct 25, 2017 at 1:15 PM
    #110
    wileydavis
    Wiley
    2017 SR5
    The panels seal to the tubular frame with a gasket and attach with perimeter tabs to ensure the gasket stays engaged. The tubular frame was designed so that each panel is a flat plane. Only the side panels would be removable during normal use. The rear panel edges seal the same way and has a hinged window like any other topper. The thing won't be a submarine but for highway driving and windy rainstorms it will shed water just fine. The upper frame also seals to the lower frame the same way. You're correct that it's challenging to seal something that is subjected to so much vibration. We opted to make each interface semi-floating and resilient.
  11. Oct 25, 2017 at 1:19 PM
    #111
    wileydavis
    Wiley
    2017 SR5
    Do you mean the roof rack on top of the camper or the lower shell? The roof bars on the upper are optional. The frame is a custome-extruded tube with utility track running the length, so the roof bars can be removed or bolted anywhere along the length (or roof baskets, etc.)
    If you mean the lower shell, then yes, eventually we'll be selling just the popup on its own with a non-removeable floor. But if you'd be putting it on a truck, the whole camper unit makes a much more usable space than just the tent portion would.
    BloodyTaco likes this.
  12. Oct 25, 2017 at 1:20 PM
    #112
    wileydavis
    Wiley
    2017 SR5
    Eventually we'll make just the upper tent available on its own. Weight would be about 150 lbs. But for the first run we're only selling them as a complete unit.
  13. Oct 25, 2017 at 2:29 PM
    #113
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    How much weight can the roof support when in the open position? I take kayaks (about 100lbs combined) camping frequently and they ride on the roof rack that would have to be removed for this poptop. It would be nice to not have to take them off to open the tent portion.
    socalktk likes this.
  14. Oct 25, 2017 at 2:31 PM
    #114
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Crap! This GFC is sounding better every freaking post.
    socalktk and wileydavis[OP] like this.
  15. Oct 25, 2017 at 2:32 PM
    #115
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    right almost to good to be true
    socalktk and tonered like this.
  16. Oct 25, 2017 at 2:42 PM
    #116
    wileydavis
    Wiley
    2017 SR5
    We'll probably size the lift struts for a 75 lb load on the roof. You could certainly throw 100 lbs on it and still open it but it will take a bit more oomph to lift it open. And the more weight you can move toward the pivot the easier it will be to lift.
  17. Oct 25, 2017 at 2:45 PM
    #117
    Trucko
    2005 Tacoma
    im excited about the timeline you have on your site. when it goes live how are you going to announce to the public we can purchase? will these fit a 05dcsb or will i need to wait longer?
  18. Oct 25, 2017 at 2:46 PM
    #118
    wileydavis
    Wiley
    2017 SR5
    That's the spot we want to be in :) The trick is that I designed most of the parts to be made by CNC machines and to be fast to assemble. The hardest part to automate is the sewing but we're fortunate that Bozeman is sort of a hotbed of sewing skills as we have a number of backpack manufacturers within two miles of our shop.
    Willbeck, jubei, OutbackHack and 3 others like this.
  19. Oct 25, 2017 at 2:50 PM
    #119
    Trucko
    2005 Tacoma
    please please tell me this will fit my 05dcsb
  20. Oct 25, 2017 at 2:52 PM
    #120
    wileydavis
    Wiley
    2017 SR5
    Well I'll be updating this thread as we build out the production betas. We'll have models right out of the gate for all Tacoma models except step sides. The big wait right now is for our tent frame extrusions to get here. The dies are being made now and we expect the first sticks of material to be here in the beginning of December. We should be welding up the tube sets for the production lower in about two weeks(the one in the test photos is a very crude test rig).
    BloodyTaco and socalktk like this.
