Hondo Garage's New Thing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wileydavis, Oct 23, 2017.
  1. Apr 17, 2018 at 6:51 AM
    #1921
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    I thought it was Aaron Kaufman from Fast and Loud....
    angryskittle and gordi like this.
  2. Apr 17, 2018 at 6:54 AM
    #1922
    YOTA 4X4
    Just kidding Graeme!!!
    Although i kinda feel like this process would have made for an interesting “reality” TV show....
    :crapstorm:
    PB FAB and gmacmt like this.
  3. Apr 17, 2018 at 7:00 AM
    #1923
    unclewilson
    unclewilson Well-Known Member
    Wilson
    Michigan or Colorado
    Several
    Lots
    @inv3ctiv3 Any comment
    It was mentioned that you could use square tube pieces (maybe 1x3 cut couple inches wide) to offset the opening gas struts. The AL channel accepts t-nuts. I have a foxwing awning and am looking at something like that.
  4. Apr 17, 2018 at 7:32 AM
    #1924
    gmacmt
    gmacmt Well-Known Member
    Graeme
    Montucky
    98 taco, Ram on 40's
    Third brake light wiring runs through the extrusion, and down the rear left frame rail into the bed of the truck, harness that comes with the camper is ready to be integrated into the stock system. Lighting harness runs down the front left frame rail into the bed, so its basically wherever you want to run it from there. House battery in the bed, existing wiring harness, etc.
    A lot more in terms of photos/content coming this week. Our buddy drew martin is shooting photos in the shop this week while we are working to get a couple of these out the door. Working long days to document and manufacture, and it's all looking really good.
    I met Aaron at the Pikes Peak hill climb a couple years back. Couldn't be a nicer guy. Glad I don't seem like the greasy dude to his left :eek:
    -g
    bigdood, Quadabaum and DoorDing like this.
  5. Apr 17, 2018 at 9:46 AM
    #1925
    08brickfjc
    08brickfjc
    Ross
    Montana
    ‘08 FJ Cruiser ‘94 FZJ80
    DoorDing likes this.
  6. Apr 17, 2018 at 10:23 AM
    #1926
    08brickfjc
    08brickfjc
    Ross
    Montana
    Not a fan of the crimp-on style and I also prefer to tread lightly on factory wiring :sawzall:
  7. Apr 17, 2018 at 10:24 AM
    #1927
    I_eat_tacos
    I_eat_tacos Well-Known Member
    Splicing the factory Tow harness should be more of where everyone should want to install it to. That way in the event you no longer have the camper, etc. then you can just replace the tow package part of the harness if it were to be unusable after. Or even a way that just plugged into the factory tow ports with a male/female so it could still be used. Probably a more expensive way, but I plan on using tow harness since it can be replaced easily without rewiring half the truck.
    08brickfjc likes this.
  8. Apr 17, 2018 at 10:42 AM
    #1928
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    FWIW I bought a RTT, used it three times over the course of two months, decided it wasn't for me, and sold it for $1 more than I paid for it. Might be worth trying at least.
    Shellshock likes this.
  9. Apr 17, 2018 at 11:17 AM
    #1929
    rajacat9
    rajacat9 Well-Known Member
    Washington State
    Curt offers a number of harness adapters that might provide a solution. Here's one.https://www.amazon.com/CURT-55384-Custom-Wiring-Connector/dp/B0009FJ38Q
    hardcharger77 and ace7196 like this.
  10. Apr 17, 2018 at 11:46 AM
    #1930
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    @rajacat9 That's a great idea. Adding to my list.
  11. Apr 17, 2018 at 12:03 PM
    #1931
    I_eat_tacos
    Exactly what I was envisioning! Thanks for the link! Should just order those along with the camper and alter the wiring as needed. Or add a connector from the GFC that plugs into this. Either way whether GFC sends the harness for lighting, 3rd brake, etc or just gives me open wires for me to DIY it then we should be set. For $21 that is an easy buy to not have to touch the vehicle harness.
