Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Mar 30, 2018 at 7:38 PM
    #1521
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    What???? No. @wileydavis said the GFC was 1/2” ABOVE the shark fin
  2. Mar 30, 2018 at 7:40 PM
    #1522
    YOTA 4X4
    This (correction Graeme said it)
    DoorDing likes this.
  3. Mar 30, 2018 at 7:44 PM
    #1523
    YOTA 4X4
    I’m guessing @inv3ctiv3 has his antenna cut from his old camper. I hope.
    rsxftw likes this.
  4. Mar 30, 2018 at 7:58 PM
    #1524
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Unless you’re lucky like me and got the small bump antenna from the factory.
    rsxftw likes this.
  5. Mar 30, 2018 at 8:00 PM
    #1525
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OR
    You really like Hondas
  6. Mar 30, 2018 at 8:01 PM
    #1526
    Evanike
    Evanike Well-Known Member
    Evan
    Encinitas, CA
    GFC Camper, OME Suspension
    I agree, I really like how tight that clearance is and am willing to chop that antenna. I also have a 2nd gen so I’m hoping it’s the same for mine as it is for @inv3ctiv3
    tonered likes this.
  7. Mar 30, 2018 at 8:10 PM
    #1527
    wileydavis
    wileydavis [OP] Well-Known Member
    Wiley
    2017 SR5
    @inv3ctiv3 has the kb voodoo bed rails which sit lower. With the stock plastic bed rails it should just clear the fin.
  8. Mar 30, 2018 at 8:24 PM
    #1528
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    ? how much height difference does the KB Voodoo bed rails reduce?
    The_Black_Pearl and ace7196 like this.
  9. Mar 30, 2018 at 8:25 PM
    #1529
    YOTA 4X4
    More options.... awesome
    tonered likes this.
  10. Mar 30, 2018 at 8:35 PM
    #1530
    aaen
    Northern Alberta
    I'm baffled by how changing out the rail can reduce the height significantly. From looking at the rails in person, I couldn't see any more then 1/8" drop which is negligible.
  11. Mar 30, 2018 at 9:13 PM
    #1531
    TACOROSSO
    TACOROSSO Well-Known Member
    2017 SR 4x4 5spd
    that... looks good. AF.
    I love the attention to detail on this thing; all the machined bits, the translucent roof and edge lighting... and the lightness... Damn.
    It might be a while from now, but I want.
    Really nice work GFC, seriously.
    tonered, DoorDing and Borrego Taco like this.
  12. Mar 30, 2018 at 9:14 PM
    #1532
    Evanike
    Evan
    Encinitas, CA
    So does the GFC sit closer to the shark fin on a stock 2nd gen than a stock 3rd gen? (Stock bedrails)
  13. Mar 30, 2018 at 9:37 PM
    #1533
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Looks better on the 2nd gen then on the 3rd gen IMO. Great work @wileydavis @gmacmt
    Can't wait to see a 1st gen version. Have you test fitted one? Mounting is going to be VERY different. Plus bed is a touch narrower...
    Willbeck, Digiratus and DoorDing like this.
  14. Mar 30, 2018 at 9:47 PM
    #1534
    Ralston
    Ralston Well-Known Member
    High in the Rockies
    Super White - 4x4 - TRD Off Road
    29401043_1822857654675600_84454765495698_31a4fbda45ab610fa0301b2ad3b24906d245ebde.jpg
    Looks like the fabric is being tweaked to make it tight like a drum? I never actually was a boy scout, but I sure do appreciate a taut tent.
    All in house, and all in USA!!!
  15. Mar 30, 2018 at 10:15 PM
    #1535
    Ralston
    High in the Rockies
    Yes, but only by an inch. The 2nd Gen has a bed depth which is an inch "shallower" than the bed depth of 3rd Gen Tacos. So yes, the GFC should sit closer to the roof.
    Evanike[QUOTED] likes this.
  16. Mar 30, 2018 at 11:06 PM
    #1536
    rsxftw
    rsxftw Well-Known Member
    Tyler
    Santa Cruz
    09 DCSB TRD Off-Road
    @wileydavis do you guys recommend running the kb voodoo bed rails for an easier more water tight install vs the stock rails or does this not matter? The only reason I’d purchase prior to picking mine up is if there’s a benefit for how the camper sits on the bed. Thanks!!
    The_Black_Pearl and Evanike like this.
  17. Mar 31, 2018 at 2:57 AM
    #1537
    YOTA 4X4
    @wileydavis can you remind me again what the max capacity of the roof is, in order to still retain opening and closing. I thought you had mentioned 75lbs, and 600lbs max when closed and latched.
    If that is the case is there a strut upgrade, that can make it handle more capacity (I’m thinking 100-125lbs). I realize this would make closing it empty slightly more difficult.
    Thanks
    The_Black_Pearl likes this.
  18. Mar 31, 2018 at 7:50 AM
    #1538
    wileydavis
    Wiley
    2017 SR5
    75 lbs when the CG of the load is at the strut mounting location. That weight goes down if the CG moves behind the mounting point and goes up if the CG moves forward of the mounting point. We don't recommend putting stronger struts on it for a number of reasons. Stronger struts will make it very difficult to close when you don't have a load on top. They'll also put more stress on the tent fabric, the frame, hinges, etc. The tent is a pretty big structure when opened and isn't designed to support a big load without being supported at each end like it is when closed. Your best bet is to position your load as close to the hinges as possible as that will increase the capacity and still be safe. The supplied struts have 100 lbs of force each. But you need some reserve to account for wind/snow loads, cold weather, and wear over time.
  19. Mar 31, 2018 at 8:16 AM
    #1539
    wileydavis
    Wiley
    2017 SR5
    We're working on an optional aluminum sleeve that pops onto the strut to lock it out. Not strictly necessary but good to have as the struts start to wear.
    The_Black_Pearl, DoorDing and tonered like this.
  20. Mar 31, 2018 at 8:18 AM
    #1540
    YOTA 4X4
    Thanks brother. I was imagining keeping a big boat on there down in the Keys this fall, but unloading it at night isn’t a big deal. I’d rather take care of this camper and not be lazy and try to leave too much up there. Thank you!!!!
    tonered likes this.