  12. Apr 17, 2018 at 12:48 PM
    #1932
    I_eat_tacos
    This harness goes in between the factory harness and the trailer plug, so you tap in without being intrusive (it is all hidden behind the bumper, you'd have to bend down underneath to see the vehicle side harness). Think of this as a tee. You are basically turning the harness behind your trailer connector into a 3-way and you tap into the harness's power. The extra bonus/precaution is that the trailer harness bypasses the ignition, so you can still tap into power with the keys out of the vehicle.
    ace7196[QUOTED] likes this.
  13. Apr 17, 2018 at 1:36 PM
    #1933
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    As an added bonus the 4-pin connector is what is on all the little u-haul utility trailers in my area. I was anticipating renting them more often for hauling dirt/etc. now vs. removing the GFC and using the bed.
  14. Apr 17, 2018 at 1:46 PM
    #1934
    I_eat_tacos
    Shouldn't need to cut anything on the vehicle. Depending how the GFC is wired when we get them will determine if the harness that we buy will need to be cut. I doubt anything needs to be cut, but probably would just need to add a 4 pin connector to plug into this harness.
  15. Apr 17, 2018 at 1:56 PM
    #1935
    slowboater
    slowboater Well-Known Member
    When I had my canopy installed (I didn't do it myself) - they just spliced the left rear brake light. It was ridiculously easy. I try to minimize cutting into the electrical system but this is the way it's done for 1000's of canopies so I didn't sweat it at all.
    For the GFC I'll just take the wire that's there from the canopy brake light and wire it up. Easy peasy.
    I was looking into a harness like what is above. It looks to be a really nice product. But, I think I've decided to put a separate battery in the bed (a house battery) and run a wire directly from the existing battery (positive) with a solenoid to keep from discharging the cranking battery. The solenoids are not that expensive (used extensively in boating applications). Then when the truck is running both batteries will be charging but when you shut off the truck - the lights and whatnot in the bed only draw from the isolated house battery.
  16. Apr 17, 2018 at 2:17 PM
    #1936
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Nothing wrong with some crimp connectors if installed properly. In fact, I would rather have one of those then some in line trailer wiring adding unnecessary complication.
    The 3rd brake for my topper is spliced into the brake light wiring right behind the tail light, and has been fine for years.
    slowboater likes this.
  17. Apr 17, 2018 at 2:40 PM
    #1937
    I_eat_tacos
    Agreed. I originally planned on splicing, nothing against it. But I don't have a 3 prong plug in the bed and I want one. This enables me to add that with a little finesse and not intruding too far into the harness. I've had many a headache with wiring harnesses. Sounds silly, but I'd rather not mess around with it, plus I can add a feature and hook up a double battery in my engine bay to feed everything while vehicle is off. Two birds, one stone in my eyes. To each his own.
  18. Apr 17, 2018 at 3:40 PM
    #1938
    macdadmorgan
    macdadmorgan Clean like ammonia, Sick like pneumonia
    IG@overlandonthefly
    W-Mass
    17 TRDORMT
    Things to get me in over my head
    For anyone who want to install a second battery this is a must read, long, but very informative. This read is what sold me on the Blue Sea automatic charging relay.
    http://www.sportsmobileforum.com/forums/f20/battery-isolators-separators-and-switches-7991.html
  19. Apr 17, 2018 at 3:53 PM
    #1939
    macdadmorgan
    IG@overlandonthefly
    W-Mass
    17 TRDORMT
    Well if you run solar the amp draw that is needed to keep your isolator relay closed is a significant amount. Nothing wrong with your setup, just not for everyone and its $179.
  20. Apr 17, 2018 at 3:56 PM
    #1940
    danneskjold
    danneskjold Well-Known Member
    Brian
    Shoreline, WA
    2018 F150
    There's plenty of reasons to run different isolators. Solar support, on/off, manual linking, etc. Just because you don't need that doesn't mean there's "no reason" to purchase a more expensive isolator.
